StdMeshers_CartesianParameters3D Class Reference
This hypothesis specifies. More...
#include <StdMeshers_CartesianParameters3D.hxx>
Inheritance diagram for StdMeshers_CartesianParameters3D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_CartesianParameters3D (int hypId, SMESH_Gen *gen)
void SetGrid (std::vector< double > &xNodes, int axis)
 Sets coordinates of node positions along an axis (countered from 0) More...
void GetGrid (std::vector< double > &xNodes, int axis) const
 Return coordinates of node positions along the three axes. More...
void SetGridSpacing (std::vector< std::string > &spaceFunctions, std::vector< double > &internalPoints, const int axis)
 Set grid spacing along the three axes. More...
void GetGridSpacing (std::vector< std::string > &spaceFunctions, std::vector< double > &internalPoints, const int axis) const
bool IsGridBySpacing (const int axis) const
void SetFixedPoint (const double p[3], bool toUnset)
 Set/unset a fixed point, at which a node will be created provided that grid is defined by spacing in all directions. More...
bool GetFixedPoint (double p[3]) const
void GetCoordinates (std::vector< double > &xNodes, std::vector< double > &yNodes, std::vector< double > &zNodes, const Bnd_Box &bndBox) const
void SetAxisDirs (const double *the9DirComps)
 Set custom direction of axes. More...
const double * GetAxisDirs () const
void SetSizeThreshold (const double threshold)
 Set size threshold. More...
double GetSizeThreshold () const
 Return size threshold. More...
void SetToAddEdges (bool toAdd)
 Enables implementation of geometrical edges into the mesh. More...
bool GetToAddEdges () const
void SetToConsiderInternalFaces (bool toTreat)
 Enables treatment of geom faces either shared by solids or internal. More...
bool GetToConsiderInternalFaces () const
void SetToUseThresholdForInternalFaces (bool toUse)
 Enables applying size threshold to grid cells cut by internal geom faces. More...
bool GetToUseThresholdForInternalFaces () const
void SetToCreateFaces (bool toCreate)
 Enables creation of mesh faces. More...
bool GetToCreateFaces () const
void SetToUseQuanta (bool toUseQuanta)
 Enables use of quanta for hexahedrons at the solid external boundary. More...
bool GetToUseQuanta () const
void SetQuanta (const double quanta)
 Value of the quanta (volPolyhedron/volHexahedron) to use. More...
double GetQuanta () const
bool IsDefined () const
 Return true if parameters are well defined. More...
 Persistence methods. More...
 Initialize my parameter values by the mesh built on the geometry. More...
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static void ComputeCoordinates (const double x0, const double x1, std::vector< std::string > &spaceFuns, std::vector< double > &points, std::vector< double > &coords, const std::string &axis, const double *xForced=0)
 Computes node coordinates by spacing functions. More...
static void ComputeOptimalAxesDirs (const TopoDS_Shape &shape, const bool isOrthogonal, double dirCoords[9])
 Returns axes at which number of hexahedra is maximal. More...
std::vector< double > _coords [3]
std::vector< std::string > _spaceFunctions [3]
std::vector< double > _internalPoints [3]
double _axisDirs [9]
double _fixedPoint [3]
double _sizeThreshold
bool _toAddEdges
bool _toConsiderInternalFaces
bool _toUseThresholdForInternalFaces
bool _toCreateFaces
bool _toUseQuanta
double _quanta
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
  • Definition of the Cartesian grid
  • Size threshold
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_CartesianParameters3D()
StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D ( int  hypId,
SMESH_Gen *  gen
◆ ComputeCoordinates()
void StdMeshers_CartesianParameters3D::ComputeCoordinates ( const double  x0,
const double  x1,
std::vector< std::string > &  spaceFuns,
std::vector< double > &  points,
std::vector< double > &  coords,
const std::string &  axis,
const double *  xForced = 0
x0- lower coordinate
x1- upper coordinate
spaceFuns- space functions
points- internal points
coords- the computed coordinates
References StdMeshers::FunctionExpr::value().
Referenced by StdMeshers_CartesianParameters3D_i::ComputeCoordinates(), and GetCoordinates().
◆ ComputeOptimalAxesDirs()
void StdMeshers_CartesianParameters3D::ComputeOptimalAxesDirs ( const TopoDS_Shape &  shape,
double  dirCoords[9]
References Face, gpXYZ, and Handle().
Referenced by StdMeshers_CartesianParameters3D_i::ComputeOptimalAxesDirs().
◆ DataDependOnParams()
◆ GetAxisDirs()
const double * StdMeshers_CartesianParameters3D::GetAxisDirs ( ) const
◆ GetCoordinates()
void StdMeshers_CartesianParameters3D::GetCoordinates ( std::vector< double > &  xNodes,
std::vector< double > &  yNodes,
std::vector< double > &  zNodes,
const Bnd_Box &  bndBox
If the grid is defined by spacing functions, the coordinates are computed
References _axisDirs, _coords, _internalPoints, _spaceFunctions, ComputeCoordinates(), GetFixedPoint(), and IsGridBySpacing().
◆ GetDim()
◆ GetFixedPoint()
bool StdMeshers_CartesianParameters3D::GetFixedPoint ( double  p[3]) const
References _fixedPoint.
Referenced by GetCoordinates().
◆ GetGen()
◆ GetGrid()
void StdMeshers_CartesianParameters3D::GetGrid ( std::vector< double > &  xNodes,
int  axis
References _coords, and IsGridBySpacing().
Referenced by StdMeshers_CartesianParameters3D_i::GetGrid().
◆ GetGridSpacing()
void StdMeshers_CartesianParameters3D::GetGridSpacing ( std::vector< std::string > &  spaceFunctions,
std::vector< double > &  internalPoints,
const int  axis
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetName()
◆ GetQuanta()
double StdMeshers_CartesianParameters3D::GetQuanta ( ) const
◆ GetShapeType()
◆ GetSizeThreshold()
double StdMeshers_CartesianParameters3D::GetSizeThreshold ( ) const
◆ GetToAddEdges()
bool StdMeshers_CartesianParameters3D::GetToAddEdges ( ) const
◆ GetToConsiderInternalFaces()
bool StdMeshers_CartesianParameters3D::GetToConsiderInternalFaces ( ) const
◆ GetToCreateFaces()
bool StdMeshers_CartesianParameters3D::GetToCreateFaces ( ) const
◆ GetToUseQuanta()
bool StdMeshers_CartesianParameters3D::GetToUseQuanta ( ) const
◆ GetToUseThresholdForInternalFaces()
bool StdMeshers_CartesianParameters3D::GetToUseThresholdForInternalFaces ( ) const
◆ GetType()
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsDefined()
bool StdMeshers_CartesianParameters3D::IsDefined ( ) const
References _coords, _internalPoints, _sizeThreshold, and _spaceFunctions.
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis().
◆ IsGridBySpacing()
bool StdMeshers_CartesianParameters3D::IsGridBySpacing ( const int  axis) const
◆ IsSameName()
◆ IsStatusFatal()
◆ LoadFrom()
std::istream & StdMeshers_CartesianParameters3D::LoadFrom ( std::istream &  load)
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), SetFixedPoint(), SetGrid(), SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), SetToAddEdges(), SetToConsiderInternalFaces(), SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), SetToUseQuanta(), SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
std::ostream & StdMeshers_CartesianParameters3D::SaveTo ( std::ostream &  save)
◆ SetAxisDirs()
void StdMeshers_CartesianParameters3D::SetAxisDirs ( const double *  the9DirComps)
◆ SetFixedPoint()
void StdMeshers_CartesianParameters3D::SetFixedPoint ( const double  p[3],
bool  toUnset
References _fixedPoint, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetFixedPoint(), and StdMeshers_CartesianParameters3D().
◆ SetGrid()
void StdMeshers_CartesianParameters3D::SetGrid ( std::vector< double > &  xNodes,
int  axis
References _coords, _internalPoints, _spaceFunctions, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetGrid().
◆ SetGridSpacing()
void StdMeshers_CartesianParameters3D::SetGridSpacing ( std::vector< std::string > &  spaceFunctions,
const int  axis
spaceFunctions- functions defining spacing values at given point on axis
internalPoints- points dividing a grid into parts along each direction
Parameter t of spaceFunction f(t) is a position [0,1] within bounding box of the shape to mesh
Referenced by StdMeshers_CartesianParameters3D_i::SetGridSpacing(), and SetParametersByDefaults().
◆ SetLibName()
◆ SetParametersByDefaults()
bool StdMeshers_CartesianParameters3D::SetParametersByDefaults ( const TDefaults &  dflts,
Implements SMESH_Hypothesis.
References SMESH_Hypothesis::TDefaults::_elemLength, and SetGridSpacing().
◆ SetParametersByMesh()
bool StdMeshers_CartesianParameters3D::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
◆ SetQuanta()
void StdMeshers_CartesianParameters3D::SetQuanta ( const double  quanta)
Remarks
value [0.1, 1.0]
References _quanta, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetQuanta().
◆ SetSizeThreshold()
void StdMeshers_CartesianParameters3D::SetSizeThreshold ( const double  threshold)
Set size threshold.
A polyhedral cell got by cutting an initial hexahedron by geometry boundary is considered small and is removed if it's size is \athreshold times less than the size of the initial hexahedron.
References _sizeThreshold, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetSizeThreshold().
◆ SetToAddEdges()
void StdMeshers_CartesianParameters3D::SetToAddEdges ( bool  toAdd)
If this feature is disabled, sharp edges of the shape are lost ("smoothed") in the mesh if they don't coincide with the grid lines
References _toAddEdges, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetToAddEdges().
◆ SetToConsiderInternalFaces()
void StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces ( bool  toTreat)
References _toConsiderInternalFaces, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetToConsiderInternalFaces().
◆ SetToCreateFaces()
void StdMeshers_CartesianParameters3D::SetToCreateFaces ( bool  toCreate)
◆ SetToUseQuanta()
void StdMeshers_CartesianParameters3D::SetToUseQuanta ( bool  toUseQuanta)
References _toUseQuanta, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetToUseQuanta().
◆ SetToUseThresholdForInternalFaces()
void StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces ( bool  toUse)
References _toUseThresholdForInternalFaces, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_CartesianParameters3D_i::SetToUseThresholdForInternalFaces().
◆ _axisDirs
double StdMeshers_CartesianParameters3D::_axisDirs[9]
◆ _coords
std::vector<double> StdMeshers_CartesianParameters3D::_coords[3]
◆ _fixedPoint
double StdMeshers_CartesianParameters3D::_fixedPoint[3]
◆ _gen
◆ _hypId
◆ _internalPoints
std::vector<double> StdMeshers_CartesianParameters3D::_internalPoints[3]
◆ _libName
privateinherited
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _quanta
double StdMeshers_CartesianParameters3D::_quanta
Referenced by LoadFrom(), SaveTo(), and SetQuanta().
◆ _shapeType
◆ _sizeThreshold
double StdMeshers_CartesianParameters3D::_sizeThreshold
◆ _spaceFunctions
std::vector<std::string> StdMeshers_CartesianParameters3D::_spaceFunctions[3]
◆ _toAddEdges
bool StdMeshers_CartesianParameters3D::_toAddEdges
◆ _toConsiderInternalFaces
bool StdMeshers_CartesianParameters3D::_toConsiderInternalFaces
◆ _toCreateFaces
bool StdMeshers_CartesianParameters3D::_toCreateFaces
Referenced by LoadFrom(), SaveTo(), and SetToCreateFaces().
◆ _toUseQuanta
bool StdMeshers_CartesianParameters3D::_toUseQuanta
Referenced by LoadFrom(), SaveTo(), and SetToUseQuanta().
◆ _toUseThresholdForInternalFaces
bool StdMeshers_CartesianParameters3D::_toUseThresholdForInternalFaces
◆ _type
