TNodeDistributor Class Reference
Class computing layers distribution using data of StdMeshers_LayerDistribution hypothesis. More...
Inheritance diagram for TNodeDistributor:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
bool Compute (vector< double > &positions, gp_Pnt pIn, gp_Pnt pOut, SMESH_Mesh &aMesh, const StdMeshers_LayerDistribution *hyp)
virtual void CancelCompute ()
 Pass CancelCompute() to a child algorithm. More...
void SubmeshRestored (SMESH_subMesh *subMesh)
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static TNodeDistributor * GetDistributor (SMESH_Mesh &aMesh)
Protected Types
enum  HypothesisType {
  LOCAL_LENGTH , MAX_LENGTH , NB_SEGMENTS , BEG_END_LENGTH ,
  DEFLECTION , ARITHMETIC_1D , FIXED_POINTS_1D , ADAPTIVE ,
  GEOMETRIC_1D , DISTRIB_PROPAGATION , NONE
enum  ValueIndex {
  SCALE_FACTOR_IND = 0 , BETA_IND = 0 , BEG_LENGTH_IND = 0 , END_LENGTH_IND = 1 ,
  DEFLECTION_IND = 0 , PRECISION_IND = 1
enum  IValueIndex { NB_SEGMENTS_IND = 0 , DISTR_TYPE_IND = 1 , CONV_MODE_IND = 2 }
enum  VValueIndex { TAB_FUNC_IND = 0 }
enum  SValueIndex { EXPR_FUNC_IND = 0 }
 TNodeDistributor (int hypId, SMESH_Gen *gen)
virtual const list< const SMESHDS_Hypothesis * > & GetUsedHypothesis (SMESH_Mesh &, const TopoDS_Shape &, const bool)
 See comments in SMESH_Algo.cxx. More...
virtual bool computeInternalParameters (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, double theLength, double theFirstU, double theLastU, std::list< double > &theParameters, const bool theReverse, bool theConsiderPropagation=false)
virtual void redistributeNearVertices (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, double theLength, std::list< double > &theParameters, const TopoDS_Vertex &theVf, const TopoDS_Vertex &thieve)
 Tune parameters to fit "SegmentLengthAroundVertex" hypothesis. More...
bool divideIntoEqualSegments (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, smIdType theNbPoints, double theTol, double theLength, double theFirstU, double theLastU, std::list< double > &theParameters)
 Divide a curve into equal segments. More...
bool computeBetaLaw (Adaptor3d_Curve &theC3d, std::list< double > &theParams, double f, double theLength, double beta, int nbSegments, bool theReverse)
static const StdMeshers_SegmentLengthAroundVertex * getVertexHyp (SMESH_Mesh &theMesh, const TopoDS_Vertex &theV)
 Return StdMeshers_SegmentLengthAroundVertex assigned to vertex. More...
HypothesisType _hypType
const StdMeshers_FixedPoints1D * _fpHyp
const StdMeshers_Adaptive1D * _adaptiveHyp
double _value [2]
smIdType _ivalue [3]
std::vector< double > _vvalue [1]
std::string _svalue [1]
std::vector< int > _revEdgesIDs
TopoDS_Shape _mainEdge
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
list< const SMESHDS_Hypothesis * > myUsedHyps
std::string _libName
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ HypothesisType
enum StdMeshers_Regular_1D::HypothesisType
LOCAL_LENGTH
MAX_LENGTH
NB_SEGMENTS
BEG_END_LENGTH
DEFLECTION
ARITHMETIC_1D
FIXED_POINTS_1D
ADAPTIVE
GEOMETRIC_1D
DISTRIB_PROPAGATION
NONE
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ IValueIndex
enum StdMeshers_Regular_1D::IValueIndex
NB_SEGMENTS_IND
DISTR_TYPE_IND
CONV_MODE_IND
◆ SValueIndex
enum StdMeshers_Regular_1D::SValueIndex
EXPR_FUNC_IND
◆ ValueIndex
enum StdMeshers_Regular_1D::ValueIndex
SCALE_FACTOR_IND
BETA_IND
BEG_LENGTH_IND
END_LENGTH_IND
DEFLECTION_IND
PRECISION_IND
◆ VValueIndex
enum StdMeshers_Regular_1D::VValueIndex
TAB_FUNC_IND
◆ TNodeDistributor()
TNodeDistributor::TNodeDistributor ( int  hypId,
SMESH_Gen *  gen
Referenced by GetDistributor().
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ CancelCompute()
void StdMeshers_Regular_1D::CancelCompute ( )
References SMESH_Algo::CancelCompute().
◆ CheckHypothesis()
bool StdMeshers_Regular_1D::CheckHypothesis ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
SMESH_Hypothesis::Hypothesis_Status &  aStatus
aMesh- the mesh
aShape- the shape
aStatus- check result
bool- true if hypothesis is well defined
Textual description of a problem can be stored in _comment field.
Implements SMESH_Algo.
Reimplemented in StdMeshers_QuadFromMedialAxis_1D2D::Algo1D.
References StdMeshers::StdMeshers_NumberOfSegments::ConversionMode(), StdMeshers_NumberOfSegments::DT_BetaLaw, StdMeshers_NumberOfSegments::DT_ExprFunc, StdMeshers_NumberOfSegments::DT_Regular, StdMeshers_NumberOfSegments::DT_Scale, StdMeshers_NumberOfSegments::DT_TabFunc, StdMeshers::StdMeshers_NumberOfSegments::GetBeta(), SMESH_Gen::GetBoundaryBoxSegmentation(), StdMeshers::StdMeshers_Geometric1D::GetCommonRatio(), StdMeshers::StdMeshers_Deflection1D::GetDeflection(), StdMeshers::StdMeshers_NumberOfSegments::GetDistrType(), StdMeshers::StdMeshers_NumberOfSegments::GetExpressionFunction(), StdMeshers_Propagation::GetFilter(), SMESH_Mesh::GetGen(), SMESH_Mesh::GetHypotheses(), StdMeshers::StdMeshers_LocalLength::GetLength(), StdMeshers::StdMeshers_MaxLength::GetLength(), StdMeshers::StdMeshers_Arithmetic1D::GetLength(), StdMeshers::StdMeshers_StartEndLength::GetLength(), SMESH::SMESH_Hypothesis::GetName(), SMESHDS_Hypothesis::GetName(), StdMeshers::StdMeshers_NumberOfSegments::GetNumberOfSegments(), StdMeshers::StdMeshers_LocalLength::GetPrecision(), StdMeshers::Reversible1D::GetReversedEdges(), StdMeshers::StdMeshers_NumberOfSegments::GetScaleFactor(), SMESH_Mesh::GetShapeDiagonalSize(), StdMeshers::StdMeshers_Geometric1D::GetStartLength(), StdMeshers::StdMeshers_NumberOfSegments::GetTableFunction(), StdMeshers::StdMeshers_MaxLength::GetUsePreestimatedLength(), SMESH::HYP_INCOMPAT_HYPS, SMESH_Hypothesis::HYP_INCOMPATIBLE, SMESH_Hypothesis::HYP_MISSING, SMESH::HYP_OK, SMESH_Hypothesis::HYP_OK, SMESH_Hypothesis::IsAuxiliary(), SMESH_HypoFilter::IsOk(), and SMESHDS_Hypothesis::IsSameName().
Referenced by StdMeshers_QuadFromMedialAxis_1D2D::Algo1D::CheckHypothesis(), and Compute().
◆ Compute() [1/3]
bool StdMeshers_Regular_1D::Compute ( SMESH_Mesh &  aMesh,
◆ Compute() [2/3]
SMESH_MesherHelper *  aHelper
aMesh- the mesh
bool- is a success
aMesh- the mesh
bool- is a success
◆ Compute() [3/3]
bool TNodeDistributor::Compute ( vector< double > &  positions,
gp_Pnt  pIn,
gp_Pnt  pOut,
SMESH_Mesh &  aMesh,
const StdMeshers_LayerDistribution *  hyp
◆ computeBetaLaw()
bool StdMeshers_Regular_1D::computeBetaLaw ( Adaptor3d_Curve &  theC3d,
std::list< double > &  theParams,
double  f,
double  theLength,
double  beta,
int  nbSegments,
bool  theReverse
References MESSAGE.
◆ computeInternalParameters()
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ divideIntoEqualSegments()
bool StdMeshers_Regular_1D::divideIntoEqualSegments ( SMESH_Mesh &  theMesh,
double  theTol,
double  theLength,
double  theFirstU,
double  theLastU,
std::list< double > &  theParameters
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Prism_3D::compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), StdMeshers_Quadrangle_2D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), StdMeshers_Prism_3D::computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), StdMeshers_Prism_3D::Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), StdMeshers_Quadrangle_2D::getCorners(), StdMeshers_Quadrangle_2D::getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), StdMeshers_Prism_3D::getWallFaces(), StdMeshers_Prism_3D::initPrism(), StdMeshers_Prism_3D::projectBottomToTop(), and StdMeshers_Quadrangle_2D::setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
bool StdMeshers_Regular_1D::Evaluate ( SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap
aMesh- the mesh
aShape- the shape
aResMap- prospective number of elements by SMDSAbs_ElementType by a sub-mesh
bool- is a success
References COMPERR_ALGO_FAILED, Edge, SMESH_subMesh::GetComputeError(), SMESH_Mesh::GetSubMesh(), Handle(), SMDSEntity_Edge, SMDSEntity_Last, SMDSEntity_Node, and SMDSEntity_Quad_Edge.
Referenced by StdMeshers_PolyhedronPerSolid_3D::Evaluate().
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ GetDim()
◆ GetDistributor()
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ GetType()
◆ GetUsedHypothesis() [1/2]
virtual const list< const SMESHDS_Hypothesis * > & TNodeDistributor::GetUsedHypothesis ( SMESH_Mesh &  aMesh,
Reimplemented from StdMeshers_Regular_1D.
References myUsedHyps.
◆ GetUsedHypothesis() [2/2]
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), StdMeshers_CompositeSegment_1D::GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ getVertexHyp()
const StdMeshers_SegmentLengthAroundVertex * StdMeshers_Regular_1D::getVertexHyp ( SMESH_Mesh &  theMesh,
const TopoDS_Vertex &  theV
staticprotectedinherited
◆ InitComputeError()
◆ IsApplicableToShape()
bool SMESH_1D_Algo::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
[in]aShape- shape to check
bool- true by default
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
◆ isDegenerated()
◆ IsSameName()
◆ IsStatusFatal()
◆ IsStraight()
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ redistributeNearVertices()
void StdMeshers_Regular_1D::redistributeNearVertices ( SMESH_Mesh &  theMesh,
double  theLength,
std::list< double > &  theParameters,
const TopoDS_Vertex &  theVf,
const TopoDS_Vertex &  theVl
theC3d- wire curve
theLength- curve length
theParameters- internal nodes parameters to modify
theVf- 1st vertex
theVl- 2nd vertex
References compensateError(), and StdMeshers::StdMeshers_SegmentLengthAroundVertex::GetLength().
Referenced by StdMeshers_CompositeSegment_1D::Compute().
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void StdMeshers_Regular_1D::SetEventListener ( SMESH_subMesh *  subMesh)
Class used to clean mesh on edges when 0D hyp modified.
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh.
Common approach doesn't work when 0D algo is missing because the 0D hyp is considered as not participating in computation whereas it is used by 1D algo.
    \brief Clean mesh on edges
    \param event - algo_event or compute_event itself (of SMESH_subMesh)
    \param eventType - ALGO_EVENT or COMPUTE_EVENT (of SMESH_subMesh)
    \param subMesh - the submesh where the event occurs
   &zwj;/
void ProcessEvent(const int event, const int eventType, SMESH_subMesh* subMesh, EventListenerData*, const SMESH_Hypothesis*) { if ( eventType == SMESH_subMesh::ALGO_EVENT) // all algo events { subMesh->ComputeStateEngine( SMESH_subMesh::MODIF_ALGO_STATE ); } } }; // struct VertexEventListener
Sets event listener to vertex submeshes
Reimplemented in StdMeshers_CompositeSegment_1D.
References StdMeshers_Propagation::SetPropagationMgr().
Referenced by StdMeshers_CompositeSegment_1D::SetEventListener().
◆ SetLibName()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ SubMeshesToCompute()
◆ SubmeshRestored()
void StdMeshers_Regular_1D::SubmeshRestored ( SMESH_subMesh *  subMesh)
Do nothing.
subMesh- restored submesh
◆ SupportSubmeshes()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _adaptiveHyp
const StdMeshers_Adaptive1D* StdMeshers_Regular_1D::_adaptiveHyp
◆ _assigedShapeList
◆ _badInputElements
◆ _comment
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _fpHyp
const StdMeshers_FixedPoints1D* StdMeshers_Regular_1D::_fpHyp
◆ _gen
◆ _hypId
◆ _hypType
◆ _ivalue
smIdType StdMeshers_Regular_1D::_ivalue[3]
◆ _libName
privateinherited
◆ _mainEdge
TopoDS_Shape StdMeshers_Regular_1D::_mainEdge
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _revEdgesIDs
std::vector<int> StdMeshers_Regular_1D::_revEdgesIDs
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _svalue
std::string StdMeshers_Regular_1D::_svalue[1]
◆ _type
◆ _usedHypList
◆ _value
double StdMeshers_Regular_1D::_value[2]
◆ _vvalue
std::vector<double> StdMeshers_Regular_1D::_vvalue[1]
◆ myUsedHyps
list<const SMESHDS_Hypothesis *> TNodeDistributor::myUsedHyps
Referenced by Compute(), and GetUsedHypothesis().
