StdMeshers_ProjectionSource3D_i Class Reference
This hypothesis specifies a meshed shell or solid to take a mesh pattern from and optionally association of vertices between the source shape and a target one (where a hypothesis is assigned to) More...
#include <StdMeshers_ProjectionSource3D_i.hxx>
Inheritance diagram for StdMeshers_ProjectionSource3D_i:
 StdMeshers_ProjectionSource3D_i (PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
 StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i. More...
virtual ~StdMeshers_ProjectionSource3D_i ()
 StdMeshers_ProjectionSource3D_i::~StdMeshers_ProjectionSource3D_i. More...
void SetSource3DShape (GEOM::GEOM_Object_ptr shape)
 Sets a source <shape> to take a mesh pattern from. More...
GEOM::GEOM_Object_ptr GetSource3DShape ()
 Returns the source shape. More...
void SetSourceMesh (SMESH::SMESH_Mesh_ptr mesh)
 Sets source <mesh> to take a mesh pattern from. More...
SMESH::SMESH_Mesh_ptr GetSourceMesh ()
 Return source mesh. More...
void SetVertexAssociation (GEOM::GEOM_Object_ptr sourceVertex1, GEOM::GEOM_Object_ptr sourceVertex2, GEOM::GEOM_Object_ptr targetVertex1, GEOM::GEOM_Object_ptr targetVertex2)
 Sets vertex association between the source shape and the target one. More...
GEOM::GEOM_Object_ptr GetSourceVertex (CORBA::Long i)
 Returns the -th source vertex associated with the -th target vertex. More...
GEOM::GEOM_Object_ptr GetTargetVertex (CORBA::Long i)
 Returns the -th target vertex associated with the -th source vertex. More...
::StdMeshers_ProjectionSource3D * GetImpl ()
 StdMeshers_ProjectionSource3D_i::GetImpl. More...
virtual char * SaveTo ()
 Write parameters in a string. More...
 Retrieve parameters from the string. More...
virtual char * GetName ()
virtual char * GetLibName ()
virtual CORBA::Short GetId ()
bool IsPublished ()
Private Types
enum  {
  SRC_SHAPE3D =0 , SRC_VERTEX1 , SRC_VERTEX2 , TGT_VERTEX1 ,
  TGT_VERTEX2 , NB_SHAPES
std::string myShapeEntries [NB_SHAPES]
SMESH::SMESH_Mesh_var myCorbaMesh
◆ anonymous enum
anonymous enum
SRC_SHAPE3D
SRC_VERTEX1
SRC_VERTEX2
TGT_VERTEX1
TGT_VERTEX2
NB_SHAPES
◆ StdMeshers_ProjectionSource3D_i()
StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i ( PortableServer::POA_ptr  thePOA,
::SMESH_Gen *  theGenImpl
◆ ~StdMeshers_ProjectionSource3D_i()
StdMeshers_ProjectionSource3D_i::~StdMeshers_ProjectionSource3D_i ( )
◆ GetId()
◆ GetImpl()
◆ GetLibName()
◆ getMethodOfParameter()
◆ GetName()
◆ getObjectsDependOn()
bool StdMeshers_ProjectionSource3D_i::getObjectsDependOn ( std::vector< std::string > &  entryArray,
References myShapeEntries, and NB_SHAPES.
◆ getParamIndex()
int
◆ GetSource3DShape()
GEOM::GEOM_Object_ptr StdMeshers_ProjectionSource3D_i::GetSource3DShape ( )
◆ GetSourceMesh()
SMESH::SMESH_Mesh_ptr StdMeshers_ProjectionSource3D_i::GetSourceMesh ( )
Return source mesh.
References myCorbaMesh.
Referenced by SaveTo().
◆ GetSourceVertex()
GEOM::GEOM_Object_ptr StdMeshers_ProjectionSource3D_i::GetSourceVertex ( CORBA::Long  i)
Returns the vertex associated with the target vertex.
Result may be nil if association not set. Valid indices are 1 and 2
References StdMeshers_ObjRefUlils::EntryOrShapeToGeomObject(), GetImpl(), GetSourceVertex(), SMESH_Hypothesis_i::myBaseImpl, myShapeEntries, SRC_VERTEX1, and SRC_VERTEX2.
Referenced by GetSourceVertex().
◆ GetTargetVertex()
GEOM::GEOM_Object_ptr StdMeshers_ProjectionSource3D_i::GetTargetVertex ( CORBA::Long  i)
References StdMeshers_ObjRefUlils::EntryOrShapeToGeomObject(), GetImpl(), GetTargetVertex(), SMESH_Hypothesis_i::myBaseImpl, myShapeEntries, TGT_VERTEX1, and TGT_VERTEX2.
Referenced by GetTargetVertex().
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
CORBA::Boolean StdMeshers_ProjectionSource3D_i::IsDimSupported ( SMESH::Dimension  type)
References SMESH::DIM_3D.
◆ IsPublished()
◆ LoadFrom()
◆ SaveTo()
char * StdMeshers_ProjectionSource3D_i::SaveTo ( )
char*- resulting string
References GetSourceMesh(), SMESH_Hypothesis_i::myBaseImpl, myShapeEntries, NB_SHAPES, SMESHDS_Hypothesis::SaveTo(), and StdMeshers_ObjRefUlils::SaveToStream().
◆ SetHolderHypothesis()
◆ SetLibName()
◆ setObjectsDependOn()
bool StdMeshers_ProjectionSource3D_i::setObjectsDependOn ( std::vector< std::string > &  entryArray,
◆ setOldParameters()
◆ SetSource3DShape()
void StdMeshers_ProjectionSource3D_i::SetSource3DShape ( GEOM::GEOM_Object_ptr  shape)
Sets a source <face> to take a mesh pattern from.
References StdMeshers_ObjRefUlils::GeomObjectToShape(), GetImpl(), SMESH_Hypothesis_i::myBaseImpl, myShapeEntries, StdMeshers_ProjectionSource3D::SetSource3DShape(), and SRC_SHAPE3D.
◆ SetSourceMesh()
void StdMeshers_ProjectionSource3D_i::SetSourceMesh ( SMESH::SMESH_Mesh_ptr  mesh)
◆ SetVarParameter()
const char *  method
◆ SetVertexAssociation()
void StdMeshers_ProjectionSource3D_i::SetVertexAssociation ( GEOM::GEOM_Object_ptr  sourceVertex1,
This parameter is optional. Two vertices must belong to one edge of a shape
References StdMeshers_ObjRefUlils::GeomObjectToEntry(), StdMeshers_ObjRefUlils::GeomObjectToShape(), GetImpl(), SMESH_Hypothesis_i::myBaseImpl, myShapeEntries, StdMeshers_ProjectionSource3D::SetVertexAssociation(), SRC_VERTEX1, SRC_VERTEX2, TGT_VERTEX1, and TGT_VERTEX2.
◆ UpdateAsMeshesRestored()
◆ myBaseImpl
Referenced by StdMeshers_NumberOfSegments_i::BuildDistributionExpr(), StdMeshers_NumberOfSegments_i::BuildDistributionTab(), StdMeshers_NumberOfSegments_i::ConversionMode(), StdMeshers_NumberOfSegments_i::GetBeta(), SMESH_Algo_i::GetCompatibleHypothesis(), StdMeshers_Adaptive1D_i::GetDeflection(), StdMeshers_Deflection1D_i::GetDeflection(), StdMeshers_NumberOfSegments_i::GetDistrType(), StdMeshers_NumberOfSegments_i::GetExpressionFunction(), StdMeshers_AutomaticLength_i::GetFineness(), StdMeshers_CartesianParameters3D_i::GetGrid(), StdMeshers_CartesianParameters3D_i::GetGridSpacing(), SMESH_Hypothesis_i::GetId(), SMESH_Hypothesis_i::GetImpl(), StdMeshers_Adaptive1D_i::GetImpl(), StdMeshers_Arithmetic1D_i::GetImpl(), StdMeshers_AutomaticLength_i::GetImpl(), StdMeshers_BlockRenumber_i::GetImpl(), StdMeshers_Cartesian_3D_i::GetImpl(), StdMeshers_CartesianParameters3D_i::GetImpl(), StdMeshers_CompositeSegment_1D_i::GetImpl(), StdMeshers_Deflection1D_i::GetImpl(), StdMeshers_FixedPoints1D_i::GetImpl(), StdMeshers_Geometric1D_i::GetImpl(), StdMeshers_Hexa_3D_i::GetImpl(), StdMeshers_Import_1D2D_i::GetImpl(), StdMeshers_Import_1D_i::GetImpl(), StdMeshers_ImportSource1D_i::GetImpl(), StdMeshers_ImportSource2D_i::GetImpl(), StdMeshers_LayerDistribution2D_i::GetImpl(), StdMeshers_LayerDistribution_i::GetImpl(), StdMeshers_LengthFromEdges_i::GetImpl(), StdMeshers_LocalLength_i::GetImpl(), StdMeshers_MaxElementArea_i::GetImpl(), StdMeshers_MaxElementVolume_i::GetImpl(), StdMeshers_MaxLength_i::GetImpl(), StdMeshers_NumberOfLayers2D_i::GetImpl(), StdMeshers_NumberOfLayers_i::GetImpl(), StdMeshers_NumberOfSegments_i::GetImpl(), StdMeshers_Prism_3D_i::GetImpl(), StdMeshers_RadialPrism_3D_i::GetImpl(), StdMeshers_Projection_3D_i::GetImpl(), StdMeshers_Projection_2D_i::GetImpl(), StdMeshers_Projection_1D2D_i::GetImpl(), StdMeshers_Projection_1D_i::GetImpl(), StdMeshers_ProjectionSource1D_i::GetImpl(), StdMeshers_ProjectionSource2D_i::GetImpl(), GetImpl(), StdMeshers_Quadrangle_2D_i::GetImpl(), StdMeshers_QuadrangleParams_i::GetImpl(), StdMeshers_QuadranglePreference_i::GetImpl(), StdMeshers_QuadraticMesh_i::GetImpl(), StdMeshers_RadialQuadrangle_1D2D_i::GetImpl(), StdMeshers_Regular_1D_i::GetImpl(), StdMeshers_SegmentAroundVertex_0D_i::GetImpl(), StdMeshers_SegmentLengthAroundVertex_i::GetImpl(), StdMeshers_StartEndLength_i::GetImpl(), StdMeshers_UseExisting_1D_i::GetImpl(), StdMeshers_UseExisting_2D_i::GetImpl(), StdMeshers_ViscousLayerBuilder_i::GetImpl(), StdMeshers_ViscousLayers2D_i::GetImpl(), StdMeshers_ViscousLayers_i::GetImpl(), StdMeshers_LocalLength_i::GetLength(), StdMeshers_MaxLength_i::GetLength(), StdMeshers_SegmentLengthAroundVertex_i::GetLength(), StdMeshers_Arithmetic1D_i::GetLength(), StdMeshers_StartEndLength_i::GetLength(), SMESH_Hypothesis_i::GetLibName(), StdMeshers_MaxElementArea_i::GetMaxElementArea(), StdMeshers_MaxElementVolume_i::GetMaxElementVolume(), StdMeshers_Adaptive1D_i::GetMaxSize(), StdMeshers_Adaptive1D_i::GetMinSize(), StdMeshers_LengthFromEdges_i::GetMode(), SMESH_Hypothesis_i::GetName(), StdMeshers_FixedPoints1D_i::GetNbSegments(), StdMeshers_NumberOfLayers_i::GetNumberOfLayers(), StdMeshers_NumberOfSegments_i::GetNumberOfSegments(), StdMeshers_QuadrangleParams_i::GetObjectEntry(), StdMeshers_QuadrangleParams_i::getObjectsDependOn(), StdMeshers_ViscousLayers2D_i::getObjectsDependOn(), StdMeshers_ViscousLayers_i::getObjectsDependOn(), StdMeshers_FixedPoints1D_i::GetPoints(), StdMeshers_LocalLength_i::GetPrecision(), StdMeshers_MaxLength_i::GetPreestimatedLength(), StdMeshers_QuadrangleParams_i::GetQuadType(), StdMeshers_NumberOfSegments_i::GetScaleFactor(), GetSource3DShape(), StdMeshers_ProjectionSource1D_i::GetSourceEdge(), StdMeshers_ProjectionSource2D_i::GetSourceFace(), StdMeshers_ProjectionSource1D_i::GetSourceVertex(), StdMeshers_ProjectionSource2D_i::GetSourceVertex(), GetSourceVertex(), StdMeshers_NumberOfSegments_i::GetTableFunction(), StdMeshers_ProjectionSource1D_i::GetTargetVertex(), StdMeshers_ProjectionSource2D_i::GetTargetVertex(), GetTargetVertex(), StdMeshers_QuadrangleParams_i::GetTriaVertex(), StdMeshers_MaxLength_i::GetUsePreestimatedLength(), SMESH_Hypothesis_i::HasParameters(), StdMeshers_MaxLength_i::HavePreestimatedLength(), SMESH_Hypothesis_i::LoadFrom(), StdMeshers_ImportSource1D_i::LoadFrom(), StdMeshers_ImportSource2D_i::LoadFrom(), StdMeshers_LayerDistribution_i::LoadFrom(), StdMeshers_ProjectionSource1D_i::LoadFrom(), StdMeshers_ProjectionSource2D_i::LoadFrom(), LoadFrom(), StdMeshers_QuadrangleParams_i::LoadFrom(), SMESH_Hypothesis_i::SaveTo(), StdMeshers_ImportSource1D_i::SaveTo(), StdMeshers_ImportSource2D_i::SaveTo(), StdMeshers_LayerDistribution_i::SaveTo(), StdMeshers_ProjectionSource1D_i::SaveTo(), StdMeshers_ProjectionSource2D_i::SaveTo(), SaveTo(), StdMeshers_QuadrangleParams_i::SaveTo(), StdMeshers_NumberOfSegments_i::SetBeta(), StdMeshers_NumberOfSegments_i::SetConversionMode(), StdMeshers_Adaptive1D_i::SetDeflection(), StdMeshers_Deflection1D_i::SetDeflection(), StdMeshers_NumberOfSegments_i::SetDistrType(), StdMeshers_NumberOfSegments_i::SetExpressionFunction(), StdMeshers_AutomaticLength_i::SetFineness(), StdMeshers_CartesianParameters3D_i::SetGrid(), StdMeshers_CartesianParameters3D_i::SetGridSpacing(), StdMeshers_LayerDistribution_i::SetLayerDistribution(), StdMeshers_LocalLength_i::SetLength(), StdMeshers_MaxLength_i::SetLength(), StdMeshers_SegmentLengthAroundVertex_i::SetLength(), StdMeshers_Arithmetic1D_i::SetLength(), StdMeshers_StartEndLength_i::SetLength(), SMESH_Hypothesis_i::SetLibName(), StdMeshers_MaxElementArea_i::SetMaxElementArea(), StdMeshers_MaxElementVolume_i::SetMaxElementVolume(), StdMeshers_Adaptive1D_i::SetMaxSize(), StdMeshers_Adaptive1D_i::SetMinSize(), StdMeshers_LengthFromEdges_i::SetMode(), StdMeshers_FixedPoints1D_i::SetNbSegments(), StdMeshers_NumberOfLayers_i::SetNumberOfLayers(), StdMeshers_NumberOfSegments_i::SetNumberOfSegments(), StdMeshers_QuadrangleParams_i::SetObjectEntry(), StdMeshers_FixedPoints1D_i::SetPoints(), StdMeshers_LocalLength_i::SetPrecision(), StdMeshers_MaxLength_i::SetPreestimatedLength(), StdMeshers_QuadrangleParams_i::SetQuadType(), StdMeshers_CartesianParameters3D_i::SetQuanta(), StdMeshers_NumberOfSegments_i::SetScaleFactor(), StdMeshers_CartesianParameters3D_i::SetSizeThreshold(), SetSource3DShape(), StdMeshers_ProjectionSource1D_i::SetSourceEdge(), StdMeshers_ImportSource1D_i::SetSourceEdges(), StdMeshers_ProjectionSource2D_i::SetSourceFace(), StdMeshers_ImportSource2D_i::SetSourceFaces(), StdMeshers_ProjectionSource1D_i::SetSourceMesh(), StdMeshers_ProjectionSource2D_i::SetSourceMesh(), SetSourceMesh(), StdMeshers_NumberOfSegments_i::SetTableFunction(), StdMeshers_QuadrangleParams_i::SetTriaVertex(), StdMeshers_MaxLength_i::SetUsePreestimatedLength(), StdMeshers_ProjectionSource1D_i::SetVertexAssociation(), StdMeshers_ProjectionSource2D_i::SetVertexAssociation(), SetVertexAssociation(), SMESH_Hypothesis_i::SMESH_Hypothesis_i(), StdMeshers_Adaptive1D_i::StdMeshers_Adaptive1D_i(), StdMeshers_Arithmetic1D_i::StdMeshers_Arithmetic1D_i(), StdMeshers_AutomaticLength_i::StdMeshers_AutomaticLength_i(), StdMeshers_BlockRenumber_i::StdMeshers_BlockRenumber_i(), StdMeshers_Cartesian_3D_i::StdMeshers_Cartesian_3D_i(), StdMeshers_CartesianParameters3D_i::StdMeshers_CartesianParameters3D_i(), StdMeshers_CompositeSegment_1D_i::StdMeshers_CompositeSegment_1D_i(), StdMeshers_Deflection1D_i::StdMeshers_Deflection1D_i(), StdMeshers_FixedPoints1D_i::StdMeshers_FixedPoints1D_i(), StdMeshers_Geometric1D_i::StdMeshers_Geometric1D_i(), StdMeshers_Hexa_3D_i::StdMeshers_Hexa_3D_i(), StdMeshers_Import_1D2D_i::StdMeshers_Import_1D2D_i(), StdMeshers_Import_1D_i::StdMeshers_Import_1D_i(), StdMeshers_ImportSource1D_i::StdMeshers_ImportSource1D_i(), StdMeshers_ImportSource2D_i::StdMeshers_ImportSource2D_i(), StdMeshers_LayerDistribution2D_i::StdMeshers_LayerDistribution2D_i(), StdMeshers_LayerDistribution_i::StdMeshers_LayerDistribution_i(), StdMeshers_LengthFromEdges_i::StdMeshers_LengthFromEdges_i(), StdMeshers_LocalLength_i::StdMeshers_LocalLength_i(), StdMeshers_MaxElementArea_i::StdMeshers_MaxElementArea_i(), StdMeshers_MaxElementVolume_i::StdMeshers_MaxElementVolume_i(), StdMeshers_MaxLength_i::StdMeshers_MaxLength_i(), StdMeshers_NotConformAllowed_i::StdMeshers_NotConformAllowed_i(), StdMeshers_NumberOfLayers2D_i::StdMeshers_NumberOfLayers2D_i(), StdMeshers_NumberOfLayers_i::StdMeshers_NumberOfLayers_i(), StdMeshers_NumberOfSegments_i::StdMeshers_NumberOfSegments_i(), StdMeshers_PolygonPerFace_2D_i::StdMeshers_PolygonPerFace_2D_i(), StdMeshers_PolyhedronPerSolid_3D_i::StdMeshers_PolyhedronPerSolid_3D_i(), StdMeshers_Prism_3D_i::StdMeshers_Prism_3D_i(), StdMeshers_Projection_1D2D_i::StdMeshers_Projection_1D2D_i(), StdMeshers_Projection_1D_i::StdMeshers_Projection_1D_i(), StdMeshers_Projection_2D_i::StdMeshers_Projection_2D_i(), StdMeshers_Projection_3D_i::StdMeshers_Projection_3D_i(), StdMeshers_ProjectionSource1D_i::StdMeshers_ProjectionSource1D_i(), StdMeshers_ProjectionSource2D_i::StdMeshers_ProjectionSource2D_i(), StdMeshers_ProjectionSource3D_i(), StdMeshers_Propagation_i::StdMeshers_Propagation_i(), StdMeshers_PropagOfDistribution_i::StdMeshers_PropagOfDistribution_i(), StdMeshers_QuadFromMedialAxis_1D2D_i::StdMeshers_QuadFromMedialAxis_1D2D_i(), StdMeshers_Quadrangle_2D_i::StdMeshers_Quadrangle_2D_i(), StdMeshers_QuadrangleParams_i::StdMeshers_QuadrangleParams_i(), StdMeshers_QuadranglePreference_i::StdMeshers_QuadranglePreference_i(), StdMeshers_QuadraticMesh_i::StdMeshers_QuadraticMesh_i(), StdMeshers_RadialPrism_3D_i::StdMeshers_RadialPrism_3D_i(), StdMeshers_RadialQuadrangle_1D2D_i::StdMeshers_RadialQuadrangle_1D2D_i(), StdMeshers_Regular_1D_i::StdMeshers_Regular_1D_i(), StdMeshers_SegmentAroundVertex_0D_i::StdMeshers_SegmentAroundVertex_0D_i(), StdMeshers_SegmentLengthAroundVertex_i::StdMeshers_SegmentLengthAroundVertex_i(), StdMeshers_StartEndLength_i::StdMeshers_StartEndLength_i(), StdMeshers_UseExisting_1D_i::StdMeshers_UseExisting_1D_i(), StdMeshers_UseExisting_2D_i::StdMeshers_UseExisting_2D_i(), StdMeshers_ViscousLayerBuilder_i::StdMeshers_ViscousLayerBuilder_i(), StdMeshers_ViscousLayers2D_i::StdMeshers_ViscousLayers2D_i(), StdMeshers_ViscousLayers_i::StdMeshers_ViscousLayers_i(), and SMESH_Hypothesis_i::~SMESH_Hypothesis_i().
◆ myCorbaMesh
SMESH::SMESH_Mesh_var StdMeshers_ProjectionSource3D_i::myCorbaMesh
◆ myHolder
◆ myMethod2VarParams
◆ myShapeEntries
std::string StdMeshers_ProjectionSource3D_i::myShapeEntries[NB_SHAPES]
