StdMeshers_CompositeSegment_1D Class Reference
#include <StdMeshers_CompositeSegment_1D.hxx>
Inheritance diagram for StdMeshers_CompositeSegment_1D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_CompositeSegment_1D (int hypId, SMESH_Gen *gen)
virtual void CancelCompute ()
 Pass CancelCompute() to a child algorithm. More...
virtual const std::list< const SMESHDS_Hypothesis * > & GetUsedHypothesis (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, const bool=true)
 See comments in SMESH_Algo.cxx. More...
void SubmeshRestored (SMESH_subMesh *subMesh)
 return compute error More...
void InitComputeError ()
bool OnlyUnaryInput () const
bool NeedShape () const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static StdMeshers_FaceSide * GetFaceSide (SMESH_Mesh &aMesh, const TopoDS_Edge &anEdge, const TopoDS_Face &aFace, const bool ignoreMeshed)
 Return a face side the edge belongs to. More...
static std::string AlgoName ()
 Returns algo type name. More...
Protected Types
enum  HypothesisType {
  LOCAL_LENGTH , MAX_LENGTH , NB_SEGMENTS , BEG_END_LENGTH ,
  DEFLECTION , ARITHMETIC_1D , FIXED_POINTS_1D , ADAPTIVE ,
  GEOMETRIC_1D , DISTRIB_PROPAGATION , NONE
enum  ValueIndex {
  SCALE_FACTOR_IND = 0 , BETA_IND = 0 , BEG_LENGTH_IND = 0 , END_LENGTH_IND = 1 ,
  DEFLECTION_IND = 0 , PRECISION_IND = 1
enum  IValueIndex { NB_SEGMENTS_IND = 0 , DISTR_TYPE_IND = 1 , CONV_MODE_IND = 2 }
enum  VValueIndex { TAB_FUNC_IND = 0 }
enum  SValueIndex { EXPR_FUNC_IND = 0 }
virtual bool computeInternalParameters (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, double theLength, double theFirstU, double theLastU, std::list< double > &theParameters, const bool theReverse, bool theConsiderPropagation=false)
virtual void redistributeNearVertices (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, double theLength, std::list< double > &theParameters, const TopoDS_Vertex &theVf, const TopoDS_Vertex &thieve)
 Tune parameters to fit "SegmentLengthAroundVertex" hypothesis. More...
bool divideIntoEqualSegments (SMESH_Mesh &theMesh, Adaptor3d_Curve &theC3d, smIdType theNbPoints, double theTol, double theLength, double theFirstU, double theLastU, std::list< double > &theParameters)
 Divide a curve into equal segments. More...
bool computeBetaLaw (Adaptor3d_Curve &theC3d, std::list< double > &theParams, double f, double theLength, double beta, int nbSegments, bool theReverse)
static const StdMeshers_SegmentLengthAroundVertex * getVertexHyp (SMESH_Mesh &theMesh, const TopoDS_Vertex &theV)
 Return StdMeshers_SegmentLengthAroundVertex assigned to vertex. More...
HypothesisType _hypType
const StdMeshers_FixedPoints1D * _fpHyp
const StdMeshers_Adaptive1D * _adaptiveHyp
double _value [2]
smIdType _ivalue [3]
std::vector< double > _vvalue [1]
std::string _svalue [1]
std::vector< int > _revEdgesIDs
TopoDS_Shape _mainEdge
bool _onlyUnaryInput
bool _requireDiscreteBoundary
bool _requireShape
bool _supportSubmeshes
bool _neededLowerHyps [4]
bool _quadraticMesh
int _error
std::string _comment
const SMDS_Mesh * _mesh
double _progress
int _progressTic
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::string _libName
◆ EMeshError
enum SMESH_Algo::EMeshError
MEr_OK
MEr_HOLES
MEr_BAD_ORI
MEr_EMPTY
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ HypothesisType
enum StdMeshers_Regular_1D::HypothesisType
LOCAL_LENGTH
MAX_LENGTH
NB_SEGMENTS
BEG_END_LENGTH
DEFLECTION
ARITHMETIC_1D
FIXED_POINTS_1D
ADAPTIVE
GEOMETRIC_1D
DISTRIB_PROPAGATION
NONE
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ IValueIndex
enum StdMeshers_Regular_1D::IValueIndex
NB_SEGMENTS_IND
DISTR_TYPE_IND
CONV_MODE_IND
◆ SValueIndex
enum StdMeshers_Regular_1D::SValueIndex
EXPR_FUNC_IND
◆ ValueIndex
enum StdMeshers_Regular_1D::ValueIndex
SCALE_FACTOR_IND
BETA_IND
BEG_LENGTH_IND
END_LENGTH_IND
DEFLECTION_IND
PRECISION_IND
◆ VValueIndex
enum StdMeshers_Regular_1D::VValueIndex
TAB_FUNC_IND
◆ StdMeshers_CompositeSegment_1D()
StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D ( int  hypId,
SMESH_Gen *  gen
◆ addBadInputElement()
◆ addBadInputElements()
const bool  addNodes = false
◆ AlgoName()
std::string StdMeshers_CompositeSegment_1D::AlgoName ( )
Referenced by StdMeshers_CompositeSegment_1D().
◆ CancelCompute()
void StdMeshers_Regular_1D::CancelCompute ( )
References SMESH_Algo::CancelCompute().
◆ CheckHypothesis()
bool StdMeshers_Regular_1D::CheckHypothesis ( SMESH_Mesh &  aMesh,
const TopoDS_Shape &  aShape,
SMESH_Hypothesis::Hypothesis_Status &  aStatus
aMesh- the mesh
aShape- the shape
aStatus- check result
bool- true if hypothesis is well defined
Textual description of a problem can be stored in _comment field.
Implements SMESH_Algo.
Reimplemented in StdMeshers_QuadFromMedialAxis_1D2D::Algo1D.
References StdMeshers::StdMeshers_NumberOfSegments::ConversionMode(), StdMeshers_NumberOfSegments::DT_BetaLaw, StdMeshers_NumberOfSegments::DT_ExprFunc, StdMeshers_NumberOfSegments::DT_Regular, StdMeshers_NumberOfSegments::DT_Scale, StdMeshers_NumberOfSegments::DT_TabFunc, StdMeshers::StdMeshers_NumberOfSegments::GetBeta(), SMESH_Gen::GetBoundaryBoxSegmentation(), StdMeshers::StdMeshers_Geometric1D::GetCommonRatio(), StdMeshers::StdMeshers_Deflection1D::GetDeflection(), StdMeshers::StdMeshers_NumberOfSegments::GetDistrType(), StdMeshers::StdMeshers_NumberOfSegments::GetExpressionFunction(), StdMeshers_Propagation::GetFilter(), SMESH_Mesh::GetGen(), SMESH_Mesh::GetHypotheses(), StdMeshers::StdMeshers_LocalLength::GetLength(), StdMeshers::StdMeshers_MaxLength::GetLength(), StdMeshers::StdMeshers_Arithmetic1D::GetLength(), StdMeshers::StdMeshers_StartEndLength::GetLength(), SMESH::SMESH_Hypothesis::GetName(), SMESHDS_Hypothesis::GetName(), StdMeshers::StdMeshers_NumberOfSegments::GetNumberOfSegments(), StdMeshers::StdMeshers_LocalLength::GetPrecision(), StdMeshers::Reversible1D::GetReversedEdges(), StdMeshers::StdMeshers_NumberOfSegments::GetScaleFactor(), SMESH_Mesh::GetShapeDiagonalSize(), StdMeshers::StdMeshers_Geometric1D::GetStartLength(), StdMeshers::StdMeshers_NumberOfSegments::GetTableFunction(), StdMeshers::StdMeshers_MaxLength::GetUsePreestimatedLength(), SMESH::HYP_INCOMPAT_HYPS, SMESH_Hypothesis::HYP_INCOMPATIBLE, SMESH_Hypothesis::HYP_MISSING, SMESH::HYP_OK, SMESH_Hypothesis::HYP_OK, SMESH_Hypothesis::IsAuxiliary(), SMESH_HypoFilter::IsOk(), and SMESHDS_Hypothesis::IsSameName().
Referenced by StdMeshers_QuadFromMedialAxis_1D2D::Algo1D::CheckHypothesis(), and TNodeDistributor::Compute().
◆ Compute() [1/2]
◆ Compute() [2/2]
SMESH_MesherHelper *  aHelper
aMesh- the mesh
bool- is a success
aMesh- the mesh
bool- is a success
◆ computeBetaLaw()
bool StdMeshers_Regular_1D::computeBetaLaw ( Adaptor3d_Curve &  theC3d,
std::list< double > &  theParams,
double  f,
double  theLength,
double  beta,
int  nbSegments,
bool  theReverse
References MESSAGE.
◆ computeInternalParameters()
◆ Continuity()
const TopoDS_Edge &  theE2
E1- the 1st edge
E2- the 2nd edge
References OCC_CATCH_SIGNALS.
◆ DataDependOnParams()
◆ divideIntoEqualSegments()
bool StdMeshers_Regular_1D::divideIntoEqualSegments ( SMESH_Mesh &  theMesh,
double  theTol,
double  theLength,
double  theFirstU,
double  theLastU,
std::list< double > &  theParameters
◆ EdgeLength()
◆ error() [1/3]
◆ error() [2/3]
Referenced by StdMeshers_Quadrangle_2D::addEnforcedNodes(), StdMeshers_Prism_3D::assocOrProjBottom2Top(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckNbEdges(), StdMeshers_Quadrangle_2D::checkNbEdgesForEvaluate(), StdMeshers_Prism_3D::compute(), StdMeshers_Cartesian_3D::Compute(), StdMeshers_CompositeHexa_3D::Compute(), Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolygonPerFace_2D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_1D2D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_QuadFromMedialAxis_1D2D::Compute(), StdMeshers_Quadrangle_2D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_RadialQuadrangle_1D2D::Compute(), SMESH_Algo::Compute(), StdMeshers_HexaFromSkin_3D::Compute(), TNodeDistributor::Compute(), StdMeshers_Prism_3D::computeBase(), StdMeshers_RadialPrism_3D::computeLayerPositions(), StdMeshers_RadialQuadrangle_1D2D::computeLayerPositions(), StdMeshers_Quadrangle_2D::computeQuadDominant(), StdMeshers_Quadrangle_2D::computeQuadPref(), StdMeshers_Quadrangle_2D::computeReduced(), StdMeshers_Prism_3D::computeWalls(), SMESH_Algo::error(), StdMeshers_HexaFromSkin_3D::Evaluate(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_PolygonPerFace_2D::Evaluate(), StdMeshers_Prism_3D::Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), StdMeshers_CompositeHexa_3D::findBoxFaces(), StdMeshers_Quadrangle_2D::getCorners(), StdMeshers_Quadrangle_2D::getEnforcedUV(), SMESH_Algo::GetFeatures(), StdMeshers_ViscousLayerBuilder::GetShrinkGeometry(), StdMeshers_Prism_3D::getWallFaces(), StdMeshers_Prism_3D::initPrism(), StdMeshers_Prism_3D::projectBottomToTop(), and StdMeshers_Quadrangle_2D::setNormalizedGrid().
◆ error() [3/3]
◆ Evaluate()
bool StdMeshers_Regular_1D::Evaluate ( SMESH_Mesh &  aMesh,
MapShapeNbElems &  aResMap
aMesh- the mesh
aShape- the shape
aResMap- prospective number of elements by SMDSAbs_ElementType by a sub-mesh
bool- is a success
References COMPERR_ALGO_FAILED, Edge, SMESH_subMesh::GetComputeError(), SMESH_Mesh::GetSubMesh(), Handle(), SMDSEntity_Edge, SMDSEntity_Last, SMDSEntity_Node, and SMDSEntity_Quad_Edge.
Referenced by StdMeshers_PolyhedronPerSolid_3D::Evaluate().
◆ GetAssignedShapes()
◆ GetCompatibleHypoFilter()
◆ GetCompatibleHypothesis()
◆ GetComputeError()
◆ GetDim()
◆ GetFaceSide()
StdMeshers_FaceSide * StdMeshers_CompositeSegment_1D::GetFaceSide ( SMESH_Mesh &  aMesh,
const TopoDS_Edge &  anEdge,
const TopoDS_Face &  aFace,
◆ GetFeatures() [1/2]
◆ GetFeatures() [2/2]
◆ GetGen()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMeshError()
◆ GetName()
◆ GetNodeParamOnEdge()
const TopoDS_Edge &  theEdge,
Warning
◆ GetProgress()
◆ GetProgressByTic()
◆ GetShapeType()
◆ GetSortedNodesOnEdge()
theNodes- The resulting map
Warning
◆ GetType()
◆ GetUsedHypothesis() [1/2]
aMesh- the mesh
aShape- the shape
Referenced by StdMeshers_Cartesian_3D::CheckHypothesis(), StdMeshers_QuadFromMedialAxis_1D2D::CheckHypothesis(), StdMeshers_Quadrangle_2D::CheckHypothesis(), StdMeshers_Hexa_3D::CheckHypothesis(), StdMeshers_Import_1D::CheckHypothesis(), StdMeshers_Import_1D2D::CheckHypothesis(), StdMeshers_PolyhedronPerSolid_3D::CheckHypothesis(), StdMeshers_Projection_1D::CheckHypothesis(), StdMeshers_Projection_2D::CheckHypothesis(), StdMeshers_Projection_3D::CheckHypothesis(), StdMeshers_RadialPrism_3D::CheckHypothesis(), StdMeshers_RadialQuadrangle_1D2D::CheckHypothesis(), StdMeshers_SegmentAroundVertex_0D::CheckHypothesis(), SMESH_subMesh::ComputeStateEngine(), VISCOUS_2D::_ViscousBuilder2D::findEdgesWithLayers(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_subMesh::getCollection(), GetFaceSide(), StdMeshers_Regular_1D::GetUsedHypothesis(), StdMeshers_Regular_1D::getVertexHyp(), and StdMeshers_ProjectionUtils::MakeComputed().
◆ GetUsedHypothesis() [2/2]
const list< const SMESHDS_Hypothesis * > & StdMeshers_Regular_1D::GetUsedHypothesis ( SMESH_Mesh &  aMesh,
◆ getVertexHyp()
const StdMeshers_SegmentLengthAroundVertex * StdMeshers_Regular_1D::getVertexHyp ( SMESH_Mesh &  theMesh,
const TopoDS_Vertex &  theV
staticprotectedinherited
◆ InitComputeError()
◆ IsApplicableToShape()
bool SMESH_1D_Algo::IsApplicableToShape ( const TopoDS_Shape &  shape,
bool  toCheckAll
[in]aShape- shape to check
bool- true by default
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsContinuous()
const TopoDS_Edge &  E2
◆ isDegenerated()
◆ IsSameName()
◆ IsStatusFatal()
◆ IsStraight()
◆ LoadFrom()
load- the stream
std::ostream& - the stream
◆ LoadStringFromStream()
std::string &  txt
◆ NeedDiscreteBoundary()
◆ NeedLowerHyps()
◆ NeedShape()
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ NumberOfPoints()
const TopoDS_Wire &  W
◆ OnlyUnaryInput()
◆ operator!=()
◆ operator==()
Equality.
◆ redistributeNearVertices()
void StdMeshers_Regular_1D::redistributeNearVertices ( SMESH_Mesh &  theMesh,
double  theLength,
std::list< double > &  theParameters,
const TopoDS_Vertex &  theVf,
const TopoDS_Vertex &  theVl
theC3d- wire curve
theLength- curve length
theParameters- internal nodes parameters to modify
theVf- 1st vertex
theVl- 2nd vertex
References compensateError(), and StdMeshers::StdMeshers_SegmentLengthAroundVertex::GetLength().
Referenced by Compute().
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
save- the stream
◆ SetEventListener()
void StdMeshers_CompositeSegment_1D::SetEventListener ( SMESH_subMesh *  subMesh)
This method is called when a submesh gets HYP_OK algo_state. After being set, event listener is notified on each event of a submesh.
Reimplemented from StdMeshers_Regular_1D.
References Edge, SMESH_subMesh::getDependsOnIterator(), GetFaceSide(), SMESH_subMesh::GetFather(), SMESH_subMesh::GetSubShape(), SMESH_subMesh::SetEventListener(), StdMeshers_Regular_1D::SetEventListener(), and SMESH_subMesh::SetIsAlwaysComputed().
◆ SetLibName()
◆ SetParametersByDefaults()
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
◆ setSubMeshesToCompute()
◆ SubMeshesToCompute()
◆ SubmeshRestored()
void StdMeshers_Regular_1D::SubmeshRestored ( SMESH_subMesh *  subMesh)
Do nothing.
subMesh- restored submesh
◆ SupportSubmeshes()
◆ VertexNode() [1/3]
const SMESH_Mesh *  mesh
V- the vertex
mesh- mesh
◆ VertexNode() [2/3]
const SMESHDS_Mesh *  meshDS
◆ VertexNode() [3/3]
const SMESH_Mesh *  mesh,
const bool  checkV = true
V- the vertex
mesh- the mesh
V- the vertex
◆ _adaptiveHyp
const StdMeshers_Adaptive1D* StdMeshers_Regular_1D::_adaptiveHyp
◆ _assigedShapeList
◆ _badInputElements
◆ _comment
◆ _compatibleAllHypFilter
◆ _compatibleHypothesis
◆ _compatibleNoAuxHypFilter
◆ _computeCanceled
◆ _error
int SMESH_Algo::_error
◆ _fpHyp
const StdMeshers_FixedPoints1D* StdMeshers_Regular_1D::_fpHyp
◆ _gen
◆ _hypId
◆ _hypType
◆ _ivalue
smIdType StdMeshers_Regular_1D::_ivalue[3]
◆ _libName
privateinherited
◆ _mainEdge
TopoDS_Shape StdMeshers_Regular_1D::_mainEdge
◆ _mesh
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _neededLowerHyps
◆ _onlyUnaryInput
◆ _param_algo_dim
◆ _progress
double SMESH_Algo::_progress
◆ _progressTic
int SMESH_Algo::_progressTic
◆ _quadraticMesh
◆ _requireDiscreteBoundary
◆ _requireShape
◆ _revEdgesIDs
std::vector<int> StdMeshers_Regular_1D::_revEdgesIDs
◆ _shapeType
◆ _smToCompute
◆ _supportSubmeshes
◆ _svalue
std::string StdMeshers_Regular_1D::_svalue[1]
◆ _type
◆ _usedHypList
◆ _value
double StdMeshers_Regular_1D::_value[2]
◆ _vvalue
std::vector<double> StdMeshers_Regular_1D::_vvalue[1]
