SMESH_MeshAlgos::Intersector::Algo Struct Reference
Intersect faces of a mesh. More...
 Algo (SMDS_Mesh *mesh, double tol, const std::vector< gp_XYZ > &normals)
void Cut (const SMDS_MeshElement *face1, const SMDS_MeshElement *face2, const int nbCommonNodes)
 Intersect two faces. More...
void Cut (const SMDS_MeshElement *face, SMESH_NodeXYZ &lineEnd1, int edgeIndex1, SMESH_NodeXYZ &lineEnd2, int edgeIndex2)
 Store a face cut by a line given by its ends accompanied by indices of intersected face edges. More...
void MakeNewFaces (TElemIntPairVec &theNew2OldFaces, TNodeIntPairVec &theNew2OldNodes, const double theSign, const bool theOptimize)
 Split intersected faces. More...
void IntersectNewEdges (const CutFace &theCFace)
 Intersect edges added to myCutFaces. More...
Data Fields
SMDS_Mesh * myMesh
double myTol
double myEps
const std::vector< gp_XYZ > & myNormals
TCutLinkMap myCutLinks
 assure sharing of new nodes More...
TCutFaceMap myCutFaces
TNNMap myRemove2KeepNodes
 node merge map More...
const SMDS_MeshElement * myFace1
const SMDS_MeshElement * myFace2
std::vector< SMESH_NodeXYZ > myNodes1
std::vector< SMESH_NodeXYZ > myNodes2
std::vector< double > myDist1
std::vector< double > myDist2
int myInd1
int myInd2
int myNbOnPlane1
int myNbOnPlane2
TIntPointSet myIntPointSet
bool isPlaneIntersected (const gp_XYZ &n2, const double d2, const std::vector< SMESH_NodeXYZ > &nodes1, std::vector< double > &dist1, int &nbOnPlane1, int &iNotOnPlane1)
 Check if a triangle intersects the plane of another triangle. More...
void computeIntervals (const std::vector< SMESH_NodeXYZ > &nodes, const std::vector< double > &dist, const int nbOnPln, const int iMaxCoo, double *u, int *iE)
 Compute parameters on the plane intersection line of intersections of edges of a triangle. More...
void cutCoplanar ()
 Intersect two co-planar faces. More...
void addLink (CutLink &link)
 Store a CutLink. More...
bool findLink (CutLink &link)
 Find a CutLink with an intersection point coincident with that of a given link. More...
bool coincide (const gp_XYZ &p1, const gp_XYZ &p2, const double tol) const
gp_XY p2D (const gp_XYZ &p) const
void intersectLink (const std::vector< SMESH_NodeXYZ > &nodes1, const std::vector< double > &dist1, const int iEdge1, const SMDS_MeshElement *face2, CutLink &link1)
 Compute intersection point of a link1 with a face2. More...
void findIntPointOnPlane (const std::vector< SMESH_NodeXYZ > &nodes, const std::vector< double > &dist, CutLink &link)
 Try to find an intersection node on a link collinear with the plane intersection line. More...
void replaceIntNode (const SMDS_MeshNode *nToKeep, const SMDS_MeshNode *nToRemove)
 Store node replacement in myCutFaces. More...
void computeIntPoint (const double u1, const double u2, const int iE1, const int iE2, CutLink &link, const SMDS_MeshNode *&node1, const SMDS_MeshNode *&node2)
 Compute intersection point on a link of either of faces by choosing a link whose parameter on the intersection line in maximal. More...
void cutCollinearLink (const int iNotOnPlane1, const std::vector< SMESH_NodeXYZ > &nodes1, const SMDS_MeshElement *face2, const CutLink &link1, const CutLink &link2)
 Add intersections to a link collinear with the intersection line. More...
void setPlaneIndices (const gp_XYZ &planeNorm)
 Choose indices on an axis-aligned plane. More...
bool intersectEdgeEdge (const gp_XY s1p0, const gp_XY s1p1, const gp_XY s2p0, const gp_XY s2p1, double &t1, double &t2, bool &isCollinear)
 Intersect two 2D line segments. More...
bool intersectEdgeEdge (int iE1, int iE2, IntPoint2D &intPoint)
 Intersect two edges of co-planar triangles. More...
bool isPointInTriangle (const gp_XYZ &p, const std::vector< SMESH_NodeXYZ > &nodes)
 Check if a point is contained in a triangle. More...
const SMDS_MeshNode * createNode (const gp_XYZ &p)
◆ Algo()
SMESH_MeshAlgos::Intersector::Algo::Algo ( SMDS_Mesh *  mesh,
double  tol,
const std::vector< gp_XYZ > &  normals
◆ addLink()
void SMESH_MeshAlgos::Intersector::Algo::addLink ( CutLink &  link)
Store a CutLink.
◆ coincide()
bool SMESH_MeshAlgos::Intersector::Algo::coincide ( const gp_XYZ &  p1,
const gp_XYZ &  p2,
const double  tol
◆ computeIntervals()
void SMESH_MeshAlgos::Intersector::Algo::computeIntervals ( const std::vector< SMESH_NodeXYZ > &  nodes,
const std::vector< double > &  dist,
const int  nbOnPln,
const int  iMaxCoo,
double *  u,
int *  iE
[in]nodes- triangle nodes
[in]dist- distance of triangle nodes from the plane of another triangle
[in]nbOnPln- number of nodes lying on the plane of another triangle
[in]iMaxCoo- index of coordinate of max component of the plane intersection line
[out]u- two computed parameters on the plane intersection line
[out]iE- indices of intersected edges
◆ computeIntPoint()
void SMESH_MeshAlgos::Intersector::Algo::computeIntPoint ( const double  u1,
const double  u2,
const int  iE1,
const int  iE2,
CutLink &  link,
const SMDS_MeshNode *&  node1,
const SMDS_MeshNode *&  node2
[in]u1- parameter on the intersection line of link iE1 of myFace1
[in]u2- parameter on the intersection line of link iE2 of myFace2
[in]iE1- index of a link myFace1
[in]iE2- index of a link myFace2
[out]link- CutLink storing the intersection point
[out]node1- a node of the 2nd link if two links intersect
[out]node2- a node of the 2nd link if two links intersect
◆ createNode()
const SMDS_MeshNode * SMESH_MeshAlgos::Intersector::Algo::createNode ( const gp_XYZ &  p)
Store a CutLink.
References SMDS_Mesh::AddNode(), myMesh, and SMDS_MeshElement::setIsMarked().
◆ Cut() [1/2]
void SMESH_MeshAlgos::Intersector::Algo::Cut ( const SMDS_MeshElement *  face,
SMESH_NodeXYZ &  lineEnd1,
int  edgeIndex1,
SMESH_NodeXYZ &  lineEnd2,
int  edgeIndex2
Edge index is <0 if a line end is inside the face.
[in]face- a face to cut
[in,out]lineEnd1- line end coordinates + optional node existing at this point
[in]edgeIndex1- index of face edge cut by lineEnd1
[in,out]lineEnd2- line end coordinates + optional node existing at this point
[in]edgeIndex2- index of face edge cut by lineEnd2
References SMESH_TNodeXYZ::_node, SMDS_MeshElement::GetID(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), SMDS_MeshElement::GetNodeWrap(), SMESH_TNodeXYZ::Node(), and SMESH_TNodeXYZ::Set().
◆ Cut() [2/2]
void SMESH_MeshAlgos::Intersector::Algo::Cut ( const SMDS_MeshElement *  face1,
const SMDS_MeshElement *  face2,
◆ cutCollinearLink()
void SMESH_MeshAlgos::Intersector::Algo::cutCollinearLink ( const int  iNotOnPlane1,
const std::vector< SMESH_NodeXYZ > &  nodes1,
const CutLink &  link1,
const CutLink &  link2
References Node.
◆ cutCoplanar()
void SMESH_MeshAlgos::Intersector::Algo::cutCoplanar ( )
◆ findIntPointOnPlane()
void SMESH_MeshAlgos::Intersector::Algo::findIntPointOnPlane ( const std::vector< SMESH_NodeXYZ > &  nodes,
CutLink &  link
References Node.
◆ findLink()
bool SMESH_MeshAlgos::Intersector::Algo::findLink ( CutLink &  link)
◆ intersectEdgeEdge() [1/2]
bool SMESH_MeshAlgos::Intersector::Algo::intersectEdgeEdge ( const gp_XY  s1p0,
const gp_XY  s1p1,
const gp_XY  s2p0,
const gp_XY  s2p1,
double &  t1,
double &  t2,
bool &  isCollinear
◆ intersectEdgeEdge() [2/2]
bool SMESH_MeshAlgos::Intersector::Algo::intersectEdgeEdge ( int  iE1,
int  iE2,
IntPoint2D &  intPoint
[in,out]iE1- edge index of triangle 1
[in,out]iE2- edge index of triangle 2
[in,out]intPoints- intersection points
[in,out]nbIntPoints- nb of found intersection points
References Node, and SMESH_TNodeXYZ::Node().
◆ intersectLink()
void SMESH_MeshAlgos::Intersector::Algo::intersectLink ( const std::vector< SMESH_NodeXYZ > &  nodes1,
const std::vector< double > &  dist1,
const int  iEdge1,
CutLink &  link1
References SMESH_TNodeXYZ::Node(), and SMESH_TNodeXYZ::Set().
◆ IntersectNewEdges()
void SMESH_MeshAlgos::Intersector::Algo::IntersectNewEdges ( const CutFace &  theCFace)
References Node.
Referenced by SMESH_MeshAlgos::Intersector::CutByPlanes().
◆ isPlaneIntersected()
bool SMESH_MeshAlgos::Intersector::Algo::isPlaneIntersected ( const gp_XYZ &  n2,
const double  d2,
int &  nbOnPlane1,
int &  iNotOnPlane1
[in]nodes1- nodes of triangle 1
[in]n2- normal of triangle 2
[in]d2- a constant of the plane equation 2
[out]dist1- distance of nodes1 from the plane 2
[out]nbOnPlane- number of nodes1 lying on the plane 2
bool - true if the triangle intersects the plane 2
◆ isPointInTriangle()
bool SMESH_MeshAlgos::Intersector::Algo::isPointInTriangle ( const gp_XYZ &  p,
References SMESH_MeshAlgos::GetBarycentricCoords().
◆ MakeNewFaces()
void SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces ( SMESH_MeshAlgos::TElemIntPairVec &  theNew2OldFaces,
SMESH_MeshAlgos::TNodeIntPairVec &  theNew2OldNodes,
◆ p2D()
gp_XY SMESH_MeshAlgos::Intersector::Algo::p2D ( const gp_XYZ &  p) const
References myInd1, and myInd2.
◆ replaceIntNode()
void SMESH_MeshAlgos::Intersector::Algo::replaceIntNode ( const SMDS_MeshNode *  nToKeep,
const SMDS_MeshNode *  nToRemove
References SMDS_MeshElement::GetID().
◆ setPlaneIndices()
void SMESH_MeshAlgos::Intersector::Algo::setPlaneIndices ( const gp_XYZ &  planeNorm)
References SMESH_MeshAlgos::MaxIndex().
◆ myCutFaces
TCutFaceMap SMESH_MeshAlgos::Intersector::Algo::myCutFaces
◆ myCutLinks
TCutLinkMap SMESH_MeshAlgos::Intersector::Algo::myCutLinks
◆ myDist1
std::vector< double > SMESH_MeshAlgos::Intersector::Algo::myDist1
◆ myDist2
std::vector< double > SMESH_MeshAlgos::Intersector::Algo::myDist2
◆ myEps
double SMESH_MeshAlgos::Intersector::Algo::myEps
◆ myFace1
const SMDS_MeshElement* SMESH_MeshAlgos::Intersector::Algo::myFace1
◆ myFace2
const SMDS_MeshElement* SMESH_MeshAlgos::Intersector::Algo::myFace2
◆ myInd1
int SMESH_MeshAlgos::Intersector::Algo::myInd1
Referenced by p2D().
◆ myInd2
int SMESH_MeshAlgos::Intersector::Algo::myInd2
◆ myIntPointSet
TIntPointSet SMESH_MeshAlgos::Intersector::Algo::myIntPointSet
◆ myMesh
SMDS_Mesh* SMESH_MeshAlgos::Intersector::Algo::myMesh
Referenced by createNode().
◆ myNbOnPlane1
int SMESH_MeshAlgos::Intersector::Algo::myNbOnPlane1
◆ myNbOnPlane2
int SMESH_MeshAlgos::Intersector::Algo::myNbOnPlane2
◆ myNodes1
std::vector< SMESH_NodeXYZ > SMESH_MeshAlgos::Intersector::Algo::myNodes1
◆ myNodes2
std::vector< SMESH_NodeXYZ > SMESH_MeshAlgos::Intersector::Algo::myNodes2
◆ myNormals
const std::vector< gp_XYZ >& SMESH_MeshAlgos::Intersector::Algo::myNormals
◆ myRemove2KeepNodes
TNNMap SMESH_MeshAlgos::Intersector::Algo::myRemove2KeepNodes
node merge map
◆ myTol
double SMESH_MeshAlgos::Intersector::Algo::myTol
