SMESH_Delaunay Class Referenceabstract
Create a Delaunay triangulation of nodes on a face boundary and provide exploration of nodes shared by elements lying on the face. More...
#include <SMESH_Delaunay.hxx>
Inheritance diagram for SMESH_Delaunay:
 SMESH_Delaunay (const std::vector< const UVPtStructVec * > &boundaryNodes, const TopoDS_Face &face, const int faceID)
 Construct a Delaunay triangulation of given boundary nodes. More...
virtual ~SMESH_Delaunay ()
void InitTraversal (const int nbNodesToVisit=-1)
 Prepare to the exploration of nodes. More...
const SMDS_MeshNode * NextNode (double bc[3], int triaNodes[3])
 Return a node with its Barycentric Coordinates within the triangle defined by its node indices (zero based) More...
size_t NbVisitedNodes () const
const BRepMesh_Triangle * FindTriangle (const gp_XY &uv, const BRepMesh_Triangle *bmTria, double bc[3], int triaNodes[3])
 Find a Delaunay triangle containing a given 2D point and return barycentric coordinates within the found triangle. More...
const BRepMesh_Triangle * GetTriangleNear (int iBndNode)
 Return a triangle sharing a given boundary node. More...
const std::vector< const SMDS_MeshNode * > & GetBndNodes () const
gp_XY GetBndUV (const int iNode) const
 Return UV of the i-th source boundary node (zero based) More...
const gp_XY & GetScale () const
void ToPython () const
 Write a python script that creates an equal mesh in Mesh module. More...
 Handle (BRepMesh_DataStructureOfDelaun) GetDS()
Protected Types
typedef std::list< std::pair< const SMDS_MeshNode *, const BRepMesh_Triangle * > > TNodeTriaList
virtual gp_XY getNodeUV (const TopoDS_Face &face, const SMDS_MeshNode *node) const =0
 Handle (BRepMesh_DataStructureOfDelaun) _triaDS
static void addCloseNodes (const SMDS_MeshNode *node, const BRepMesh_Triangle *bmTria, const int faceID, TNodeTriaList &noTriQueue)
 Add non-marked nodes surrounding a given one to a queue. More...
const TopoDS_Face & _face
int _faceID
std::vector< const SMDS_MeshNode * > _bndNodes
gp_XY _scale
size_t _nbNodesToVisit
size_t _nbVisitedNodes
size_t _iBndNode
TNodeTriaList _noTriQueue
For a returned node, also return a Delaunay triangle the node lies in and its Barycentric Coordinates within the triangle. Only non-marked nodes are visited. Boundary nodes given at the construction are not returned.
For usage, this class needs to be subclassed to implement getNodeUV();
◆ TNodeTriaList
typedef std::list< std::pair< const SMDS_MeshNode*, const BRepMesh_Triangle* > > SMESH_Delaunay::TNodeTriaList
◆ SMESH_Delaunay()
SMESH_Delaunay::SMESH_Delaunay ( const std::vector< const UVPtStructVec * > &  boundaryNodes,
const TopoDS_Face &  face,
const int  faceID
[in]boundaryNodes- vector of nodes of a wire
[in]face- the face
[in]faceID- the face ID
References _bndNodes, and _scale.
◆ ~SMESH_Delaunay()
virtual SMESH_Delaunay::~SMESH_Delaunay ( )
◆ addCloseNodes()
void SMESH_Delaunay::addCloseNodes ( const SMDS_MeshNode *  node,
const BRepMesh_Triangle *  bmTria,
const int  faceID,
TNodeTriaList &  noTriQueue
staticprotected
◆ FindTriangle()
const BRepMesh_Triangle * SMESH_Delaunay::FindTriangle ( const gp_XY &  uv,
double  bc[3],
int  triaNodes[3]
References _scale, and SMESH_MeshAlgos::GetBarycentricCoords().
Referenced by NextNode().
◆ GetBndNodes()
const std::vector< const SMDS_MeshNode * > & SMESH_Delaunay::GetBndNodes ( ) const
◆ GetBndUV()
gp_XY SMESH_Delaunay::GetBndUV ( const int  iNode) const
◆ getNodeUV()
virtual gp_XY SMESH_Delaunay::getNodeUV ( const TopoDS_Face &  face,
protectedpure virtual
Implemented in StdMeshers_ProjectionUtils::Delaunay.
◆ GetScale()
const gp_XY & SMESH_Delaunay::GetScale ( ) const
◆ GetTriangleNear()
const BRepMesh_Triangle * SMESH_Delaunay::GetTriangleNear ( int  iBndNode)
[in]iBndNode- index of the boundary node
const BRepMesh_Triangle* - a found triangle
References _bndNodes.
◆ Handle() [1/2]
SMESH_Delaunay::Handle ( BRepMesh_DataStructureOfDelaun  )
◆ Handle() [2/2]
◆ InitTraversal()
void SMESH_Delaunay::InitTraversal ( const int  nbNodesToVisit = -1)
References _iBndNode, _nbNodesToVisit, _nbVisitedNodes, and _noTriQueue.
Referenced by StdMeshers_ProjectionUtils::Morph::Perform().
◆ NbVisitedNodes()
size_t SMESH_Delaunay::NbVisitedNodes ( ) const
◆ NextNode()
const SMDS_MeshNode * SMESH_Delaunay::NextNode ( double  bc[3],
int  triaNodes[3]
[out]bc- Barycentric Coordinates of the returned node
[out]triaNodes- indices of triangle nodes
const SMDS_MeshNode* - the next node or NULL
References _bndNodes, _face, _faceID, _iBndNode, _nbNodesToVisit, _nbVisitedNodes, _noTriQueue, addCloseNodes(), FindTriangle(), getNodeUV(), GetTriangleNear(), SMDS_MeshElement::isMarked(), and SMDS_MeshElement::setIsMarked().
◆ ToPython()
void SMESH_Delaunay::ToPython ( ) const
References SMESH_File::openForWriting(), SMESH_File::remove(), and SMESH_File::write().
◆ _bndNodes
std::vector< const SMDS_MeshNode* > SMESH_Delaunay::_bndNodes
◆ _face
const TopoDS_Face& SMESH_Delaunay::_face
◆ _faceID
int SMESH_Delaunay::_faceID
◆ _iBndNode
size_t SMESH_Delaunay::_iBndNode
Referenced by InitTraversal(), and NextNode().
◆ _nbNodesToVisit
size_t SMESH_Delaunay::_nbNodesToVisit
◆ _nbVisitedNodes
size_t SMESH_Delaunay::_nbVisitedNodes
◆ _noTriQueue
TNodeTriaList SMESH_Delaunay::_noTriQueue
◆ _scale
gp_XY SMESH_Delaunay::_scale
Referenced by FindTriangle(), and SMESH_Delaunay().
