StdMeshers_Geometric1D_i.hxx
24// File : StdMeshers_Geometric1D_i.hxx
25// Module : SMESH
26//
27#ifndef _SMESH_Geometric1D_I_HXX_
28#define _SMESH_Geometric1D_I_HXX_
31
32#include <SALOMEconfig.h>
33#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
34
38
39// ======================================================
40// Geometric 1D hypothesis
41// ======================================================
43 public virtual POA_StdMeshers::StdMeshers_Geometric1D,
44 public virtual SMESH_Hypothesis_i,
45 public virtual StdMeshers_Reversible1D_i
46{
47 public:
48 // Constructor
49 StdMeshers_Geometric1D_i( PortableServer::POA_ptr thePOA,
50 ::SMESH_Gen* theGenImpl );
51
52 void SetStartLength(CORBA::Double length);
53 void SetCommonRatio(CORBA::Double factor);
54
55 CORBA::Double GetStartLength();
56 CORBA::Double GetCommonRatio();
57
58 virtual ::CORBA::Boolean IsDimSupported(::SMESH::Dimension type);
59
60 // Get implementation
62
63
64
65 // Methods for copying mesh definition to other geometry
66
67 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
68 virtual bool getObjectsDependOn( std::vector< std::string > & entryArray,
69 std::vector< int > & subIDArray ) const;
70
71 // Set new geometry instead of that returned by getObjectsDependOn()
72 virtual bool setObjectsDependOn( std::vector< std::string > & entryArray,
73 std::vector< int > & subIDArray );
74};
75
76#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)=0
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const =0
Definition: StdMeshers_Geometric1D_i.hxx:46
Definition: StdMeshers_Geometric1D.hxx:36
Definition: StdMeshers_Reversible1D_i.hxx:43
Dimension
