VISCOUS_3D::_Smoother1D Struct Reference
Smoother of _LayerEdge's on EDGE. More...
struct  OffPnt
 Handle (Geom_Curve) _anaCurve
 _Smoother1D (Handle(Geom_Curve) curveForSmooth, _EdgesOnShape &eos)
bool Perform (_SolidData &data, Handle(ShapeAnalysis_Surface)&surface, const TopoDS_Face &F, SMESH_MesherHelper &helper)
 Smooth edges on EDGE. More...
void prepare (_SolidData &data)
 Prepare for smoothing. More...
void findEdgesToSmooth ()
 Find edges to smooth. More...
bool isToSmooth (int iE)
 Check if iE-th _LayerEdge needs smoothing. More...
bool smoothAnalyticEdge (_SolidData &data, Handle(ShapeAnalysis_Surface)&surface, const TopoDS_Face &F, SMESH_MesherHelper &helper)
 smooth _LayerEdge's on a staight EDGE or circular EDGE More...
bool smoothComplexEdge (_SolidData &data, Handle(ShapeAnalysis_Surface)&surface, const TopoDS_Face &F, SMESH_MesherHelper &helper)
 smooth _LayerEdge's on a an EDGE More...
gp_XYZ getNormalNormal (const gp_XYZ &normal, const gp_XYZ &edgeDir)
 return _normal of _leOnV[is2nd] normal to the EDGE More...
_LayerEdge * getLEdgeOnV (bool is2nd)
bool isAnalytic () const
void offPointsToPython () const
 Writes a script creating a mesh composed of _offPoints. More...
static Handle (Geom_Curve) CurveForSmooth(const TopoDS_Edge &E
Data Fields
vector< OffPnt > _offPoints
vector< double > _leParams
_LayerEdge _leOnV [2]
gp_XYZ _edgeDir [2]
size_t _iSeg [2]
_EdgesOnShape & _eos
double _curveLen
std::pair< int, int > _eToSmooth [2]
static _EdgesOnShape & eos
static _EdgesOnShape SMESH_MesherHelper & helper
◆ _Smoother1D()
VISCOUS_3D::_Smoother1D::_Smoother1D ( Handle(Geom_Curve)  curveForSmooth,
_EdgesOnShape &  eos
◆ findEdgesToSmooth()
◆ getLEdgeOnV()
_LayerEdge * VISCOUS_3D::_Smoother1D::getLEdgeOnV ( bool  is2nd)
◆ getNormalNormal()
gp_XYZ _Smoother1D::getNormalNormal ( const gp_XYZ &  normal,
const gp_XYZ &  edgeDir
References VISCOUS_3D::_EdgesOnShape::_edges, _eos, and VISCOUS_3D::_LayerEdge::_normal.
Referenced by prepare(), and smoothComplexEdge().
◆ Handle() [1/2]
VISCOUS_3D::_Smoother1D::Handle ( Geom_Curve  )
Referenced by Handle(), and smoothAnalyticEdge().
◆ Handle() [2/2]
static VISCOUS_3D::_Smoother1D::Handle ( Geom_Curve  ) const &
◆ isAnalytic()
bool VISCOUS_3D::_Smoother1D::isAnalytic ( ) const
◆ isToSmooth()
◆ offPointsToPython()
void _Smoother1D::offPointsToPython ( ) const
References _offPoints.
◆ Perform()
bool _Smoother1D::Perform ( _SolidData &  data,
Handle(ShapeAnalysis_Surface)&  surface,
const TopoDS_Face &  F,
◆ prepare()
◆ smoothAnalyticEdge()
◆ smoothComplexEdge()
◆ _curveLen
double VISCOUS_3D::_Smoother1D::_curveLen
Referenced by findEdgesToSmooth(), and prepare().
◆ _edgeDir
gp_XYZ VISCOUS_3D::_Smoother1D::_edgeDir[2]
◆ _eos
◆ _eToSmooth
std::pair<int,int> VISCOUS_3D::_Smoother1D::_eToSmooth[2]
◆ _iSeg
size_t VISCOUS_3D::_Smoother1D::_iSeg[2]
◆ _leOnV
_LayerEdge VISCOUS_3D::_Smoother1D::_leOnV[2]
◆ _leParams
vector< double > VISCOUS_3D::_Smoother1D::_leParams
◆ _offPoints
vector< OffPnt > VISCOUS_3D::_Smoother1D::_offPoints
◆ eos
_EdgesOnShape& VISCOUS_3D::_Smoother1D::eos
Referenced by Handle().
◆ helper
_EdgesOnShape SMESH_MesherHelper& VISCOUS_3D::_Smoother1D::helper
Referenced by Handle(), Perform(), and smoothAnalyticEdge().
