High level util for effective file reading and other file operations. More...
#include <SMESH_File.hxx>
| SMESH_File (const std::string &name, bool openForReading=true) | |
| Creator opening the file for reading by default. More... | |
| ~SMESH_File () | |
| Destructor closing the file. More... | |
| std::string | getName () const |
| const std::string & | error () const |
| void | close () |
| Close the file. More... | |
| bool | remove () |
| Remove the file. More... | |
| long | size () |
| Return file size. More... | |
| bool | exists () |
| Check existence. More... | |
| bool | isDirectory () |
| bool | open () |
| Open file for reading. More... | |
| operator const char * () const | |
| bool | operator++ () |
| void | operator+= (int posDelta) |
| bool | eof () const |
| const char * | end () const |
| const char * | getPos () const |
| void | setPos (const char *pos) |
| Set cursor to the given position. More... | |
| std::string | getLine () |
| Skip till current line end and return the skipped string. More... | |
| void | rewind () |
| Move cursor to the file beginning. More... | |
| bool | getInts (std::vector< int > &ids) |
| Fill vector by reading out integers from file. More... | |
| bool | openForWriting () |
| Open for binary writing only. More... | |
| template<typename T > | |
| bool | write (const T *values, size_t nbTValues) |
| bool | write (const T &value) |
| bool | writeRaw (const void *data, size_t size) |
| Write binary data. More... | |
Private Attributes | |
| std::string | _name |
| file name More... | |
| long | _size |
| file size More... | |
| std::string | _error |
| int | _file |
| void * | _map |
| const char * | _pos |
| current position More... | |
| const char * | _end |
| position after file end More... | |
| SMESH_File::SMESH_File | ( | const std::string & | name, |
| bool | openForReading = true |
References open().
| SMESH_File::~SMESH_File | ( | ) |
References close().
| void SMESH_File::close | ( | ) |
Close the file.
References _end, _file, _map, _pos, _size, and close().
Referenced by close(), open(), openForWriting(), DriverSTL_R_SMDS_Mesh::readAscii(), remove(), and ~SMESH_File().
| const char * SMESH_File::end | ( | ) | const |
Referenced by DriverSTL_R_SMDS_Mesh::Perform().
| const std::string & SMESH_File::error | ( | ) | const |
| bool SMESH_File::exists | ( | ) |
Check existence.
References _error, _name, and MED::exists().
Referenced by SMESHHOMARD_I::HOMARD_Gen_i::CreateCaseOnMesh(), SMESHHOMARD_I::HOMARD_Gen_i::DeleteCase(), and SMESH_Mesh_i::PrepareForWriting().
| bool SMESH_File::getInts | ( | std::vector< int > & | ints | ) |
| std::string SMESH_File::getLine | ( | ) |
| std::string SMESH_File::getName | ( | ) | const |
Referenced by SMESH_Mesh_i::PrepareForWriting().
| const char * SMESH_File::getPos | ( | ) | const |
| bool SMESH_File::isDirectory | ( | ) |
| bool SMESH_File::open | ( | ) |
Return true if there is something to read
References _end, _error, _file, _map, _name, _pos, _size, close(), open(), and size().
Referenced by open(), openForWriting(), DriverSTL_R_SMDS_Mesh::Perform(), and SMESH_File().
| bool SMESH_File::openForWriting | ( | ) |
References _file, _name, close(), and open().
Referenced by SMESH_Mesh_i::PrepareForWriting(), SMESH_Delaunay::ToPython(), DriverSTL_W_SMDS_Mesh::writeAscii(), and DriverSTL_W_SMDS_Mesh::writeBinary().
| SMESH_File::operator const char * | ( | ) | const |
| bool SMESH_File::operator++ | ( | ) |
| void SMESH_File::operator+= | ( | int | posDelta | ) |
| bool SMESH_File::remove | ( | ) |
Remove the file.
References _error, _name, and close().
Referenced by SMESHHOMARD_I::HOMARD_Gen_i::Compute(), SMESHHOMARD_I::HOMARD_Gen_i::DeleteCase(), SMESH_Mesh_i::PrepareForWriting(), and SMESH_Delaunay::ToPython().
| void SMESH_File::setPos | ( | const char * | pos | ) |
| long SMESH_File::size | ( | ) |
Return file size.
References _error, _name, _size, and size().
Referenced by SMESH_Mesh_i::ImportCGNSFile(), SMESH_Mesh_i::ImportGMFFile(), SMESH_Mesh_i::ImportMEDFile(), SMESH_Mesh_i::ImportSTLFile(), SMESH_Mesh_i::ImportUNVFile(), open(), DriverSTL_R_SMDS_Mesh::readAscii(), DriverSTL_R_SMDS_Mesh::readBinary(), size(), and writeRaw().
| bool SMESH_File::write | ( | const T & | value | ) |
Referenced by SMESH_Delaunay::ToPython(), DriverSTL_W_SMDS_Mesh::writeBinary(), writeFloat(), writeInteger(), and writeRaw().
Write binary data.
References _file, size(), and write().
Referenced by DriverSTL_W_SMDS_Mesh::writeAscii(), and DriverSTL_W_SMDS_Mesh::writeBinary().
private |
private |
Referenced by exists(), isDirectory(), open(), remove(), and size().
private |
Referenced by close(), open(), openForWriting(), and writeRaw().
private |
file name
Referenced by exists(), isDirectory(), open(), openForWriting(), remove(), and size().
private |
