SMESH_subMesh_i.hxx
24// File : SMESH_subMesh_i.hxx
25// Author : Paul RASCLE, EDF
26// Module : SMESH
27//
28#ifndef _SMESH_SUBMESH_I_HXX_
29#define _SMESH_SUBMESH_I_HXX_
30
31#include "SMESH.hxx"
32
33#include <SALOMEconfig.h>
34#include CORBA_SERVER_HEADER(SMESH_Mesh)
35#include CORBA_SERVER_HEADER(SMESH_Hypothesis)
36#include CORBA_CLIENT_HEADER(GEOM_Gen)
37
38#include "SALOME_GenericObj_i.hh"
39#include "SMESH_Mesh_i.hxx"
40
41class SMESH_Gen_i;
43
45 public virtual POA_SMESH::SMESH_subMesh,
46 public virtual SALOME::GenericObj_i
47{
48public:
50 SMESH_subMesh_i( PortableServer::POA_ptr thePOA,
51 SMESH_Gen_i* gen_i,
52 SMESH_Mesh_i* mesh_i,
53 int localId );
55
56 SMESH::smIdType GetNumberOfElements();
57
58 SMESH::smIdType GetNumberOfNodes( CORBA::Boolean all );
59
60 SMESH::smIdType_array* GetElementsId();
61
62 SMESH::smIdType_array* GetElementsByType( SMESH::ElementType theElemType );
63
64 SMESH::ElementType GetElementType( SMESH::smIdType id, bool iselem );
65
66 SMESH::smIdType_array* GetNodesId();
67
68 SMESH::SMESH_Mesh_ptr GetFather();
69
70 GEOM::GEOM_Object_ptr GetSubShape();
71
72 CORBA::Long GetId();
73
74
75 // =========================
76 // interface SMESH_IDSource
77 // =========================
81 virtual SMESH::smIdType_array* GetIDs();
87 virtual SMESH::smIdType_array* GetMeshInfo();
91 virtual SMESH::smIdType_array* GetNbElementsByType();
95 virtual SMESH::array_of_ElementType* GetTypes();
99 virtual SMESH::SMESH_Mesh_ptr GetMesh();
104 virtual bool IsMeshInfoCorrect();
108 virtual SALOMEDS::TMPFile* GetVtkUgStream();
109
110protected:
111
115
116 void changeLocalId(int localId) { _localId = localId; }
119
120 SMESH_PreMeshInfo* _preMeshInfo; // mesh info before full loading from study file
121
122 SMESH_PreMeshInfo* & changePreMeshInfo() { return _preMeshInfo; }
123 friend class SMESH_PreMeshInfo;
124};
125
126
128 public virtual POA_SMESH::SMESH_subMesh,
129 public virtual SALOME::GenericObj_i,
130 public virtual SMESH_subMesh_i
131{
132 public:
133 SMESH_Invalid_subMesh_i( PortableServer::POA_ptr thePOA,
134 SMESH_Gen_i* gen_i,
135 SMESH_Mesh_i* mesh_i,
136 int localId,
137 GEOM::GEOM_Object_ptr shape);
138
139 virtual GEOM::GEOM_Object_ptr GetSubShape();
140
141 protected:
142
143 GEOM::GEOM_Object_var _geom;
144
145};
146
147#endif
#define SMESH_I_EXPORT
Definition: SMESH.hxx:39
Definition: SMESH_Gen_i.hxx:99
Definition: SMESH_subMesh_i.hxx:131
Definition: SMESH_subMesh_i.hxx:143
Definition: SMESH_Mesh_i.hxx:57
void CheckGeomGroupModif()
Update hypotheses assigned to geom groups if the latter change.
Definition: SMESH_Mesh_i.cxx:2746
void CheckGeomModif(bool isBreakLink=false)
Update data if geometry changes.
Definition: SMESH_Mesh_i.cxx:2393
Class loading and holding information of a mesh object (mesh, group, submesh) not yet loaded from HDF...
Definition: SMESH_PreMeshInfo.hxx:54
Definition: SMESH_subMesh_i.hxx:47
SMESH_Gen_i * _gen_i
Definition: SMESH_subMesh_i.hxx:112
SMESH_Mesh_i * _mesh_i
Definition: SMESH_subMesh_i.hxx:114
SMESH_PreMeshInfo *& changePreMeshInfo()
Definition: SMESH_subMesh_i.hxx:122
Definition: SMESH_subMesh_i.hxx:116
SMESH_PreMeshInfo * _preMeshInfo
Definition: SMESH_subMesh_i.hxx:120
int _localId
Definition: SMESH_subMesh_i.hxx:113
sequence< ElementType > array_of_ElementType
Definition: SMESH_Mesh.idl:138
sequence< smIdType > smIdType_array
Definition: SMESH_Mesh.idl:45
ElementType
Enumeration for element type, like in SMDS.
Definition: SMESH_Mesh.idl:128
GEOM::GEOM_Object_ptr GetSubShape(GEOM::GEOM_Object_ptr theMainShape, long theID)
Definition: SMESHGUI_GEOMGenUtils.cxx:156
