StdMeshers_Arithmetic1D: interface of "Geometric 1D" hypothesis.
More...
◆ GetCommonRatio()
| double StdMeshers::StdMeshers_Geometric1D::GetCommonRatio |
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetObjectEntry()
| string StdMeshers::Reversible1D::GetObjectEntry |
Get the entry of the main object.
◆ GetReversedEdges()
◆ GetStartLength()
| double StdMeshers::StdMeshers_Geometric1D::GetStartLength |
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetCommonRatio()
| void StdMeshers::StdMeshers_Geometric1D::SetCommonRatio |
in double |
factor | ) |
| raises | ( | SALOME::SALOME_Exception |
Sets value of Common Ratio.
◆ SetHolderHypothesis()
◆ SetObjectEntry()
| void StdMeshers::Reversible1D::SetObjectEntry |
in string |
entry | ) |
Set entry of the main object.
◆ SetReversedEdges()
Set list of edges to reverse.
◆ SetStartLength()
| void StdMeshers::StdMeshers_Geometric1D::SetStartLength |
in double |
length | ) |
Sets length of the first segment.
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
