SMESH_ElementSearcherImpl Struct Reference
Inheritance diagram for SMESH_ElementSearcherImpl:
struct  TFaceLink
 < link and faces sharing it (used in findOuterBoundary()) More...
struct  TInters
 < data of intersection of the line and the mesh face (used in GetPointState()) More...
 SMESH_ElementSearcherImpl (SMDS_Mesh &mesh, double tol=-1, SMDS_ElemIteratorPtr elemIt=SMDS_ElemIteratorPtr())
virtual ~SMESH_ElementSearcherImpl ()
virtual int FindElementsByPoint (const gp_Pnt &point, SMDSAbs_ElementType type, std::vector< const SMDS_MeshElement * > &foundElements)
 Find elements of given type where the given point is IN or ON. More...
virtual TopAbs_State GetPointState (const gp_Pnt &point)
 Classify the given point in the closed 2D mesh. More...
virtual const SMDS_MeshElement * FindClosestTo (const gp_Pnt &point, SMDSAbs_ElementType type)
 Find an element of given type most close to the given point. More...
virtual void GetElementsNearLine (const gp_Ax1 &line, SMDSAbs_ElementType type, std::vector< const SMDS_MeshElement * > &foundElems)
 Return elements possibly intersecting the line. More...
virtual void GetElementsInSphere (const gp_XYZ &center, const double radius, SMDSAbs_ElementType type, std::vector< const SMDS_MeshElement * > &foundElems)
 Return elements whose bounding box intersects a sphere. More...
virtual void GetElementsInBox (const Bnd_B3d &box, SMDSAbs_ElementType type, std::vector< const SMDS_MeshElement * > &foundElems)
 Return elements whose bounding box intersects a given bounding box. More...
virtual gp_XYZ Project (const gp_Pnt &point, SMDSAbs_ElementType type, const SMDS_MeshElement **closestElem)
 Return a projection of a given point to a 2D mesh. More...
double getTolerance ()
 define tolerance for search More...
bool getIntersParamOnLine (const gp_Lin &line, const SMDS_MeshElement *face, const double tolerance, double &param)
 Find intersection of the line and an edge of face and return parameter on line. More...
void findOuterBoundary (const SMDS_MeshElement *anyOuterFace)
 Find all faces belonging to the outer boundary of mesh. More...
bool isOuterBoundary (const SMDS_MeshElement *face) const
int getTreeHeight ()
Data Fields
SMDS_Mesh * _mesh
SMDS_ElemIteratorPtr _meshPartIt
ElementBndBoxTree * _ebbTree [SMDSAbs_NbElementTypes]
int _ebbTreeHeight [SMDSAbs_NbElementTypes]
SMESH_NodeSearcherImpl * _nodeSearcher
SMDSAbs_ElementType _elementType
double _tolerance
bool _outerFacesFound
std::set< const SMDS_MeshElement * > _outerFaces
◆ SMESH_ElementSearcherImpl()
SMESH_ElementSearcherImpl::SMESH_ElementSearcherImpl ( SMDS_Mesh &  mesh,
double  tol = -1,
SMDS_ElemIteratorPtr  elemIt = SMDS_ElemIteratorPtr()
◆ ~SMESH_ElementSearcherImpl()
virtual SMESH_ElementSearcherImpl::~SMESH_ElementSearcherImpl ( )
◆ FindClosestTo()
const SMDS_MeshElement * SMESH_ElementSearcherImpl::FindClosestTo ( const gp_Pnt &  point,
WARNING: Only edge, face and volume search is implemented so far
Implements SMESH_ElementSearcher.
References _ebbTree, _elementType, _mesh, _meshPartIt, MESHCUT::d, SMESH_MeshAlgos::GetDistance(), getTreeHeight(), SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodesIterator(), SMDSAbs_Edge, SMDSAbs_Face, and SMDSAbs_Volume.
◆ FindElementsByPoint()
int SMESH_ElementSearcherImpl::FindElementsByPoint ( const gp_Pnt &  point,
std::vector< const SMDS_MeshElement * > &  foundElements
Returns nb of found elements and elements them-selves.
'ALL' type means elements of any type excluding nodes, balls and 0D elements
References _ebbTree, _elementType, _mesh, _meshPartIt, _nodeSearcher, SMESH_NodeSearcherImpl::FindNearPoint(), getTolerance(), SMESH_MeshAlgos::IsOut(), SMDSAbs_0DElement, SMDSAbs_Ball, and SMDSAbs_Node.
◆ findOuterBoundary()
void SMESH_ElementSearcherImpl::findOuterBoundary ( const SMDS_MeshElement *  anyOuterFace)
◆ GetElementsInBox()
void SMESH_ElementSearcherImpl::GetElementsInBox ( const Bnd_B3d &  box,
std::vector< const SMDS_MeshElement * > &  foundElems
References _ebbTree, _elementType, _mesh, _meshPartIt, and getTolerance().
◆ GetElementsInSphere()
void SMESH_ElementSearcherImpl::GetElementsInSphere ( const gp_XYZ &  center,
References _ebbTree, _elementType, _mesh, and _meshPartIt.
◆ GetElementsNearLine()
void SMESH_ElementSearcherImpl::GetElementsNearLine ( const gp_Ax1 &  line,
◆ getIntersParamOnLine()
bool SMESH_ElementSearcherImpl::getIntersParamOnLine ( const gp_Lin &  line,
const SMDS_MeshElement *  face,
double &  param
References SMDS_MeshElement::GetNode(), Handle(), SMDS_MeshElement::IsQuadratic(), and SMDS_MeshElement::NbNodes().
Referenced by GetPointState().
◆ GetPointState()
TopAbs_State SMESH_ElementSearcherImpl::GetPointState ( const gp_Pnt &  point)
◆ getTolerance()
◆ getTreeHeight()
int SMESH_ElementSearcherImpl::getTreeHeight ( )
References _ebbTree, _ebbTreeHeight, and _elementType.
Referenced by FindClosestTo().
◆ isOuterBoundary()
bool SMESH_ElementSearcherImpl::isOuterBoundary ( const SMDS_MeshElement *  face) const
References _outerFaces.
◆ Project()
gp_XYZ SMESH_ElementSearcherImpl::Project ( const gp_Pnt &  point,
const SMDS_MeshElement **  closestFace
Optionally return the closest face
References _ebbTree, _elementType, _mesh, _meshPartIt, MESHCUT::d, SMESH_MeshAlgos::GetDistance(), SMDS_Mesh::GetMeshInfo(), and SMDS_MeshInfo::NbElements().
◆ _ebbTree
◆ _ebbTreeHeight
int SMESH_ElementSearcherImpl::_ebbTreeHeight[SMDSAbs_NbElementTypes]
◆ _elementType
◆ _mesh
◆ _meshPartIt
◆ _nodeSearcher
SMESH_NodeSearcherImpl* SMESH_ElementSearcherImpl::_nodeSearcher
◆ _outerFaces
std::set<const SMDS_MeshElement*> SMESH_ElementSearcherImpl::_outerFaces
◆ _outerFacesFound
bool SMESH_ElementSearcherImpl::_outerFacesFound
Referenced by findOuterBoundary(), and GetPointState().
◆ _tolerance
double SMESH_ElementSearcherImpl::_tolerance
Referenced by getTolerance().
