StdMeshers_Deflection1D: interface of "Deflection 1D" hypothesis.
More...
◆ GetDeflection()
| double StdMeshers::StdMeshers_Deflection1D::GetDeflection |
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetDeflection()
| void StdMeshers::StdMeshers_Deflection1D::SetDeflection |
in double |
deflection | ) |
| raises | ( | SALOME::SALOME_Exception |
Sets <deflection> parameter value.
◆ SetHolderHypothesis()
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
