StdMeshers::StdMeshers_MaxLength Interface Reference
StdMeshers_MaxLength: interface of "Max length" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_MaxLength:
void SetLength (in double length) raises (SALOME::SALOME_Exception)
 Sets <length> parameter value. More...
double GetLength ()
 Returns <length> parameter value. More...
boolean HavePreestimatedLength ()
 Returns true if preestemated length is defined. More...
double GetPreestimatedLength ()
 Returns preestemated length. More...
void SetPreestimatedLength (in double length)
 Sets preestemated length. More...
void SetUsePreestimatedLength (in boolean toUse)
 Sets boolean parameter enabling/disabling usage of length computed basing on size of bounding box of shape to mesh. More...
boolean GetUsePreestimatedLength ()
 Returns value of boolean parameter enabling/disabling usage of length computed basing on size of bounding box of shape to mesh. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetId()
◆ GetLength()
double StdMeshers::StdMeshers_MaxLength::GetLength ( )
◆ GetLibName()
◆ GetName()
◆ GetPreestimatedLength()
double StdMeshers::StdMeshers_MaxLength::GetPreestimatedLength ( )
◆ GetUsePreestimatedLength()
boolean StdMeshers::StdMeshers_MaxLength::GetUsePreestimatedLength ( )
◆ GetVarParameter()
◆ HasParameters()
◆ HavePreestimatedLength()
boolean StdMeshers::StdMeshers_MaxLength::HavePreestimatedLength ( )
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetLength()
void StdMeshers::StdMeshers_MaxLength::SetLength ( in double  length)
◆ SetPreestimatedLength()
void StdMeshers::StdMeshers_MaxLength::SetPreestimatedLength ( in double  length)
◆ SetUsePreestimatedLength()
void StdMeshers::StdMeshers_MaxLength::SetUsePreestimatedLength ( in boolean  toUse)
◆ SetVarParameter()
in string  method
