StdMeshers_Geometric1D_i Class Reference
#include <StdMeshers_Geometric1D_i.hxx>
Inheritance diagram for StdMeshers_Geometric1D_i:
 StdMeshers_Geometric1D_i (PortableServer::POA_ptr thePOA, ::SMESH_Gen *theGenImpl)
 StdMeshers_Geometric1D_i::StdMeshers_Geometric1D_i. More...
void SetStartLength (CORBA::Double length)
 Sets <start segment length> parameter value. More...
void SetCommonRatio (CORBA::Double factor)
 Sets <common ratio> parameter value. More...
CORBA::Double GetStartLength ()
 Returns length of the first segment. More...
CORBA::Double GetCommonRatio ()
 Returns value of Common Ratio. More...
virtual ::CORBA::Boolean IsDimSupported (::SMESH::Dimension type)
::StdMeshers_Geometric1D * GetImpl ()
 StdMeshers_Geometric1D_i::GetImpl. More...
virtual char * GetName ()
virtual char * GetLibName ()
virtual CORBA::Short GetId ()
bool IsPublished ()
virtual char * SaveTo ()
void SetReversedEdges (const SMESH::long_array &theIDs)
 StdMeshers_Reversible1D_i::SetReversedEdges. More...
SMESH::long_array * GetReversedEdges ()
 StdMeshers_Reversible1D_i::GetReversedEdges. More...
void SetObjectEntry (const char *theEntry)
 StdMeshers_Reversible1D_i::SetObjectEntry. More...
char * GetObjectEntry ()
 StdMeshers_Reversible1D_i::GetObjectEntry. More...
SMESH_Hypothesis_i * myHyp
◆ StdMeshers_Geometric1D_i()
StdMeshers_Geometric1D_i::StdMeshers_Geometric1D_i ( PortableServer::POA_ptr  thePOA,
::SMESH_Gen *  theGenImpl
◆ GetCommonRatio()
CORBA::Double StdMeshers_Geometric1D_i::GetCommonRatio ( )
References StdMeshers_Geometric1D::GetCommonRatio(), and GetImpl().
◆ GetId()
◆ GetImpl()
StdMeshers_Geometric1D * StdMeshers_Geometric1D_i::GetImpl ( )
◆ GetLibName()
◆ getMethodOfParameter()
◆ GetName()
◆ GetObjectEntry()
char * StdMeshers_Reversible1D_i::GetObjectEntry ( )
◆ getObjectsDependOn()
bool StdMeshers_Geometric1D_i::getObjectsDependOn ( std::vector< std::string > &  entryArray,
References StdMeshers_Reversible1D_i::getObjectsDependOn().
◆ getParamIndex()
int
◆ GetReversedEdges()
SMESH::long_array * StdMeshers_Reversible1D_i::GetReversedEdges ( )
◆ GetStartLength()
CORBA::Double StdMeshers_Geometric1D_i::GetStartLength ( )
References GetImpl(), and StdMeshers_Geometric1D::GetStartLength().
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
CORBA::Boolean StdMeshers_Geometric1D_i::IsDimSupported ( ::SMESH::Dimension  type)
References SMESH::DIM_1D.
◆ IsPublished()
◆ LoadFrom()
◆ SaveTo()
◆ SetCommonRatio()
void StdMeshers_Geometric1D_i::SetCommonRatio ( CORBA::Double  factor)
References GetImpl(), and StdMeshers_Geometric1D::SetCommonRatio().
◆ SetHolderHypothesis()
◆ SetLibName()
◆ SetObjectEntry()
void StdMeshers_Reversible1D_i::SetObjectEntry ( const char *  theEntry)
◆ setObjectsDependOn()
bool StdMeshers_Geometric1D_i::setObjectsDependOn ( std::vector< std::string > &  entryArray,
References StdMeshers_Reversible1D_i::setObjectsDependOn().
◆ setOldParameters()
◆ SetReversedEdges()
void StdMeshers_Reversible1D_i::SetReversedEdges ( const SMESH::long_array &  theIds)
◆ SetStartLength()
void StdMeshers_Geometric1D_i::SetStartLength ( CORBA::Double  length)
References GetImpl(), and StdMeshers_Geometric1D::SetStartLength().
◆ SetVarParameter()
const char *  method
◆ UpdateAsMeshesRestored()
◆ myBaseImpl
Referenced by StdMeshers_NumberOfSegments_i::BuildDistributionExpr(), StdMeshers_NumberOfSegments_i::BuildDistributionTab(), StdMeshers_NumberOfSegments_i::ConversionMode(), StdMeshers_NumberOfSegments_i::GetBeta(), SMESH_Algo_i::GetCompatibleHypothesis(), StdMeshers_Adaptive1D_i::GetDeflection(), StdMeshers_Deflection1D_i::GetDeflection(), StdMeshers_NumberOfSegments_i::GetDistrType(), StdMeshers_NumberOfSegments_i::GetExpressionFunction(), StdMeshers_AutomaticLength_i::GetFineness(), StdMeshers_CartesianParameters3D_i::GetGrid(), StdMeshers_CartesianParameters3D_i::GetGridSpacing(), SMESH_Hypothesis_i::GetId(), SMESH_Hypothesis_i::GetImpl(), StdMeshers_Adaptive1D_i::GetImpl(), StdMeshers_Arithmetic1D_i::GetImpl(), StdMeshers_AutomaticLength_i::GetImpl(), StdMeshers_BlockRenumber_i::GetImpl(), StdMeshers_Cartesian_3D_i::GetImpl(), StdMeshers_CartesianParameters3D_i::GetImpl(), StdMeshers_CompositeSegment_1D_i::GetImpl(), StdMeshers_Deflection1D_i::GetImpl(), StdMeshers_FixedPoints1D_i::GetImpl(), GetImpl(), StdMeshers_Hexa_3D_i::GetImpl(), StdMeshers_Import_1D2D_i::GetImpl(), StdMeshers_Import_1D_i::GetImpl(), StdMeshers_ImportSource1D_i::GetImpl(), StdMeshers_ImportSource2D_i::GetImpl(), StdMeshers_LayerDistribution2D_i::GetImpl(), StdMeshers_LayerDistribution_i::GetImpl(), StdMeshers_LengthFromEdges_i::GetImpl(), StdMeshers_LocalLength_i::GetImpl(), StdMeshers_MaxElementArea_i::GetImpl(), StdMeshers_MaxElementVolume_i::GetImpl(), StdMeshers_MaxLength_i::GetImpl(), StdMeshers_NumberOfLayers2D_i::GetImpl(), StdMeshers_NumberOfLayers_i::GetImpl(), StdMeshers_NumberOfSegments_i::GetImpl(), StdMeshers_Prism_3D_i::GetImpl(), StdMeshers_RadialPrism_3D_i::GetImpl(), StdMeshers_Projection_3D_i::GetImpl(), StdMeshers_Projection_2D_i::GetImpl(), StdMeshers_Projection_1D2D_i::GetImpl(), StdMeshers_Projection_1D_i::GetImpl(), StdMeshers_ProjectionSource1D_i::GetImpl(), StdMeshers_ProjectionSource2D_i::GetImpl(), StdMeshers_ProjectionSource3D_i::GetImpl(), StdMeshers_Quadrangle_2D_i::GetImpl(), StdMeshers_QuadrangleParams_i::GetImpl(), StdMeshers_QuadranglePreference_i::GetImpl(), StdMeshers_QuadraticMesh_i::GetImpl(), StdMeshers_RadialQuadrangle_1D2D_i::GetImpl(), StdMeshers_Regular_1D_i::GetImpl(), StdMeshers_SegmentAroundVertex_0D_i::GetImpl(), StdMeshers_SegmentLengthAroundVertex_i::GetImpl(), StdMeshers_StartEndLength_i::GetImpl(), StdMeshers_UseExisting_1D_i::GetImpl(), StdMeshers_UseExisting_2D_i::GetImpl(), StdMeshers_ViscousLayerBuilder_i::GetImpl(), StdMeshers_ViscousLayers2D_i::GetImpl(), StdMeshers_ViscousLayers_i::GetImpl(), StdMeshers_LocalLength_i::GetLength(), StdMeshers_MaxLength_i::GetLength(), StdMeshers_SegmentLengthAroundVertex_i::GetLength(), StdMeshers_Arithmetic1D_i::GetLength(), StdMeshers_StartEndLength_i::GetLength(), SMESH_Hypothesis_i::GetLibName(), StdMeshers_MaxElementArea_i::GetMaxElementArea(), StdMeshers_MaxElementVolume_i::GetMaxElementVolume(), StdMeshers_Adaptive1D_i::GetMaxSize(), StdMeshers_Adaptive1D_i::GetMinSize(), StdMeshers_LengthFromEdges_i::GetMode(), SMESH_Hypothesis_i::GetName(), StdMeshers_FixedPoints1D_i::GetNbSegments(), StdMeshers_NumberOfLayers_i::GetNumberOfLayers(), StdMeshers_NumberOfSegments_i::GetNumberOfSegments(), StdMeshers_QuadrangleParams_i::GetObjectEntry(), StdMeshers_QuadrangleParams_i::getObjectsDependOn(), StdMeshers_ViscousLayers2D_i::getObjectsDependOn(), StdMeshers_ViscousLayers_i::getObjectsDependOn(), StdMeshers_FixedPoints1D_i::GetPoints(), StdMeshers_LocalLength_i::GetPrecision(), StdMeshers_MaxLength_i::GetPreestimatedLength(), StdMeshers_QuadrangleParams_i::GetQuadType(), StdMeshers_NumberOfSegments_i::GetScaleFactor(), StdMeshers_ProjectionSource3D_i::GetSource3DShape(), StdMeshers_ProjectionSource1D_i::GetSourceEdge(), StdMeshers_ProjectionSource2D_i::GetSourceFace(), StdMeshers_ProjectionSource1D_i::GetSourceVertex(), StdMeshers_ProjectionSource2D_i::GetSourceVertex(), StdMeshers_ProjectionSource3D_i::GetSourceVertex(), StdMeshers_NumberOfSegments_i::GetTableFunction(), StdMeshers_ProjectionSource1D_i::GetTargetVertex(), StdMeshers_ProjectionSource2D_i::GetTargetVertex(), StdMeshers_ProjectionSource3D_i::GetTargetVertex(), StdMeshers_QuadrangleParams_i::GetTriaVertex(), StdMeshers_MaxLength_i::GetUsePreestimatedLength(), SMESH_Hypothesis_i::HasParameters(), StdMeshers_MaxLength_i::HavePreestimatedLength(), SMESH_Hypothesis_i::LoadFrom(), StdMeshers_ImportSource1D_i::LoadFrom(), StdMeshers_ImportSource2D_i::LoadFrom(), StdMeshers_LayerDistribution_i::LoadFrom(), StdMeshers_ProjectionSource1D_i::LoadFrom(), StdMeshers_ProjectionSource2D_i::LoadFrom(), StdMeshers_ProjectionSource3D_i::LoadFrom(), StdMeshers_QuadrangleParams_i::LoadFrom(), SMESH_Hypothesis_i::SaveTo(), StdMeshers_ImportSource1D_i::SaveTo(), StdMeshers_ImportSource2D_i::SaveTo(), StdMeshers_LayerDistribution_i::SaveTo(), StdMeshers_ProjectionSource1D_i::SaveTo(), StdMeshers_ProjectionSource2D_i::SaveTo(), StdMeshers_ProjectionSource3D_i::SaveTo(), StdMeshers_QuadrangleParams_i::SaveTo(), StdMeshers_NumberOfSegments_i::SetBeta(), StdMeshers_NumberOfSegments_i::SetConversionMode(), StdMeshers_Adaptive1D_i::SetDeflection(), StdMeshers_Deflection1D_i::SetDeflection(), StdMeshers_NumberOfSegments_i::SetDistrType(), StdMeshers_NumberOfSegments_i::SetExpressionFunction(), StdMeshers_AutomaticLength_i::SetFineness(), StdMeshers_CartesianParameters3D_i::SetGrid(), StdMeshers_CartesianParameters3D_i::SetGridSpacing(), StdMeshers_LayerDistribution_i::SetLayerDistribution(), StdMeshers_LocalLength_i::SetLength(), StdMeshers_MaxLength_i::SetLength(), StdMeshers_SegmentLengthAroundVertex_i::SetLength(), StdMeshers_Arithmetic1D_i::SetLength(), StdMeshers_StartEndLength_i::SetLength(), SMESH_Hypothesis_i::SetLibName(), StdMeshers_MaxElementArea_i::SetMaxElementArea(), StdMeshers_MaxElementVolume_i::SetMaxElementVolume(), StdMeshers_Adaptive1D_i::SetMaxSize(), StdMeshers_Adaptive1D_i::SetMinSize(), StdMeshers_LengthFromEdges_i::SetMode(), StdMeshers_FixedPoints1D_i::SetNbSegments(), StdMeshers_NumberOfLayers_i::SetNumberOfLayers(), StdMeshers_NumberOfSegments_i::SetNumberOfSegments(), StdMeshers_QuadrangleParams_i::SetObjectEntry(), StdMeshers_FixedPoints1D_i::SetPoints(), StdMeshers_LocalLength_i::SetPrecision(), StdMeshers_MaxLength_i::SetPreestimatedLength(), StdMeshers_QuadrangleParams_i::SetQuadType(), StdMeshers_CartesianParameters3D_i::SetQuanta(), StdMeshers_NumberOfSegments_i::SetScaleFactor(), StdMeshers_CartesianParameters3D_i::SetSizeThreshold(), StdMeshers_ProjectionSource3D_i::SetSource3DShape(), StdMeshers_ProjectionSource1D_i::SetSourceEdge(), StdMeshers_ImportSource1D_i::SetSourceEdges(), StdMeshers_ProjectionSource2D_i::SetSourceFace(), StdMeshers_ImportSource2D_i::SetSourceFaces(), StdMeshers_ProjectionSource1D_i::SetSourceMesh(), StdMeshers_ProjectionSource2D_i::SetSourceMesh(), StdMeshers_ProjectionSource3D_i::SetSourceMesh(), StdMeshers_NumberOfSegments_i::SetTableFunction(), StdMeshers_QuadrangleParams_i::SetTriaVertex(), StdMeshers_MaxLength_i::SetUsePreestimatedLength(), StdMeshers_ProjectionSource1D_i::SetVertexAssociation(), StdMeshers_ProjectionSource2D_i::SetVertexAssociation(), StdMeshers_ProjectionSource3D_i::SetVertexAssociation(), SMESH_Hypothesis_i::SMESH_Hypothesis_i(), StdMeshers_Adaptive1D_i::StdMeshers_Adaptive1D_i(), StdMeshers_Arithmetic1D_i::StdMeshers_Arithmetic1D_i(), StdMeshers_AutomaticLength_i::StdMeshers_AutomaticLength_i(), StdMeshers_BlockRenumber_i::StdMeshers_BlockRenumber_i(), StdMeshers_Cartesian_3D_i::StdMeshers_Cartesian_3D_i(), StdMeshers_CartesianParameters3D_i::StdMeshers_CartesianParameters3D_i(), StdMeshers_CompositeSegment_1D_i::StdMeshers_CompositeSegment_1D_i(), StdMeshers_Deflection1D_i::StdMeshers_Deflection1D_i(), StdMeshers_FixedPoints1D_i::StdMeshers_FixedPoints1D_i(), StdMeshers_Geometric1D_i(), StdMeshers_Hexa_3D_i::StdMeshers_Hexa_3D_i(), StdMeshers_Import_1D2D_i::StdMeshers_Import_1D2D_i(), StdMeshers_Import_1D_i::StdMeshers_Import_1D_i(), StdMeshers_ImportSource1D_i::StdMeshers_ImportSource1D_i(), StdMeshers_ImportSource2D_i::StdMeshers_ImportSource2D_i(), StdMeshers_LayerDistribution2D_i::StdMeshers_LayerDistribution2D_i(), StdMeshers_LayerDistribution_i::StdMeshers_LayerDistribution_i(), StdMeshers_LengthFromEdges_i::StdMeshers_LengthFromEdges_i(), StdMeshers_LocalLength_i::StdMeshers_LocalLength_i(), StdMeshers_MaxElementArea_i::StdMeshers_MaxElementArea_i(), StdMeshers_MaxElementVolume_i::StdMeshers_MaxElementVolume_i(), StdMeshers_MaxLength_i::StdMeshers_MaxLength_i(), StdMeshers_NotConformAllowed_i::StdMeshers_NotConformAllowed_i(), StdMeshers_NumberOfLayers2D_i::StdMeshers_NumberOfLayers2D_i(), StdMeshers_NumberOfLayers_i::StdMeshers_NumberOfLayers_i(), StdMeshers_NumberOfSegments_i::StdMeshers_NumberOfSegments_i(), StdMeshers_PolygonPerFace_2D_i::StdMeshers_PolygonPerFace_2D_i(), StdMeshers_PolyhedronPerSolid_3D_i::StdMeshers_PolyhedronPerSolid_3D_i(), StdMeshers_Prism_3D_i::StdMeshers_Prism_3D_i(), StdMeshers_Projection_1D2D_i::StdMeshers_Projection_1D2D_i(), StdMeshers_Projection_1D_i::StdMeshers_Projection_1D_i(), StdMeshers_Projection_2D_i::StdMeshers_Projection_2D_i(), StdMeshers_Projection_3D_i::StdMeshers_Projection_3D_i(), StdMeshers_ProjectionSource1D_i::StdMeshers_ProjectionSource1D_i(), StdMeshers_ProjectionSource2D_i::StdMeshers_ProjectionSource2D_i(), StdMeshers_ProjectionSource3D_i::StdMeshers_ProjectionSource3D_i(), StdMeshers_Propagation_i::StdMeshers_Propagation_i(), StdMeshers_PropagOfDistribution_i::StdMeshers_PropagOfDistribution_i(), StdMeshers_QuadFromMedialAxis_1D2D_i::StdMeshers_QuadFromMedialAxis_1D2D_i(), StdMeshers_Quadrangle_2D_i::StdMeshers_Quadrangle_2D_i(), StdMeshers_QuadrangleParams_i::StdMeshers_QuadrangleParams_i(), StdMeshers_QuadranglePreference_i::StdMeshers_QuadranglePreference_i(), StdMeshers_QuadraticMesh_i::StdMeshers_QuadraticMesh_i(), StdMeshers_RadialPrism_3D_i::StdMeshers_RadialPrism_3D_i(), StdMeshers_RadialQuadrangle_1D2D_i::StdMeshers_RadialQuadrangle_1D2D_i(), StdMeshers_Regular_1D_i::StdMeshers_Regular_1D_i(), StdMeshers_SegmentAroundVertex_0D_i::StdMeshers_SegmentAroundVertex_0D_i(), StdMeshers_SegmentLengthAroundVertex_i::StdMeshers_SegmentLengthAroundVertex_i(), StdMeshers_StartEndLength_i::StdMeshers_StartEndLength_i(), StdMeshers_UseExisting_1D_i::StdMeshers_UseExisting_1D_i(), StdMeshers_UseExisting_2D_i::StdMeshers_UseExisting_2D_i(), StdMeshers_ViscousLayerBuilder_i::StdMeshers_ViscousLayerBuilder_i(), StdMeshers_ViscousLayers2D_i::StdMeshers_ViscousLayers2D_i(), StdMeshers_ViscousLayers_i::StdMeshers_ViscousLayers_i(), and SMESH_Hypothesis_i::~SMESH_Hypothesis_i().
◆ myHolder
◆ myHyp
◆ myMethod2VarParams
