SMDS_VolumeOfNodes Class Reference
#include <SMDS_VolumeOfNodes.hxx>
Inheritance diagram for SMDS_VolumeOfNodes:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
 SMDS_VolumeOfNodes (const SMDS_MeshNode *node1, const SMDS_MeshNode *node2, const SMDS_MeshNode *node3, const SMDS_MeshNode *node4)
 SMDS_VolumeOfNodes (const SMDS_MeshNode *node1, const SMDS_MeshNode *node2, const SMDS_MeshNode *node3, const SMDS_MeshNode *node4, const SMDS_MeshNode *node5)
 SMDS_VolumeOfNodes (const SMDS_MeshNode *node1, const SMDS_MeshNode *node2, const SMDS_MeshNode *node3, const SMDS_MeshNode *node4, const SMDS_MeshNode *node5, const SMDS_MeshNode *node6)
 SMDS_VolumeOfNodes (const SMDS_MeshNode *node1, const SMDS_MeshNode *node2, const SMDS_MeshNode *node3, const SMDS_MeshNode *node4, const SMDS_MeshNode *node5, const SMDS_MeshNode *node6, const SMDS_MeshNode *node7, const SMDS_MeshNode *node8)
 Create an hexahedron. More...
bool ChangeNodes (const SMDS_MeshNode *nodes[], const int nbNodes)
 ~SMDS_VolumeOfNodes ()
virtual void Print (std::ostream &OS) const override
 Print self. More...
int NbFaces () const
int NbNodes () const
int NbEdges () const
virtual SMDSAbs_ElementType GetType () const
virtual SMDSAbs_EntityType GetEntityType () const
virtual SMDSAbs_GeometryType GetGeomType () const
virtual bool IsPoly () const
virtual bool IsQuadratic () const
virtual const SMDS_MeshNode * GetNode (const int ind) const
 Return node by its index. More...
virtual int NbCornerNodes () const
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual SMDS_ElemIteratorPtr nodesIterator () const
virtual SMDS_NodeIteratorPtr nodeIterator () const
virtual smIdType GetID () const
 Return ID of an element. More...
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
virtual VTKCellType GetVtkType () const
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
virtual bool IsMediumNode (const SMDS_MeshNode *node) const
 Check if a node is a medium node of a quadratic cell. More...
const SMDS_MeshNode * GetNodeWrap (const int ind) const
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
Protected Types
enum  Bits { BIT_IS_MARKED = 1 , BITS_SHIFT = 1 }
virtual void setID (const smIdType id)
virtual void setShapeID (const int shapeID)
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
const SMDS_MeshNode ** myNodes
int myNbNodes
smIdType myID
int myShapeID
SMDS_ElementChunk * myHolder
◆ iterator
◆ Bits
enum SMDS_CellOfNodes::Bits
BIT_IS_MARKED
BITS_SHIFT
◆ SMDS_VolumeOfNodes() [1/4]
SMDS_VolumeOfNodes::SMDS_VolumeOfNodes ( const SMDS_MeshNode *  node1,
const SMDS_MeshNode *  node2,
const SMDS_MeshNode *  node3,
const SMDS_MeshNode *  node4
References myNbNodes, and myNodes.
◆ SMDS_VolumeOfNodes() [2/4]
const SMDS_MeshNode *  node4,
const SMDS_MeshNode *  node5
◆ SMDS_VolumeOfNodes() [3/4]
const SMDS_MeshNode *  node5,
const SMDS_MeshNode *  node6
◆ SMDS_VolumeOfNodes() [4/4]
const SMDS_MeshNode *  node6,
const SMDS_MeshNode *  node7,
const SMDS_MeshNode *  node8
node 1,2,3,4 and 5,6,7,8 are quadrangle and 5,1 and 7,3 are an edges.
◆ ~SMDS_VolumeOfNodes()
SMDS_VolumeOfNodes::~SMDS_VolumeOfNodes ( )
References myNodes.
◆ begin_nodes()
◆ ChangeNodes()
bool SMDS_VolumeOfNodes::ChangeNodes ( const SMDS_MeshNode *  nodes[],
const int  nbNodes
◆ end_nodes()
◆ GetEntityType()
SMDSAbs_EntityType SMDS_VolumeOfNodes::GetEntityType ( ) const
◆ GetGeomType()
SMDSAbs_GeometryType SMDS_VolumeOfNodes::GetGeomType ( ) const
◆ getGrid()
◆ GetID()
smIdType SMDS_CellOfNodes::GetID ( ) const
Reimplemented from SMDS_MeshElement.
References SMDS_CellOfNodes::myID.
Referenced by SMDS_FaceOfNodes::Print(), SMDS_PolygonalFaceOfNodes::Print(), and Print().
◆ GetMesh()
◆ GetNode()
const SMDS_MeshNode * SMDS_VolumeOfNodes::GetNode ( const int  ind) const
ind- node index
constSMDS_MeshNode* - the node
Implements SMDS_MeshElement.
References myNodes.
◆ GetNodeIndex()
int SMDS_VolumeOfNodes::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ GetShapeID()
int SMDS_CellOfNodes::GetShapeID ( ) const
References SMDS_CellOfNodes::BITS_SHIFT, and SMDS_CellOfNodes::myShapeID.
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetType()
SMDSAbs_ElementType SMDS_VolumeOfNodes::GetType ( ) const
References SMDSAbs_Volume.
◆ GetVtkID()
vtkIdType SMDS_MeshElement::GetVtkID ( ) const
References SMDS_ElementChunk::GetVtkID(), and SMDS_MeshElement::myHolder.
Referenced by SMDS_MeshNode::AddInverseElement(), SMDS_ElementHolder::beforeCompacting(), SMDS_MeshCell::ChangeNodes(), SMDS_MeshVolume::ChangeNodes(), SMDS_MeshNode::ClearInverseElements(), SMDS_ElementFactory::Compact(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_ElementFactory::Free(), SMDS_MeshNode::getCoord(), SMDS_BallElement::GetDiameter(), SMESH_VisualObjDef::GetElemVTKId(), SMESHGUI_PreVisualObj::GetElemVTKId(), SMDS_MeshVolume::GetFaceNode(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshCell::GetNode(), SMDS_MeshVolume::GetNode(), SMDS_MeshCell::GetNodeIndex(), SMDS_MeshVolume::GetNodeIndex(), SMESH_VisualObjDef::GetNodeVTKId(), SMDS_MeshVolume::GetQuantities(), SMESH::Controls::AspectRatio3D::GetValue(), SMDS_MeshCell::GetVtkType(), SMDS_MeshNode::GetXYZ(), SMDS_BallElement::init(), SMDS_MeshNode::init(), SMDS_MeshCell::init(), SMDS_MeshVolume::NbEdges(), SMDS_MeshVolume::NbFaceNodes(), SMDS_MeshVolume::NbFaces(), SMDS_MeshNode::NbInverseElements(), SMDS_MeshCell::NbNodes(), SMDS_MeshVolume::NbNodes(), SMDS_MeshCell::nodeIterator(), SMDS_MeshVolume::nodeIterator(), SMDS_MeshCell::nodesIterator(), SMDS_MeshVolume::nodesIterator(), SMDS_MeshCell::nodesIteratorToUNV(), SMDS_Mesh::RemoveFreeElement(), SMDS_MeshNode::RemoveInverseElement(), SMDS_BallElement::SetDiameter(), and SMDS_MeshNode::setXYZ().
◆ GetVtkType()
virtual VTKCellType SMDS_CellOfNodes::GetVtkType ( ) const
◆ interlacedNodesIterator()
◆ isMarked()
bool SMDS_CellOfNodes::isMarked ( ) const
References SMDS_CellOfNodes::BIT_IS_MARKED, and SMDS_CellOfNodes::myShapeID.
◆ IsMediumNode()
◆ IsNull()
◆ IsPoly()
virtual bool SMDS_VolumeOfNodes::IsPoly ( ) const
◆ IsQuadratic()
virtual bool SMDS_VolumeOfNodes::IsQuadratic ( ) const
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ NbCornerNodes()
virtual int SMDS_VolumeOfNodes::NbCornerNodes ( ) const
◆ NbEdges()
int SMDS_VolumeOfNodes::NbEdges ( ) const
References MESSAGE, and NbNodes().
◆ NbFaces()
int SMDS_VolumeOfNodes::NbFaces ( ) const
◆ NbNodes()
int SMDS_VolumeOfNodes::NbNodes ( ) const
References myNbNodes.
Referenced by NbEdges(), NbFaces(), nodeIterator(), nodesIterator(), and Print().
◆ nodeIterator()
SMDS_NodeIteratorPtr SMDS_VolumeOfNodes::nodeIterator ( ) const
References myNodes, and NbNodes().
◆ nodesIterator()
SMDS_ElemIteratorPtr SMDS_VolumeOfNodes::nodesIterator ( ) const
◆ nodesIteratorToUNV()
virtual SMDS_NodeIteratorPtr SMDS_MeshElement::nodesIteratorToUNV ( ) const
Reimplemented in SMDS_MeshCell.
◆ Print()
void SMDS_VolumeOfNodes::Print ( std::ostream &  OS) const
overridevirtual
Print self.
References SMDS_CellOfNodes::GetID(), myNodes, and NbNodes().
◆ setID()
void SMDS_CellOfNodes::setID ( const smIdType  id)
◆ setIsMarked()
void SMDS_CellOfNodes::setIsMarked ( bool  is) const
Mark this element.
◆ setShapeID() [1/2]
void SMDS_CellOfNodes::setShapeID ( const int  shapeID)
◆ setShapeID() [2/2]
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ myHolder
◆ myID
smIdType SMDS_CellOfNodes::myID
◆ myNbNodes
int SMDS_VolumeOfNodes::myNbNodes
◆ myNodes
◆ myShapeID
