interface of "SegmentLengthAroundVertex" hypothesis. More...
| void | SetLength (in double length) raises (SALOME::SALOME_Exception) |
| Sets <length> parameter value. More... | |
| double | GetLength () |
| Returns <length> parameter value. More... | |
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
This hypothesis specifies length of segments adjacent to the vertex the hypothesis is assigned to
| double StdMeshers::StdMeshers_SegmentLengthAroundVertex::GetLength | ( | ) |
Referenced by StdMeshers_Regular_1D::redistributeNearVertices().
| void StdMeshers::StdMeshers_SegmentLengthAroundVertex::SetLength | ( | in double | length | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
