StdMeshers_FixedPoints1D: interface of "Fixed points 1D" hypothesis.
More...
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetNbSegments()
Returns list of numbers of segments.
◆ GetObjectEntry()
| string StdMeshers::Reversible1D::GetObjectEntry |
Get the entry of the main object.
◆ GetPoints()
Returns list of point's parameters.
◆ GetReversedEdges()
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetHolderHypothesis()
◆ SetNbSegments()
| void StdMeshers::StdMeshers_FixedPoints1D::SetNbSegments |
in SMESH::smIdType_array |
listNbSeg | ) |
| raises | ( | SALOME::SALOME_Exception |
◆ SetObjectEntry()
| void StdMeshers::Reversible1D::SetObjectEntry |
in string |
entry | ) |
Set entry of the main object.
◆ SetPoints()
| void StdMeshers::StdMeshers_FixedPoints1D::SetPoints |
in SMESH::double_array |
listParams | ) |
Sets some points on edge using parameter on curve from 0 to 1 (additionally it is neecessary to check orientation of edges and create list of reversed edges if it is needed) and sets numbers of segments between given points (default values are equals 1)
Referenced by StdMeshers_Regular_1D::divideIntoEqualSegments().
◆ SetReversedEdges()
Set list of edges to reverse.
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
