StdMeshers_Arithmetic1D: interface of "Arithmetic 1D" hypothesis.
More...
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLength()
| double StdMeshers::StdMeshers_Arithmetic1D::GetLength |
in boolean |
isStartLength | ) |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetObjectEntry()
| string StdMeshers::Reversible1D::GetObjectEntry |
Get the entry of the main object.
◆ GetReversedEdges()
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetEndLength()
| void StdMeshers::StdMeshers_Arithmetic1D::SetEndLength |
in double |
length | ) |
| raises | ( | SALOME::SALOME_Exception |
Sets <end segment length> parameter value.
◆ SetHolderHypothesis()
◆ SetLength()
| void StdMeshers::StdMeshers_Arithmetic1D::SetLength |
in double |
length, |
in boolean |
isStartLength |
Sets <start segment length> or <end segment length> parameter value.
- OBSOLETE *. Avoid such a way of interface design
- It is recommended to dedicate a method to each parameter.
◆ SetObjectEntry()
| void StdMeshers::Reversible1D::SetObjectEntry |
in string |
entry | ) |
Set entry of the main object.
◆ SetReversedEdges()
Set list of edges to reverse.
◆ SetStartLength()
| void StdMeshers::StdMeshers_Arithmetic1D::SetStartLength |
in double |
length | ) |
Sets <start segment length> parameter value.
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
