StdMeshers_ProjectionSource3D Class Reference
This hypothesis specifies a meshed shell or solid to take a mesh pattern from and optionally association of vertices between the source shape and a target one (where a hypothesis is assigned to) More...
#include <StdMeshers_ProjectionSource3D.hxx>
Inheritance diagram for StdMeshers_ProjectionSource3D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_ProjectionSource3D (int hypId, SMESH_Gen *gen)
 StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D. More...
virtual ~StdMeshers_ProjectionSource3D ()
 StdMeshers_ProjectionSource3D::~StdMeshers_ProjectionSource3D. More...
void SetSource3DShape (const TopoDS_Shape &shape)
 Sets a source <shape> to take a mesh pattern from. More...
TopoDS_Shape GetSource3DShape () const
 Returns the source shape. More...
void SetSourceMesh (SMESH_Mesh *mesh)
 Sets source <mesh> to take a mesh pattern from. More...
SMESH_Mesh * GetSourceMesh () const
 Return source mesh. More...
void SetVertexAssociation (const TopoDS_Shape &sourceVertex1, const TopoDS_Shape &sourceVertex2, const TopoDS_Shape &targetVertex1, const TopoDS_Shape &targetVertex2)
 Sets vertex association between the source shape and the target one. More...
TopoDS_Vertex GetSourceVertex (int i) const
 Returns the -th source vertex associated with the -th target vertex. More...
TopoDS_Vertex GetTargetVertex (int i) const
 Returns the -th target vertex associated with the -th source vertex. More...
bool HasVertexAssociation () const
 Test if vertex association defined. More...
void GetStoreParams (TopoDS_Shape &s1, TopoDS_Shape &s2, TopoDS_Shape &s3, TopoDS_Shape &s4, TopoDS_Shape &s5) const
 Return all parameters. More...
void RestoreParams (const TopoDS_Shape &s1, const TopoDS_Shape &s2, const TopoDS_Shape &s3, const TopoDS_Shape &s4, const TopoDS_Shape &s5, SMESH_Mesh *mesh)
 Set all parameters without notifying on modification. More...
 Initialize parameters by the mesh built on the geometry. More...
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
TopoDS_Shape _sourceShape
SMESH_Mesh * _sourceMesh
TopoDS_Vertex _sourceVertex1
TopoDS_Vertex _sourceVertex2
TopoDS_Vertex _targetVertex1
TopoDS_Vertex _targetVertex2
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
Friends
std::ostream & operator<< (std::ostream &save, StdMeshers_ProjectionSource3D &hyp)
std::istream & operator>> (std::istream &load, StdMeshers_ProjectionSource3D &hyp)
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_ProjectionSource3D()
StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D ( int  hypId,
SMESH_Gen *  gen
◆ ~StdMeshers_ProjectionSource3D()
StdMeshers_ProjectionSource3D::~StdMeshers_ProjectionSource3D ( )
◆ DataDependOnParams()
◆ GetDim()
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetName()
◆ GetShapeType()
◆ GetSource3DShape()
TopoDS_Shape StdMeshers_ProjectionSource3D::GetSource3DShape ( ) const
◆ GetSourceMesh()
◆ GetSourceVertex()
TopoDS_Vertex StdMeshers_ProjectionSource3D::GetSourceVertex ( int  i) const
Returns the vertex associated with the target vertex.
Result may be nil if association not set.
References _sourceVertex1, and _sourceVertex2.
Referenced by StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_Projection_3D::Compute(), and StdMeshers_ProjectionUtils::InitVertexAssociation().
◆ GetStoreParams()
void StdMeshers_ProjectionSource3D::GetStoreParams ( TopoDS_Shape &  s1,
TopoDS_Shape &  s2,
TopoDS_Shape &  s3,
TopoDS_Shape &  s4,
TopoDS_Shape &  s5
References _sourceShape, _sourceVertex1, _sourceVertex2, _targetVertex1, and _targetVertex2.
◆ GetTargetVertex()
TopoDS_Vertex StdMeshers_ProjectionSource3D::GetTargetVertex ( int  i) const
References _targetVertex1, and _targetVertex2.
◆ GetType()
◆ HasVertexAssociation()
bool StdMeshers_ProjectionSource3D::HasVertexAssociation ( ) const
bool- test result
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsStatusFatal()
◆ LoadFrom()
istream & StdMeshers_ProjectionSource3D::LoadFrom ( std::istream &  load)
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ RestoreParams()
void StdMeshers_ProjectionSource3D::RestoreParams ( const TopoDS_Shape &  s1,
const TopoDS_Shape &  s2,
const TopoDS_Shape &  s3,
const TopoDS_Shape &  s4,
const TopoDS_Shape &  s5,
SMESH_Mesh *  mesh
References _sourceMesh, _sourceShape, _sourceVertex1, _sourceVertex2, _targetVertex1, and _targetVertex2.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
ostream & StdMeshers_ProjectionSource3D::SaveTo ( std::ostream &  save)
◆ SetLibName()
◆ SetParametersByDefaults()
bool StdMeshers_ProjectionSource3D::SetParametersByDefaults ( const TDefaults &  dflts,
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
bool StdMeshers_ProjectionSource3D::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
Initialize start and end length by the mesh built on the geometry.
theMesh- the built mesh
Implementation does noting
◆ SetSource3DShape()
void StdMeshers_ProjectionSource3D::SetSource3DShape ( const TopoDS_Shape &  shape)
◆ SetSourceMesh()
void StdMeshers_ProjectionSource3D::SetSourceMesh ( SMESH_Mesh *  mesh)
◆ SetVertexAssociation()
void StdMeshers_ProjectionSource3D::SetVertexAssociation ( const TopoDS_Shape &  sourceVertex1,
const TopoDS_Shape &  sourceVertex2,
const TopoDS_Shape &  targetVertex1,
const TopoDS_Shape &  targetVertex2
This parameter is optional. Two vertices must belong to one edge of a shape
References _sourceVertex1, _sourceVertex2, _targetVertex1, _targetVertex2, and SMESH_Hypothesis::NotifySubMeshesHypothesisModification().
Referenced by StdMeshers_ProjectionSource3D_i::LoadFrom(), StdMeshers_ProjectionSource3D_i::setObjectsDependOn(), and StdMeshers_ProjectionSource3D_i::SetVertexAssociation().
◆ operator<<
std::ostream & operator<< ( std::ostream &  save,
StdMeshers_ProjectionSource3D &  hyp
friend
◆ operator>>
std::istream & operator>> ( std::istream &  load,
friend
◆ _gen
◆ _hypId
◆ _libName
privateinherited
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _shapeType
◆ _sourceMesh
SMESH_Mesh* StdMeshers_ProjectionSource3D::_sourceMesh
◆ _sourceShape
TopoDS_Shape StdMeshers_ProjectionSource3D::_sourceShape
◆ _sourceVertex1
TopoDS_Vertex StdMeshers_ProjectionSource3D::_sourceVertex1
◆ _sourceVertex2
TopoDS_Vertex StdMeshers_ProjectionSource3D::_sourceVertex2
◆ _targetVertex1
TopoDS_Vertex StdMeshers_ProjectionSource3D::_targetVertex1
◆ _targetVertex2
TopoDS_Vertex StdMeshers_ProjectionSource3D::_targetVertex2
◆ _type
