SMESH_subMesh_i Class Reference
#include <SMESH_subMesh_i.hxx>
Inheritance diagram for SMESH_subMesh_i:
 SMESH_subMesh_i ()
 SMESH_subMesh_i (PortableServer::POA_ptr thePOA, SMESH_Gen_i *gen_i, SMESH_Mesh_i *mesh_i, int localId)
 ~SMESH_subMesh_i ()
SMESH::smIdType GetNumberOfElements ()
SMESH::smIdType GetNumberOfNodes (CORBA::Boolean all)
SMESH::smIdType_array * GetElementsId ()
SMESH::smIdType_array * GetElementsByType (SMESH::ElementType theElemType)
SMESH::ElementType GetElementType (SMESH::smIdType id, bool iselem)
SMESH::smIdType_array * GetNodesId ()
SMESH::SMESH_Mesh_ptr GetFather ()
GEOM::GEOM_Object_ptr GetSubShape ()
CORBA::Long GetId ()
virtual SMESH::smIdType_array * GetIDs ()
virtual SMESH::smIdType_array * GetMeshInfo ()
 Returns number of mesh elements of each EntityType Result array of number of elements per EntityType Inherited from SMESH_IDSource. More...
virtual SMESH::smIdType_array * GetNbElementsByType ()
virtual SMESH::array_of_ElementType * GetTypes ()
virtual SMESH::SMESH_Mesh_ptr GetMesh ()
 Returns the mesh. More...
virtual bool IsMeshInfoCorrect ()
virtual SALOMEDS::TMPFile * GetVtkUgStream ()
void changeLocalId (int localId)
SMESH_PreMeshInfo *& changePreMeshInfo ()
SMESH_Gen_i * _gen_i
int _localId
SMESH_Mesh_i * _mesh_i
SMESH_PreMeshInfo * _preMeshInfo
Friends
class SMESH_PreMeshInfo
void SMESH_Mesh_i::CheckGeomGroupModif ()
void SMESH_Mesh_i::CheckGeomModif (bool)
◆ SMESH_subMesh_i() [1/2]
SMESH_subMesh_i::SMESH_subMesh_i ( )
References MESSAGE.
◆ SMESH_subMesh_i() [2/2]
SMESH_subMesh_i::SMESH_subMesh_i ( PortableServer::POA_ptr  thePOA,
SMESH_Gen_i *  gen_i,
SMESH_Mesh_i *  mesh_i,
int  localId
References _gen_i, _localId, _mesh_i, and _preMeshInfo.
◆ ~SMESH_subMesh_i()
SMESH_subMesh_i::~SMESH_subMesh_i ( )
References _preMeshInfo.
◆ changeLocalId()
void SMESH_subMesh_i::changeLocalId ( int  localId)
◆ changePreMeshInfo()
SMESH_PreMeshInfo *& SMESH_subMesh_i::changePreMeshInfo ( )
◆ GetElementsByType()
◆ GetElementsId()
◆ GetElementType()
SMESH::ElementType SMESH_subMesh_i::GetElementType ( SMESH::smIdType  id,
bool  iselem
◆ GetFather()
SMESH::SMESH_Mesh_ptr SMESH_subMesh_i::GetFather ( )
References _mesh_i.
Referenced by GetElementType(), and GetMesh().
◆ GetId()
CORBA::Long SMESH_subMesh_i::GetId ( )
References _localId.
◆ GetIDs()
SMESH::smIdType_array * SMESH_subMesh_i::GetIDs ( )
References GetElementsId().
◆ GetMesh()
SMESH::SMESH_Mesh_ptr SMESH_subMesh_i::GetMesh ( )
Returns the mesh.
References GetFather().
◆ GetMeshInfo()
SMESH::smIdType_array * SMESH_subMesh_i::GetMeshInfo ( )
References _localId, SMESH_Mesh_i::_mapSubMesh, _mesh_i, _preMeshInfo, SMESH_Mesh_i::CollectMeshInfo(), SMESH::Entity_Last, SMESH::Entity_Node, SMESH_PreMeshInfo::GetMeshInfo(), GetNumberOfNodes(), and getSubMeshes().
◆ GetNbElementsByType()
SMESH::smIdType_array * SMESH_subMesh_i::GetNbElementsByType ( )
◆ GetNodesId()
SMESH::smIdType_array * SMESH_subMesh_i::GetNodesId ( )
References GetElementsByType(), and SMESH::NODE.
◆ GetNumberOfElements()
SMESH::smIdType SMESH_subMesh_i::GetNumberOfElements ( )
◆ GetNumberOfNodes()
◆ GetSubShape()
GEOM::GEOM_Object_ptr SMESH_subMesh_i::GetSubShape ( )
◆ GetTypes()
SMESH::array_of_ElementType * SMESH_subMesh_i::GetTypes ( )
◆ GetVtkUgStream()
SALOMEDS::TMPFile * SMESH_subMesh_i::GetVtkUgStream ( )
◆ IsMeshInfoCorrect()
bool SMESH_subMesh_i::IsMeshInfoCorrect ( )
References _preMeshInfo, and SMESH_PreMeshInfo::IsMeshInfoCorrect().
◆ SMESH_Mesh_i::CheckGeomGroupModif
◆ SMESH_Mesh_i::CheckGeomModif
◆ SMESH_PreMeshInfo
friend class SMESH_PreMeshInfo
friend
◆ _gen_i
SMESH_Gen_i* SMESH_subMesh_i::_gen_i
Referenced by GetSubShape(), and SMESH_subMesh_i().
◆ _localId
◆ _mesh_i
◆ _preMeshInfo
