StdMeshers::StdMeshers_LocalLength Interface Reference
StdMeshers_LocalLength: interface of "Average length" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_LocalLength:
void SetLength (in double length) raises (SALOME::SALOME_Exception)
 Sets <length> parameter value. More...
void SetPrecision (in double precision) raises (SALOME::SALOME_Exception)
 Sets <precision> parameter value. More...
double GetLength ()
 Returns <length> parameter value. More...
double GetPrecision ()
 Returns <precision> parameter value. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetId()
◆ GetLength()
double StdMeshers::StdMeshers_LocalLength::GetLength ( )
◆ GetLibName()
◆ GetName()
◆ GetPrecision()
double StdMeshers::StdMeshers_LocalLength::GetPrecision ( )
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetLength()
void StdMeshers::StdMeshers_LocalLength::SetLength ( in double  length)
◆ SetPrecision()
void StdMeshers::StdMeshers_LocalLength::SetPrecision ( in double  precision)
Precision parameter is used to allow rounding a number of segments, calculated from the edge length and average length of segment, to the lower integer, if this value outstands from it in bounds of the precision. Otherwise, the number of segments is rounded to the higher integer. Use value 0.5 to provide rounding to the nearest integer, 1.0 for the lower integer, 0.0 for the higher integer. Default value is 1e-07. In old studies, restored from file, this value will be set to zero, what corresponds to the old behaviour.
◆ SetVarParameter()
in string  method
