StdMeshers_CartesianParameters3D_i Class Reference
#include <StdMeshers_CartesianParameters3D_i.hxx>
Inheritance diagram for StdMeshers_CartesianParameters3D_i:
 StdMeshers_CartesianParameters3D_i (PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
 StdMeshers_CartesianParameters3D_i::StdMeshers_CartesianParameters3D_i. More...
virtual ~StdMeshers_CartesianParameters3D_i ()
 StdMeshers_CartesianParameters3D_i::~StdMeshers_CartesianParameters3D_i. More...
void SetSizeThreshold (CORBA::Double threshold)
 Set size threshold. More...
CORBA::Double GetSizeThreshold ()
 GetSizeThreshold. More...
void SetGrid (const SMESH::double_array &coords, CORBA::Short axis)
 Set node coordinates along an axis (counterd from zero) More...
SMESH::double_array * GetGrid (CORBA::Short axis)
 GetGrid. More...
void SetGridSpacing (const SMESH::string_array &spaceFunctions, const SMESH::double_array &internalPoints, CORBA::Short axis)
 Set grid spacing along an axis. More...
void GetGridSpacing (SMESH::string_array_out xSpaceFunctions, SMESH::double_array_out xInternalPoints, CORBA::Short axis)
void SetAxesDirs (const SMESH::DirStruct &x, const SMESH::DirStruct &y, const SMESH::DirStruct &z)
 Set custom direction of axes. More...
void GetAxesDirs (SMESH::DirStruct &x, SMESH::DirStruct &y, SMESH::DirStruct &z)
void SetFixedPoint (const ::SMESH::PointStruct &p, CORBA::Boolean toUnset)
 Set/unset a fixed point, at which a node will be created provided that grid is defined by spacing in all directions. More...
CORBA::Boolean GetFixedPoint (::SMESH::PointStruct &p)
void SetToAddEdges (CORBA::Boolean toAdd)
 Enable implementation of geometrical edges into the mesh. More...
CORBA::Boolean GetToAddEdges ()
void SetToConsiderInternalFaces (CORBA::Boolean toTreat)
 Enable treatment of geom faces, either shared by solids or internal. More...
CORBA::Boolean GetToConsiderInternalFaces ()
void SetToUseThresholdForInternalFaces (CORBA::Boolean toUse)
 Enable applying size threshold to grid cells cut by internal geom faces. More...
CORBA::Boolean GetToUseThresholdForInternalFaces ()
void SetToCreateFaces (CORBA::Boolean toCreate)
 Enable creation of mesh faces. More...
CORBA::Boolean GetToCreateFaces ()
void SetToUseQuanta (CORBA::Boolean toUseQuanta)
 Set quanta option to allow replace polyhedrons by hexahedrons. More...
CORBA::Boolean GetToUseQuanta ()
void SetQuanta (CORBA::Double quanta)
 Define the quanta value. More...
CORBA::Double GetQuanta ()
 GetQuanta. More...
CORBA::Boolean IsGridBySpacing (CORBA::Short axis)
 Return true if the grid is defined by spacing functions and not by node coordinates. More...
void ComputeOptimalAxesDirs (GEOM::GEOM_Object_ptr shape, CORBA::Boolean isOrthogonal, SMESH::DirStruct &x, SMESH::DirStruct &y, SMESH::DirStruct &z)
 Return axes at which number of hexahedra is maximal. More...
SMESH::double_array * ComputeCoordinates (CORBA::Double x0, CORBA::Double x1, const SMESH::string_array &spaceFuns, const SMESH::double_array &points, const char *axisName)
 Compute node coordinates by spacing functions. More...
::StdMeshers_CartesianParameters3D * GetImpl ()
 Get implementation. More...
virtual char * GetName ()
virtual char * GetLibName ()
virtual CORBA::Short GetId ()
bool IsPublished ()
virtual char * SaveTo ()
◆ StdMeshers_CartesianParameters3D_i()
StdMeshers_CartesianParameters3D_i::StdMeshers_CartesianParameters3D_i ( PortableServer::POA_ptr  thePOA,
::SMESH_Gen *  theGenImpl
◆ ~StdMeshers_CartesianParameters3D_i()
StdMeshers_CartesianParameters3D_i::~StdMeshers_CartesianParameters3D_i ( )
◆ ComputeCoordinates()
SMESH::double_array * StdMeshers_CartesianParameters3D_i::ComputeCoordinates ( CORBA::Double  x0,
CORBA::Double  x1,
const SMESH::string_array &  spaceFuns,
const SMESH::double_array &  points,
const char *  axisName
x0- lower coordinate
x1- upper coordinate
spaceFuns- space functions
points- internal points
coords- the computed coordinates
References _array2vec, _vec2array, StdMeshers_CartesianParameters3D::ComputeCoordinates(), and GetImpl().
◆ ComputeOptimalAxesDirs()
void StdMeshers_CartesianParameters3D_i::ComputeOptimalAxesDirs ( GEOM::GEOM_Object_ptr  shape,
SMESH::DirStruct &  x,
SMESH::DirStruct &  y,
SMESH::DirStruct &  z
◆ GetAxesDirs()
◆ GetFixedPoint()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetFixedPoint ( ::SMESH::PointStruct &  p)
◆ GetGrid()
SMESH::double_array * StdMeshers_CartesianParameters3D_i::GetGrid ( CORBA::Short  axis)
◆ GetGridSpacing()
void StdMeshers_CartesianParameters3D_i::GetGridSpacing ( SMESH::string_array_out  xSpaceFunctions,
CORBA::Short  axis
◆ GetId()
◆ GetImpl()
◆ GetLibName()
◆ getMethodOfParameter()
◆ GetName()
◆ getObjectsDependOn()
virtual bool StdMeshers_CartesianParameters3D_i::getObjectsDependOn ( std::vector< std::string > &  ,
◆ getParamIndex()
int
◆ GetQuanta()
CORBA::Double StdMeshers_CartesianParameters3D_i::GetQuanta ( )
◆ GetSizeThreshold()
CORBA::Double StdMeshers_CartesianParameters3D_i::GetSizeThreshold ( )
◆ GetToAddEdges()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetToAddEdges ( )
◆ GetToConsiderInternalFaces()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetToConsiderInternalFaces ( )
◆ GetToCreateFaces()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetToCreateFaces ( )
◆ GetToUseQuanta()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetToUseQuanta ( )
◆ GetToUseThresholdForInternalFaces()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::GetToUseThresholdForInternalFaces ( )
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::IsDimSupported ( SMESH::Dimension  type)
References SMESH::DIM_3D.
◆ IsGridBySpacing()
CORBA::Boolean StdMeshers_CartesianParameters3D_i::IsGridBySpacing ( CORBA::Short  axis)
References GetImpl(), and StdMeshers_CartesianParameters3D::IsGridBySpacing().
◆ IsPublished()
◆ LoadFrom()
◆ SaveTo()
◆ SetAxesDirs()
void StdMeshers_CartesianParameters3D_i::SetAxesDirs ( const SMESH::DirStruct &  x,
const SMESH::DirStruct &  y,
const SMESH::DirStruct &  z
◆ SetFixedPoint()
void StdMeshers_CartesianParameters3D_i::SetFixedPoint ( const ::SMESH::PointStruct &  p,
References GetFixedPoint(), GetImpl(), StdMeshers_CartesianParameters3D::SetFixedPoint(), SMESH::PointStruct::x, SMESH::PointStruct::y, and SMESH::PointStruct::z.
◆ SetGrid()
void StdMeshers_CartesianParameters3D_i::SetGrid ( const SMESH::double_array &  coords,
CORBA::Short  axis
SetGrid.
References _array2vec, GetImpl(), SMESH_Hypothesis_i::myBaseImpl, and StdMeshers_CartesianParameters3D::SetGrid().
◆ SetGridSpacing()
void StdMeshers_CartesianParameters3D_i::SetGridSpacing ( const SMESH::string_array &  spaceFunctions,
const SMESH::double_array &  internalPoints,
CORBA::Short  axis
spaceFunctions- functions defining spacing value at given point on axis
internalPoints- points dividing a grid into parts along each direction
axis- index of an axis counterd from zero, i.e. 0==X, 1==Y, 2==Z
Parameter t of spaceFunction f(t) is a position [0,1] within bounding box of the shape to mesh or within an interval defined by internal points
References _array2vec, GetImpl(), SMESH_Hypothesis_i::myBaseImpl, and StdMeshers_CartesianParameters3D::SetGridSpacing().
◆ SetHolderHypothesis()
◆ SetLibName()
◆ setObjectsDependOn()
virtual bool StdMeshers_CartesianParameters3D_i::setObjectsDependOn ( std::vector< std::string > &  ,
◆ setOldParameters()
◆ SetQuanta()
void StdMeshers_CartesianParameters3D_i::SetQuanta ( CORBA::Double  quanta)
◆ SetSizeThreshold()
void StdMeshers_CartesianParameters3D_i::SetSizeThreshold ( CORBA::Double  threshold)
Set size threshold.
SetSizeThreshold.
A polyhedral cell got by cutting an initial hexahedron by geometry boundary is considered small and is removed if it's size is \athreshold times less than the size of the initial hexahedron. threshold must be > 1.0
References GetImpl(), SMESH_Hypothesis_i::myBaseImpl, and StdMeshers_CartesianParameters3D::SetSizeThreshold().
◆ SetToAddEdges()
void StdMeshers_CartesianParameters3D_i::SetToAddEdges ( CORBA::Boolean  toAdd)
If this feature is disabled, sharp edges of the shape are lost ("smoothed") in the mesh if they don't coincide with the grid lines
References GetImpl(), and StdMeshers_CartesianParameters3D::SetToAddEdges().
◆ SetToConsiderInternalFaces()
void StdMeshers_CartesianParameters3D_i::SetToConsiderInternalFaces ( CORBA::Boolean  toTreat)
References GetImpl(), GetToConsiderInternalFaces(), and StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces().
◆ SetToCreateFaces()
void StdMeshers_CartesianParameters3D_i::SetToCreateFaces ( CORBA::Boolean  toCreate)
References GetImpl(), GetToCreateFaces(), and StdMeshers_CartesianParameters3D::SetToCreateFaces().
◆ SetToUseQuanta()
void StdMeshers_CartesianParameters3D_i::SetToUseQuanta ( CORBA::Boolean  toUseQuanta)
References GetImpl(), GetToUseQuanta(), and StdMeshers_CartesianParameters3D::SetToUseQuanta().
◆ SetToUseThresholdForInternalFaces()
void StdMeshers_CartesianParameters3D_i::SetToUseThresholdForInternalFaces ( CORBA::Boolean  toUse)
References GetImpl(), GetToUseThresholdForInternalFaces(), and StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces().
◆ SetVarParameter()
const char *  method
◆ UpdateAsMeshesRestored()
◆ myBaseImpl
Referenced by StdMeshers_NumberOfSegments_i::BuildDistributionExpr(), StdMeshers_NumberOfSegments_i::BuildDistributionTab(), StdMeshers_NumberOfSegments_i::ConversionMode(), StdMeshers_NumberOfSegments_i::GetBeta(), SMESH_Algo_i::GetCompatibleHypothesis(), StdMeshers_Adaptive1D_i::GetDeflection(), StdMeshers_Deflection1D_i::GetDeflection(), StdMeshers_NumberOfSegments_i::GetDistrType(), StdMeshers_NumberOfSegments_i::GetExpressionFunction(), StdMeshers_AutomaticLength_i::GetFineness(), GetGrid(), GetGridSpacing(), SMESH_Hypothesis_i::GetId(), SMESH_Hypothesis_i::GetImpl(), StdMeshers_Adaptive1D_i::GetImpl(), StdMeshers_Arithmetic1D_i::GetImpl(), StdMeshers_AutomaticLength_i::GetImpl(), StdMeshers_BlockRenumber_i::GetImpl(), StdMeshers_Cartesian_3D_i::GetImpl(), GetImpl(), StdMeshers_CompositeSegment_1D_i::GetImpl(), StdMeshers_Deflection1D_i::GetImpl(), StdMeshers_FixedPoints1D_i::GetImpl(), StdMeshers_Geometric1D_i::GetImpl(), StdMeshers_Hexa_3D_i::GetImpl(), StdMeshers_Import_1D2D_i::GetImpl(), StdMeshers_Import_1D_i::GetImpl(), StdMeshers_ImportSource1D_i::GetImpl(), StdMeshers_ImportSource2D_i::GetImpl(), StdMeshers_LayerDistribution2D_i::GetImpl(), StdMeshers_LayerDistribution_i::GetImpl(), StdMeshers_LengthFromEdges_i::GetImpl(), StdMeshers_LocalLength_i::GetImpl(), StdMeshers_MaxElementArea_i::GetImpl(), StdMeshers_MaxElementVolume_i::GetImpl(), StdMeshers_MaxLength_i::GetImpl(), StdMeshers_NumberOfLayers2D_i::GetImpl(), StdMeshers_NumberOfLayers_i::GetImpl(), StdMeshers_NumberOfSegments_i::GetImpl(), StdMeshers_Prism_3D_i::GetImpl(), StdMeshers_RadialPrism_3D_i::GetImpl(), StdMeshers_Projection_3D_i::GetImpl(), StdMeshers_Projection_2D_i::GetImpl(), StdMeshers_Projection_1D2D_i::GetImpl(), StdMeshers_Projection_1D_i::GetImpl(), StdMeshers_ProjectionSource1D_i::GetImpl(), StdMeshers_ProjectionSource2D_i::GetImpl(), StdMeshers_ProjectionSource3D_i::GetImpl(), StdMeshers_Quadrangle_2D_i::GetImpl(), StdMeshers_QuadrangleParams_i::GetImpl(), StdMeshers_QuadranglePreference_i::GetImpl(), StdMeshers_QuadraticMesh_i::GetImpl(), StdMeshers_RadialQuadrangle_1D2D_i::GetImpl(), StdMeshers_Regular_1D_i::GetImpl(), StdMeshers_SegmentAroundVertex_0D_i::GetImpl(), StdMeshers_SegmentLengthAroundVertex_i::GetImpl(), StdMeshers_StartEndLength_i::GetImpl(), StdMeshers_UseExisting_1D_i::GetImpl(), StdMeshers_UseExisting_2D_i::GetImpl(), StdMeshers_ViscousLayerBuilder_i::GetImpl(), StdMeshers_ViscousLayers2D_i::GetImpl(), StdMeshers_ViscousLayers_i::GetImpl(), StdMeshers_LocalLength_i::GetLength(), StdMeshers_MaxLength_i::GetLength(), StdMeshers_SegmentLengthAroundVertex_i::GetLength(), StdMeshers_Arithmetic1D_i::GetLength(), StdMeshers_StartEndLength_i::GetLength(), SMESH_Hypothesis_i::GetLibName(), StdMeshers_MaxElementArea_i::GetMaxElementArea(), StdMeshers_MaxElementVolume_i::GetMaxElementVolume(), StdMeshers_Adaptive1D_i::GetMaxSize(), StdMeshers_Adaptive1D_i::GetMinSize(), StdMeshers_LengthFromEdges_i::GetMode(), SMESH_Hypothesis_i::GetName(), StdMeshers_FixedPoints1D_i::GetNbSegments(), StdMeshers_NumberOfLayers_i::GetNumberOfLayers(), StdMeshers_NumberOfSegments_i::GetNumberOfSegments(), StdMeshers_QuadrangleParams_i::GetObjectEntry(), StdMeshers_QuadrangleParams_i::getObjectsDependOn(), StdMeshers_ViscousLayers2D_i::getObjectsDependOn(), StdMeshers_ViscousLayers_i::getObjectsDependOn(), StdMeshers_FixedPoints1D_i::GetPoints(), StdMeshers_LocalLength_i::GetPrecision(), StdMeshers_MaxLength_i::GetPreestimatedLength(), StdMeshers_QuadrangleParams_i::GetQuadType(), StdMeshers_NumberOfSegments_i::GetScaleFactor(), StdMeshers_ProjectionSource3D_i::GetSource3DShape(), StdMeshers_ProjectionSource1D_i::GetSourceEdge(), StdMeshers_ProjectionSource2D_i::GetSourceFace(), StdMeshers_ProjectionSource1D_i::GetSourceVertex(), StdMeshers_ProjectionSource2D_i::GetSourceVertex(), StdMeshers_ProjectionSource3D_i::GetSourceVertex(), StdMeshers_NumberOfSegments_i::GetTableFunction(), StdMeshers_ProjectionSource1D_i::GetTargetVertex(), StdMeshers_ProjectionSource2D_i::GetTargetVertex(), StdMeshers_ProjectionSource3D_i::GetTargetVertex(), StdMeshers_QuadrangleParams_i::GetTriaVertex(), StdMeshers_MaxLength_i::GetUsePreestimatedLength(), SMESH_Hypothesis_i::HasParameters(), StdMeshers_MaxLength_i::HavePreestimatedLength(), SMESH_Hypothesis_i::LoadFrom(), StdMeshers_ImportSource1D_i::LoadFrom(), StdMeshers_ImportSource2D_i::LoadFrom(), StdMeshers_LayerDistribution_i::LoadFrom(), StdMeshers_ProjectionSource1D_i::LoadFrom(), StdMeshers_ProjectionSource2D_i::LoadFrom(), StdMeshers_ProjectionSource3D_i::LoadFrom(), StdMeshers_QuadrangleParams_i::LoadFrom(), SMESH_Hypothesis_i::SaveTo(), StdMeshers_ImportSource1D_i::SaveTo(), StdMeshers_ImportSource2D_i::SaveTo(), StdMeshers_LayerDistribution_i::SaveTo(), StdMeshers_ProjectionSource1D_i::SaveTo(), StdMeshers_ProjectionSource2D_i::SaveTo(), StdMeshers_ProjectionSource3D_i::SaveTo(), StdMeshers_QuadrangleParams_i::SaveTo(), StdMeshers_NumberOfSegments_i::SetBeta(), StdMeshers_NumberOfSegments_i::SetConversionMode(), StdMeshers_Adaptive1D_i::SetDeflection(), StdMeshers_Deflection1D_i::SetDeflection(), StdMeshers_NumberOfSegments_i::SetDistrType(), StdMeshers_NumberOfSegments_i::SetExpressionFunction(), StdMeshers_AutomaticLength_i::SetFineness(), SetGrid(), SetGridSpacing(), StdMeshers_LayerDistribution_i::SetLayerDistribution(), StdMeshers_LocalLength_i::SetLength(), StdMeshers_MaxLength_i::SetLength(), StdMeshers_SegmentLengthAroundVertex_i::SetLength(), StdMeshers_Arithmetic1D_i::SetLength(), StdMeshers_StartEndLength_i::SetLength(), SMESH_Hypothesis_i::SetLibName(), StdMeshers_MaxElementArea_i::SetMaxElementArea(), StdMeshers_MaxElementVolume_i::SetMaxElementVolume(), StdMeshers_Adaptive1D_i::SetMaxSize(), StdMeshers_Adaptive1D_i::SetMinSize(), StdMeshers_LengthFromEdges_i::SetMode(), StdMeshers_FixedPoints1D_i::SetNbSegments(), StdMeshers_NumberOfLayers_i::SetNumberOfLayers(), StdMeshers_NumberOfSegments_i::SetNumberOfSegments(), StdMeshers_QuadrangleParams_i::SetObjectEntry(), StdMeshers_FixedPoints1D_i::SetPoints(), StdMeshers_LocalLength_i::SetPrecision(), StdMeshers_MaxLength_i::SetPreestimatedLength(), StdMeshers_QuadrangleParams_i::SetQuadType(), SetQuanta(), StdMeshers_NumberOfSegments_i::SetScaleFactor(), SetSizeThreshold(), StdMeshers_ProjectionSource3D_i::SetSource3DShape(), StdMeshers_ProjectionSource1D_i::SetSourceEdge(), StdMeshers_ImportSource1D_i::SetSourceEdges(), StdMeshers_ProjectionSource2D_i::SetSourceFace(), StdMeshers_ImportSource2D_i::SetSourceFaces(), StdMeshers_ProjectionSource1D_i::SetSourceMesh(), StdMeshers_ProjectionSource2D_i::SetSourceMesh(), StdMeshers_ProjectionSource3D_i::SetSourceMesh(), StdMeshers_NumberOfSegments_i::SetTableFunction(), StdMeshers_QuadrangleParams_i::SetTriaVertex(), StdMeshers_MaxLength_i::SetUsePreestimatedLength(), StdMeshers_ProjectionSource1D_i::SetVertexAssociation(), StdMeshers_ProjectionSource2D_i::SetVertexAssociation(), StdMeshers_ProjectionSource3D_i::SetVertexAssociation(), SMESH_Hypothesis_i::SMESH_Hypothesis_i(), StdMeshers_Adaptive1D_i::StdMeshers_Adaptive1D_i(), StdMeshers_Arithmetic1D_i::StdMeshers_Arithmetic1D_i(), StdMeshers_AutomaticLength_i::StdMeshers_AutomaticLength_i(), StdMeshers_BlockRenumber_i::StdMeshers_BlockRenumber_i(), StdMeshers_Cartesian_3D_i::StdMeshers_Cartesian_3D_i(), StdMeshers_CartesianParameters3D_i(), StdMeshers_CompositeSegment_1D_i::StdMeshers_CompositeSegment_1D_i(), StdMeshers_Deflection1D_i::StdMeshers_Deflection1D_i(), StdMeshers_FixedPoints1D_i::StdMeshers_FixedPoints1D_i(), StdMeshers_Geometric1D_i::StdMeshers_Geometric1D_i(), StdMeshers_Hexa_3D_i::StdMeshers_Hexa_3D_i(), StdMeshers_Import_1D2D_i::StdMeshers_Import_1D2D_i(), StdMeshers_Import_1D_i::StdMeshers_Import_1D_i(), StdMeshers_ImportSource1D_i::StdMeshers_ImportSource1D_i(), StdMeshers_ImportSource2D_i::StdMeshers_ImportSource2D_i(), StdMeshers_LayerDistribution2D_i::StdMeshers_LayerDistribution2D_i(), StdMeshers_LayerDistribution_i::StdMeshers_LayerDistribution_i(), StdMeshers_LengthFromEdges_i::StdMeshers_LengthFromEdges_i(), StdMeshers_LocalLength_i::StdMeshers_LocalLength_i(), StdMeshers_MaxElementArea_i::StdMeshers_MaxElementArea_i(), StdMeshers_MaxElementVolume_i::StdMeshers_MaxElementVolume_i(), StdMeshers_MaxLength_i::StdMeshers_MaxLength_i(), StdMeshers_NotConformAllowed_i::StdMeshers_NotConformAllowed_i(), StdMeshers_NumberOfLayers2D_i::StdMeshers_NumberOfLayers2D_i(), StdMeshers_NumberOfLayers_i::StdMeshers_NumberOfLayers_i(), StdMeshers_NumberOfSegments_i::StdMeshers_NumberOfSegments_i(), StdMeshers_PolygonPerFace_2D_i::StdMeshers_PolygonPerFace_2D_i(), StdMeshers_PolyhedronPerSolid_3D_i::StdMeshers_PolyhedronPerSolid_3D_i(), StdMeshers_Prism_3D_i::StdMeshers_Prism_3D_i(), StdMeshers_Projection_1D2D_i::StdMeshers_Projection_1D2D_i(), StdMeshers_Projection_1D_i::StdMeshers_Projection_1D_i(), StdMeshers_Projection_2D_i::StdMeshers_Projection_2D_i(), StdMeshers_Projection_3D_i::StdMeshers_Projection_3D_i(), StdMeshers_ProjectionSource1D_i::StdMeshers_ProjectionSource1D_i(), StdMeshers_ProjectionSource2D_i::StdMeshers_ProjectionSource2D_i(), StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i(), StdMeshers_Propagation_i::StdMeshers_Propagation_i(), StdMeshers_PropagOfDistribution_i::StdMeshers_PropagOfDistribution_i(), StdMeshers_QuadFromMedialAxis_1D2D_i::StdMeshers_QuadFromMedialAxis_1D2D_i(), StdMeshers_Quadrangle_2D_i::StdMeshers_Quadrangle_2D_i(), StdMeshers_QuadrangleParams_i::StdMeshers_QuadrangleParams_i(), StdMeshers_QuadranglePreference_i::StdMeshers_QuadranglePreference_i(), StdMeshers_QuadraticMesh_i::StdMeshers_QuadraticMesh_i(), StdMeshers_RadialPrism_3D_i::StdMeshers_RadialPrism_3D_i(), StdMeshers_RadialQuadrangle_1D2D_i::StdMeshers_RadialQuadrangle_1D2D_i(), StdMeshers_Regular_1D_i::StdMeshers_Regular_1D_i(), StdMeshers_SegmentAroundVertex_0D_i::StdMeshers_SegmentAroundVertex_0D_i(), StdMeshers_SegmentLengthAroundVertex_i::StdMeshers_SegmentLengthAroundVertex_i(), StdMeshers_StartEndLength_i::StdMeshers_StartEndLength_i(), StdMeshers_UseExisting_1D_i::StdMeshers_UseExisting_1D_i(), StdMeshers_UseExisting_2D_i::StdMeshers_UseExisting_2D_i(), StdMeshers_ViscousLayerBuilder_i::StdMeshers_ViscousLayerBuilder_i(), StdMeshers_ViscousLayers2D_i::StdMeshers_ViscousLayers2D_i(), StdMeshers_ViscousLayers_i::StdMeshers_ViscousLayers_i(), and SMESH_Hypothesis_i::~SMESH_Hypothesis_i().
◆ myHolder
◆ myMethod2VarParams
