StdMeshers_NumberOfSegments Class Reference
This class represents hypothesis for 1d algorithm. More...
#include <StdMeshers_NumberOfSegments.hxx>
Inheritance diagram for StdMeshers_NumberOfSegments:
enum  DistrType {
  DT_Regular , DT_Scale , DT_TabFunc , DT_ExprFunc ,
  DT_BetaLaw
 This enumeration presents available types of distribution. More...
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_NumberOfSegments (int hypId, SMESH_Gen *gen)
virtual ~StdMeshers_NumberOfSegments ()
const std::vector< double > & BuildDistributionExpr (const char *, int, int)
const std::vector< double > & BuildDistributionTab (const std::vector< double > &, int, int)
void SetNumberOfSegments (smIdType segmentsNumber)
 Set the number of segments. More...
smIdType GetNumberOfSegments () const
 Get the number of segments. More...
void SetDistrType (DistrType typ)
 Set distribution type. More...
DistrType GetDistrType () const
 Get distribution type. More...
bool IsValidDistrType (int distrType) const
 Check if a given int falls into distribution type scope. More...
virtual void SetScaleFactor (double scaleFactor)
 Set scale factor for scale distribution. More...
double GetScaleFactor () const
 Get scale factor for scale distribution. More...
virtual void SetBeta (double scaleFactor)
 Set beta coefficient for Beta Law distribution. More...
double GetBeta () const
 Get beta coefficient for Beta Law distribution. More...
void SetTableFunction (const std::vector< double > &table)
 Set table function for distribution DT_TabFunc. More...
const std::vector< double > & GetTableFunction () const
 Get table function for distribution DT_TabFunc. More...
void SetExpressionFunction (const char *expr)
 Set expression function for distribution DT_ExprFunc. More...
const char * GetExpressionFunction () const
 Get expression function for distribution DT_ExprFunc. More...
void SetConversionMode (int conv)
 Set conversion mode. More...
int ConversionMode () const
 Returns conversion mode. More...
 Initialize number of segments by the mesh built on the geometry. More...
void SetReversedEdges (const std::vector< int > &ids)
void SetObjectEntry (const char *entry)
const char * GetObjectEntry () const
const std::vector< int > & GetReversedEdges () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static std::string CheckExpressionFunction (const std::string &expr, const int convMode)
 Checks validity of the expression of the function f(t), e.g. More...
smIdType _numberOfSegments
 an edge will be split on to this number of segments More...
DistrType _distrType
 the type of distribution of density function More...
double _scaleFactor
 the scale parameter for DT_Scale More...
double _beta
 beta coefficient for DT_BetaLaw More...
std::vector< double > _table
std::vector< double > _distr
 the table for DT_TabFunc, a sequence of pairs of numbers More...
std::string _func
 the expression of the function for DT_ExprFunc More...
int _convMode
 flag of conversion mode: 0=exponent, 1=cut negative More...
std::vector< int > _edgeIDs
std::string _objEntry
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
Friends
std::ostream & operator<< (std::ostream &save, StdMeshers_NumberOfSegments &hyp)
std::istream & operator>> (std::istream &load, StdMeshers_NumberOfSegments &hyp)
It provides parameters for subdivision an edge by various distribution types, considering the given number of resulting segments
◆ DistrType
DT_Regular
equidistant distribution
DT_Scale
scale distribution
DT_TabFunc
distribution with density function presented by table
DT_ExprFunc
distribution with density function presented by expression
DT_BetaLaw
distribution with Beta Law using parameter beta (expansion coefficient)
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_NumberOfSegments()
StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments ( int  hypId,
SMESH_Gen *  gen
◆ ~StdMeshers_NumberOfSegments()
StdMeshers_NumberOfSegments::~StdMeshers_NumberOfSegments ( )
◆ BuildDistributionExpr()
const std::vector< double > & StdMeshers_NumberOfSegments::BuildDistributionExpr ( const char *  ,
int  ,
int
◆ BuildDistributionTab()
const std::vector< double > & StdMeshers_NumberOfSegments::BuildDistributionTab ( const std::vector< double > &  ,
int  ,
int
◆ CheckExpressionFunction()
std::string StdMeshers_NumberOfSegments::CheckExpressionFunction ( const std::string &  expr,
const int  convMode
"sin(t)". In case of validity returns a cleaned expression
convMode- 0 for "Exponent mode", 1 for "Cut negative mode"
References process().
◆ ConversionMode()
int StdMeshers_NumberOfSegments::ConversionMode ( ) const
Throws SALOME_Exception if distribution type is not functional
Referenced by StdMeshers_NumberOfSegments_i::ConversionMode().
◆ DataDependOnParams()
◆ GetBeta()
double StdMeshers_NumberOfSegments::GetBeta ( ) const
Throws SALOME_Exception if distribution type is not DT_BetaLaw
Referenced by StdMeshers_NumberOfSegments_i::GetBeta().
◆ GetDim()
◆ GetDistrType()
StdMeshers_NumberOfSegments::DistrType StdMeshers_NumberOfSegments::GetDistrType ( ) const
◆ GetExpressionFunction()
const char * StdMeshers_NumberOfSegments::GetExpressionFunction ( ) const
Throws SALOME_Exception if distribution type is not DT_ExprFunc
Referenced by StdMeshers_NumberOfSegments_i::GetExpressionFunction().
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetName()
◆ GetNumberOfSegments()
smIdType StdMeshers_NumberOfSegments::GetNumberOfSegments ( ) const
Referenced by StdMeshers_NumberOfSegments_i::GetNumberOfSegments().
◆ GetObjectEntry()
const char * StdMeshers_Reversible1D::GetObjectEntry ( ) const
◆ GetReversedEdges()
const std::vector< int > & StdMeshers_Reversible1D::GetReversedEdges ( ) const
◆ GetScaleFactor()
double StdMeshers_NumberOfSegments::GetScaleFactor ( ) const
Throws SALOME_Exception if distribution type is not DT_Scale
Referenced by StdMeshers_NumberOfSegments_i::GetScaleFactor().
◆ GetShapeType()
◆ GetTableFunction()
const vector< double > & StdMeshers_NumberOfSegments::GetTableFunction ( ) const
Throws SALOME_Exception if distribution type is not DT_TabFunc
Referenced by StdMeshers_NumberOfSegments_i::GetTableFunction().
◆ GetType()
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsStatusFatal()
◆ IsValidDistrType()
bool StdMeshers_NumberOfSegments::IsValidDistrType ( int  distrType) const
◆ LoadFrom()
istream & StdMeshers_NumberOfSegments::LoadFrom ( std::istream &  load)
Reimplemented from StdMeshers_Reversible1D.
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
ostream & StdMeshers_NumberOfSegments::SaveTo ( std::ostream &  save)
◆ SetBeta()
virtual void StdMeshers_NumberOfSegments::SetBeta ( double  scaleFactor)
beta- usually set between 1.01 (narrow mesh) and 1.00001 (very narrow mesh)
Referenced by StdMeshers_NumberOfSegments_i::SetBeta().
◆ SetConversionMode()
void StdMeshers_NumberOfSegments::SetConversionMode ( int  conv)
When it is 0, it means "exponent mode": the function of distribution of density is used as an exponent of 10, i,e, 10^f(t). When it is 1, it means "cut negative mode". The function of distribution is used as F(t), where F(t0)=f(t0), if f(t0)>=0, otherwise F(t0) = 0. This mode is sensible only when function distribution is used (DT_TabFunc or DT_ExprFunc)
Referenced by StdMeshers_NumberOfSegments_i::SetConversionMode().
◆ SetDistrType()
void StdMeshers_NumberOfSegments::SetDistrType ( DistrType  typ)
Referenced by StdMeshers_NumberOfSegments_i::SetDistrType().
◆ SetExpressionFunction()
void StdMeshers_NumberOfSegments::SetExpressionFunction ( const char *  expr)
expr- string containing the expression of the function f(t), e.g. "sin(t)"
Referenced by StdMeshers_NumberOfSegments_i::SetExpressionFunction().
◆ SetLibName()
◆ SetNumberOfSegments()
void StdMeshers_NumberOfSegments::SetNumberOfSegments ( smIdType  segmentsNumber)
segmentsNumber- must be greater than zero
Referenced by StdMeshers_NumberOfSegments_i::SetNumberOfSegments().
◆ SetObjectEntry()
void StdMeshers_Reversible1D::SetObjectEntry ( const char *  entry)
◆ SetParametersByDefaults()
bool StdMeshers_NumberOfSegments::SetParametersByDefaults ( const TDefaults &  dflts,
Implements SMESH_Hypothesis.
References SMESH_Hypothesis::TDefaults::_nbSegments.
◆ SetParametersByMesh()
bool StdMeshers_NumberOfSegments::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
theMesh- the built mesh
References SMESHDS_Mesh::MeshElements(), and SMESHDS_SubMesh::NbElements().
◆ SetReversedEdges()
void StdMeshers_Reversible1D::SetReversedEdges ( const std::vector< int > &  ids)
◆ SetScaleFactor()
void StdMeshers_NumberOfSegments::SetScaleFactor ( double  scaleFactor)
scaleFactor- positive value different from 1
Throws SALOME_Exception if distribution type is not DT_Scale, or scaleFactor is not a positive value different from 1
References PRECISION.
Referenced by StdMeshers_NumberOfSegments_i::SetScaleFactor().
◆ SetTableFunction()
void StdMeshers_NumberOfSegments::SetTableFunction ( const std::vector< double > &  table)
table- this vector contains the pairs (parameter, value) following each by other, so the number of elements in the vector must be even. The parameters must be in range [0,1] and sorted in increase order. The values of function must be positive.
Referenced by StdMeshers_NumberOfSegments_i::SetTableFunction().
◆ operator<<
std::ostream & operator<< ( std::ostream &  save,
StdMeshers_NumberOfSegments &  hyp
friend
◆ operator>>
std::istream & operator>> ( std::istream &  load,
friend
◆ _beta
double StdMeshers_NumberOfSegments::_beta
◆ _convMode
int StdMeshers_NumberOfSegments::_convMode
◆ _distr
std::vector<double> StdMeshers_NumberOfSegments::_distr
◆ _distrType
DistrType StdMeshers_NumberOfSegments::_distrType
◆ _edgeIDs
◆ _func
std::string StdMeshers_NumberOfSegments::_func
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _numberOfSegments
smIdType StdMeshers_NumberOfSegments::_numberOfSegments
◆ _objEntry
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _scaleFactor
double StdMeshers_NumberOfSegments::_scaleFactor
◆ _shapeType
◆ _table
std::vector<double> StdMeshers_NumberOfSegments::_table
◆ _type
