StdMeshers_ProjectionSource3D_i.hxx
24// File : StdMeshers_ProjectionSource3D_i.hxx
25// Author : Edward AGAPOV
26// Module : SMESH
27// $Header$
28//
29#ifndef _SMESH_ProjectionSource3D_I_HXX_
30#define _SMESH_ProjectionSource3D_I_HXX_
31
32#include <SALOMEconfig.h>
33#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
34#include CORBA_SERVER_HEADER(SMESH_Mesh)
35
38
39class SMESH_Gen;
40
41// =========================================================
47// =========================================================
48
50 public virtual POA_StdMeshers::StdMeshers_ProjectionSource3D,
51 public virtual SMESH_Hypothesis_i
52{
53public:
54 // Constructor
55 StdMeshers_ProjectionSource3D_i( PortableServer::POA_ptr thePOA,
56 ::SMESH_Gen* theGenImpl );
57 // Destructor
59
63 void SetSource3DShape(GEOM::GEOM_Object_ptr shape);
64
68 GEOM::GEOM_Object_ptr GetSource3DShape();
69
73 void SetSourceMesh(SMESH::SMESH_Mesh_ptr mesh);
74
78 SMESH::SMESH_Mesh_ptr GetSourceMesh();
79
85 void SetVertexAssociation(GEOM::GEOM_Object_ptr sourceVertex1,
86 GEOM::GEOM_Object_ptr sourceVertex2,
87 GEOM::GEOM_Object_ptr targetVertex1,
88 GEOM::GEOM_Object_ptr targetVertex2);
89
95 GEOM::GEOM_Object_ptr GetSourceVertex(CORBA::Long i);
96
101 GEOM::GEOM_Object_ptr GetTargetVertex(CORBA::Long i);
102
103 // Get implementation
105
106 // Verify whether hypothesis supports given entity type
107 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
108
109
110 // Redefined Persistence
111 virtual char* SaveTo();
112 virtual void LoadFrom( const char* theStream );
113
114
115 // Methods for copying mesh definition to other geometry
116
117 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
118 virtual bool getObjectsDependOn( std::vector< std::string > & entryArray,
119 std::vector< int > & subIDArray ) const;
120
121 // Set new geometry instead of that returned by getObjectsDependOn()
122 virtual bool setObjectsDependOn( std::vector< std::string > & entryArray,
123 std::vector< int > & subIDArray );
124
125private:
126 // keep entries because the same shape can be published several times with
127 // different names and in this case a correct name can't be restored by a TopoDS_Shape
128 // kept by ::StdMeshers_ProjectionSource3D
131 SMESH::SMESH_Mesh_var myCorbaMesh;
132};
133
134#endif
Definition: SMESH_Gen.hxx:68
This hypothesis specifies a meshed shell or solid to take a mesh pattern from and optionally associat...
Definition: StdMeshers_ProjectionSource3D_i.hxx:52
std::string myShapeEntries[NB_SHAPES]
Definition: StdMeshers_ProjectionSource3D_i.hxx:130
Definition: StdMeshers_ProjectionSource3D_i.hxx:131
@ TGT_VERTEX2
Definition: StdMeshers_ProjectionSource3D_i.hxx:129
@ SRC_SHAPE3D
@ SRC_VERTEX2
@ NB_SHAPES
@ TGT_VERTEX1
@ SRC_VERTEX1
CORBA::Boolean IsDimSupported(SMESH::Dimension type)
Definition: StdMeshers_ProjectionSource3D_i.cxx:240
Sets source <mesh> to take a mesh pattern from.
Definition: StdMeshers_ProjectionSource3D_i.cxx:98
Returns the source shape.
Definition: StdMeshers_ProjectionSource3D_i.cxx:180
Returns the -th target vertex associated with the -th source vertex.
Definition: StdMeshers_ProjectionSource3D_i.cxx:210
virtual char * SaveTo()
Write parameters in a string.
Definition: StdMeshers_ProjectionSource3D_i.cxx:252
void SetVertexAssociation(GEOM::GEOM_Object_ptr sourceVertex1, GEOM::GEOM_Object_ptr sourceVertex2, GEOM::GEOM_Object_ptr targetVertex1, GEOM::GEOM_Object_ptr targetVertex2)
Sets vertex association between the source shape and the target one.
Definition: StdMeshers_ProjectionSource3D_i.cxx:145
Return source mesh.
Definition: StdMeshers_ProjectionSource3D_i.cxx:131
virtual void LoadFrom(const char *theStream)
Retrieve parameters from the string.
Definition: StdMeshers_ProjectionSource3D_i.cxx:273
Returns the -th source vertex associated with the -th target vertex.
Definition: StdMeshers_ProjectionSource3D_i.cxx:195
Sets a source <shape> to take a mesh pattern from.
Definition: StdMeshers_ProjectionSource3D_i.cxx:76
virtual ~StdMeshers_ProjectionSource3D_i()
StdMeshers_ProjectionSource3D_i::~StdMeshers_ProjectionSource3D_i.
Definition: StdMeshers_ProjectionSource3D_i.cxx:66
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const
Definition: StdMeshers_ProjectionSource3D_i.cxx:319
StdMeshers_ProjectionSource3D_i(PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i.
Definition: StdMeshers_ProjectionSource3D_i.cxx:50
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)
Definition: StdMeshers_ProjectionSource3D_i.cxx:335
::StdMeshers_ProjectionSource3D * GetImpl()
StdMeshers_ProjectionSource3D_i::GetImpl.
Definition: StdMeshers_ProjectionSource3D_i.cxx:226
Definition: StdMeshers_ProjectionSource3D.hxx:49
Dimension
