StdMeshers_Adaptive1D Class Reference
Adaptive 1D hypothesis. More...
#include <StdMeshers_Adaptive1D.hxx>
Inheritance diagram for StdMeshers_Adaptive1D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_Adaptive1D (int hypId, SMESH_Gen *gen)
 ~StdMeshers_Adaptive1D ()
void SetMinSize (double minSegLen)
 Sets minimal allowed segment length. More...
double GetMinSize () const
void SetMaxSize (double maxSegLen)
 Sets maximal allowed segment length. More...
double GetMaxSize () const
void SetDeflection (double value)
 Sets <deflection> parameter value, i.e. More...
double GetDeflection () const
 Initialize deflection value by the mesh built on the geometry. More...
SMESH_Algo * GetAlgo () const
 Returns an algorithm that works using this hypothesis. More...
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
double myMinSize
double myMaxSize
double myDeflection
SMESH_Algo * myAlgo
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_Adaptive1D()
StdMeshers_Adaptive1D::StdMeshers_Adaptive1D ( int  hypId,
SMESH_Gen *  gen
◆ ~StdMeshers_Adaptive1D()
StdMeshers_Adaptive1D::~StdMeshers_Adaptive1D ( )
References myAlgo.
◆ DataDependOnParams()
◆ GetAlgo()
SMESH_Algo * StdMeshers_Adaptive1D::GetAlgo ( ) const
References SMESH_Hypothesis::_gen, SMESH_Gen::GetANewId(), and myAlgo.
◆ GetDeflection()
double StdMeshers_Adaptive1D::GetDeflection ( ) const
◆ GetDim()
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMaxSize()
double StdMeshers_Adaptive1D::GetMaxSize ( ) const
◆ GetMeshByPersistentID()
◆ GetMinSize()
double StdMeshers_Adaptive1D::GetMinSize ( ) const
◆ GetName()
◆ GetShapeType()
◆ GetType()
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsStatusFatal()
◆ LoadFrom()
istream & StdMeshers_Adaptive1D::LoadFrom ( std::istream &  load)
References myDeflection, myMaxSize, and myMinSize.
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
ostream & StdMeshers_Adaptive1D::SaveTo ( std::ostream &  save)
◆ SetDeflection()
void StdMeshers_Adaptive1D::SetDeflection ( double  value)
a maximal allowed distance between a segment and an edge.
References myDeflection, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_Adaptive1D_i::SetDeflection().
◆ SetLibName()
◆ SetMaxSize()
void StdMeshers_Adaptive1D::SetMaxSize ( double  maxSegLen)
References myMaxSize, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_Adaptive1D_i::SetMaxSize().
◆ SetMinSize()
void StdMeshers_Adaptive1D::SetMinSize ( double  minSegLen)
References myMinSize, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_Adaptive1D_i::SetMinSize().
◆ SetParametersByDefaults()
bool StdMeshers_Adaptive1D::SetParametersByDefaults ( const TDefaults &  dflts,
Implements SMESH_Hypothesis.
References SMESH_Hypothesis::TDefaults::_elemLength, myDeflection, myMaxSize, and myMinSize.
◆ SetParametersByMesh()
bool StdMeshers_Adaptive1D::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
theMesh- the built mesh
References Edge, SMESHDS_SubMesh::GetElements(), SMESH_Mesh::GetMeshDS(), SMDS_MeshElement::GetNode(), SMESH_MesherHelper::GetNodeU(), SMESHDS_Mesh::MeshElements(), myDeflection, myMaxSize, myMinSize, SMESH_MesherHelper::SetSubShape(), and SMESH_TNodeXYZ::SquareDistance().
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _shapeType
◆ _type
◆ myAlgo
SMESH_Algo* StdMeshers_Adaptive1D::myAlgo
◆ myDeflection
double StdMeshers_Adaptive1D::myDeflection
◆ myMaxSize
double StdMeshers_Adaptive1D::myMaxSize
◆ myMinSize
double StdMeshers_Adaptive1D::myMinSize
