StdMeshers::StdMeshers_NumberOfSegments Interface Reference
StdMeshers_NumberOfSegments: interface of "Nb. Segments" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_NumberOfSegments:
SMESH::double_array BuildDistributionExpr (in string func, in long nbSeg, in long conv) raises (SALOME::SALOME_Exception)
 Builds and returns point distribution according to passed density function. More...
SMESH::double_array BuildDistributionTab (in SMESH::double_array func, in long nbSeg, in long conv) raises (SALOME::SALOME_Exception)
void SetNumberOfSegments (in SMESH::smIdType segmentsNumber) raises (SALOME::SALOME_Exception)
 Sets <number of segments> parameter value. More...
long GetNumberOfSegments ()
 Returns <number of segments> parameter value. More...
void SetDistrType (in long typ) raises (SALOME::SALOME_Exception)
 Sets <distribution type> parameter value. More...
long GetDistrType ()
 Returns <distribution type> parameter value. More...
void SetScaleFactor (in double scaleFactor) raises (SALOME::SALOME_Exception)
 Sets <scale factor> parameter value. More...
double GetScaleFactor () raises (SALOME::SALOME_Exception)
 Returns <scale factor> parameter value. More...
void SetBeta (in double beta) raises (SALOME::SALOME_Exception)
 Sets <beta> coefficient for Beta Law distribution. More...
double GetBeta () raises (SALOME::SALOME_Exception)
 Returns <beta> coefficient for Beta Law distribution. More...
void SetTableFunction (in SMESH::double_array table) raises (SALOME::SALOME_Exception)
 Sets. More...
SMESH::double_array GetTableFunction () raises (SALOME::SALOME_Exception)
 Returns. More...
void SetExpressionFunction (in string expr) raises (SALOME::SALOME_Exception)
 Sets <expression function> parameter value for distribution DT_ExprFunc. More...
string GetExpressionFunction () raises (SALOME::SALOME_Exception)
 Returns <expression function> parameter value for distribution DT_ExprFunc. More...
void SetConversionMode (in long conv) raises (SALOME::SALOME_Exception)
 Sets <conversion mode> parameter value for functional distributions. More...
long ConversionMode () raises (SALOME::SALOME_Exception)
 Returns <conversion mode> parameter value for functional distributions. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
void SetReversedEdges (in SMESH::long_array list)
 Set list of edges to reverse. More...
SMESH::long_array GetReversedEdges ()
 Returns list of edges to reverse. More...
void SetObjectEntry (in string entry)
 Set entry of the main object. More...
string GetObjectEntry ()
 Get the entry of the main object. More...
◆ BuildDistributionExpr()
SMESH::double_array StdMeshers::StdMeshers_NumberOfSegments::BuildDistributionExpr ( in string  func,
in long  nbSeg,
in long  conv
◆ BuildDistributionTab()
SMESH::double_array StdMeshers::StdMeshers_NumberOfSegments::BuildDistributionTab ( in SMESH::double_array  func,
in long  nbSeg,
in long  conv
◆ ConversionMode()
long StdMeshers::StdMeshers_NumberOfSegments::ConversionMode ( )
◆ GetBeta()
double StdMeshers::StdMeshers_NumberOfSegments::GetBeta ( )
◆ GetDistrType()
long StdMeshers::StdMeshers_NumberOfSegments::GetDistrType ( )
◆ GetExpressionFunction()
string StdMeshers::StdMeshers_NumberOfSegments::GetExpressionFunction ( )
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetNumberOfSegments()
long StdMeshers::StdMeshers_NumberOfSegments::GetNumberOfSegments ( )
◆ GetObjectEntry()
string StdMeshers::Reversible1D::GetObjectEntry ( )
◆ GetReversedEdges()
SMESH::long_array StdMeshers::Reversible1D::GetReversedEdges ( )
◆ GetScaleFactor()
double StdMeshers::StdMeshers_NumberOfSegments::GetScaleFactor ( )
◆ GetTableFunction()
SMESH::double_array StdMeshers::StdMeshers_NumberOfSegments::GetTableFunction ( )
Returns.
value for distribution DT_TabFunc
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetBeta()
void StdMeshers::StdMeshers_NumberOfSegments::SetBeta ( in double  beta)
◆ SetConversionMode()
void StdMeshers::StdMeshers_NumberOfSegments::SetConversionMode ( in long  conv)
◆ SetDistrType()
void StdMeshers::StdMeshers_NumberOfSegments::SetDistrType ( in long  typ)
◆ SetExpressionFunction()
void StdMeshers::StdMeshers_NumberOfSegments::SetExpressionFunction ( in string  expr)
◆ SetHolderHypothesis()
◆ SetNumberOfSegments()
void StdMeshers::StdMeshers_NumberOfSegments::SetNumberOfSegments ( in SMESH::smIdType  segmentsNumber)
◆ SetObjectEntry()
void StdMeshers::Reversible1D::SetObjectEntry ( in string  entry)
◆ SetReversedEdges()
void StdMeshers::Reversible1D::SetReversedEdges ( in SMESH::long_array  list)
◆ SetScaleFactor()
void StdMeshers::StdMeshers_NumberOfSegments::SetScaleFactor ( in double  scaleFactor)
◆ SetTableFunction()
void StdMeshers::StdMeshers_NumberOfSegments::SetTableFunction ( in SMESH::double_array  table)
Sets.
◆ SetVarParameter()
in string  method
