StdMeshers_PolyhedronPerSolid_3D Class Reference
#include <StdMeshers_PolyhedronPerSolid_3D.hxx>
Inheritance diagram for StdMeshers_PolyhedronPerSolid_3D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_PolyhedronPerSolid_3D (int hypId, SMESH_Gen *gen)
 ~StdMeshers_PolyhedronPerSolid_3D ()
virtual void CancelCompute ()
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
StdMeshers_Regular_1D * myEdgeMesher
StdMeshers_PolygonPerFace_2D * myFaceMesher
const StdMeshers_ViscousLayers * myViscousLayersHyp
std::string _libName
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_PolyhedronPerSolid_3D()
StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D ( int  hypId,
SMESH_Gen *  gen
◆ ~StdMeshers_PolyhedronPerSolid_3D()
StdMeshers_PolyhedronPerSolid_3D::~StdMeshers_PolyhedronPerSolid_3D ( )
References myEdgeMesher, and myFaceMesher.
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ CancelCompute()
◆ CheckHypothesis()
bool StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
SMESH_Hypothesis::Hypothesis_Status &  aStatus
aMesh- the mesh
aShape- the shape
aStatus- check result
bool- true if hypothesis is well defined
Textual description of a problem can be stored in _comment field.
Implements SMESH_Algo.
References StdMeshers_ViscousLayers::CheckHypothesis(), SMESH_Algo::error(), SMESH_Algo::GetUsedHypothesis(), SMESH_Hypothesis::HYP_INCOMPATIBLE, SMESH_Hypothesis::HYP_OK, and myViscousLayersHyp.
◆ Compute() [1/2]
◆ Compute() [2/2]
SMESH_MesherHelper *  aHelper
aMesh- the mesh
bool- is a success
aMesh- the mesh
bool- is a success
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Prism_3D::compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), StdMeshers_Quadrangle_2D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), TNodeDistributor::Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), StdMeshers_Prism_3D::computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), StdMeshers_Prism_3D::Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), StdMeshers_Quadrangle_2D::getCorners(), StdMeshers_Quadrangle_2D::getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), StdMeshers_Prism_3D::getWallFaces(), StdMeshers_Prism_3D::initPrism(), StdMeshers_Prism_3D::projectBottomToTop(), and StdMeshers_Quadrangle_2D::setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
bool StdMeshers_PolyhedronPerSolid_3D::Evaluate ( SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ GetDim()
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ GetType()
◆ GetUsedHypothesis()
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), StdMeshers_CompositeSegment_1D::GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ InitComputeError()
◆ IsApplicableToShape()
bool SMESH_3D_Algo::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
[in]aShape- shape to check
bool- true by default
Reimplemented in StdMeshers_Hexa_3D, StdMeshers_Prism_3D, StdMeshers_Projection_3D, and StdMeshers_RadialPrism_3D.
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
◆ isDegenerated()
◆ IsSameName()
◆ IsStatusFatal()
◆ IsStraight()
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void SMESH_Algo::SetEventListener ( SMESH_subMesh *  subMesh)
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh. By default none listener is set
After being set, event listener is notified on each event of a submesh. By default non listener is set
Reimplemented in StdMeshers_Cartesian_3D, StdMeshers_CompositeSegment_1D, StdMeshers_Import_1D, StdMeshers_Import_1D2D, StdMeshers_QuadFromMedialAxis_1D2D, StdMeshers_RadialQuadrangle_1D2D, StdMeshers_Regular_1D, StdMeshers_Projection_1D, StdMeshers_Projection_1D2D, StdMeshers_Projection_2D, and StdMeshers_Projection_3D.
Referenced by SMESH_subMesh::AlgoStateEngine().
◆ SetLibName()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ SubMeshesToCompute()
◆ SubmeshRestored()
subMesh- restored submesh
◆ SupportSubmeshes()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _assigedShapeList
◆ _badInputElements
◆ _comment
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _type
◆ _usedHypList
◆ myEdgeMesher
StdMeshers_Regular_1D* StdMeshers_PolyhedronPerSolid_3D::myEdgeMesher
◆ myFaceMesher
StdMeshers_PolygonPerFace_2D* StdMeshers_PolyhedronPerSolid_3D::myFaceMesher
◆ myViscousLayersHyp
const StdMeshers_ViscousLayers* StdMeshers_PolyhedronPerSolid_3D::myViscousLayersHyp
Referenced by CheckHypothesis(), and Compute().
