SMDS_LinearEdge Class Reference
#include <SMDS_LinearEdge.hxx>
Inheritance diagram for SMDS_LinearEdge:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
 SMDS_LinearEdge (const SMDS_MeshNode *node1=nullptr, const SMDS_MeshNode *node2=nullptr)
void Init (const SMDS_MeshNode *node1, const SMDS_MeshNode *node2)
virtual SMDSAbs_ElementType GetType () const
virtual SMDSAbs_GeometryType GetGeomType () const
virtual SMDSAbs_EntityType GetEntityType () const
virtual bool ChangeNodes (const SMDS_MeshNode *nodes[], const int nbNodes)
virtual int NbNodes () const
virtual int NbEdges () const
virtual int NbFaces () const
virtual int NbCornerNodes () const
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual bool IsPoly () const
virtual bool IsQuadratic () const
virtual SMDS_ElemIteratorPtr nodesIterator () const
virtual SMDS_NodeIteratorPtr nodeIterator () const
virtual const SMDS_MeshNode * GetNode (const int ind) const
 Return node by its index. More...
virtual smIdType GetID () const
 Return ID of an element. More...
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
virtual VTKCellType GetVtkType () const
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
virtual bool IsMediumNode (const SMDS_MeshNode *node) const
 Check if a node is a medium node of a quadratic cell. More...
const SMDS_MeshNode * GetNodeWrap (const int ind) const
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
virtual void Print (std::ostream &OS) const
 Print self. More...
Protected Types
enum  Bits { BIT_IS_MARKED = 1 , BITS_SHIFT = 1 }
virtual void setID (const smIdType id)
virtual void setShapeID (const int shapeID)
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
const SMDS_MeshNode * myNodes [2]
smIdType myID
int myShapeID
SMDS_ElementChunk * myHolder
◆ iterator
◆ Bits
enum SMDS_CellOfNodes::Bits
BIT_IS_MARKED
BITS_SHIFT
◆ SMDS_LinearEdge()
SMDS_LinearEdge::SMDS_LinearEdge ( const SMDS_MeshNode *  node1 = nullptr,
const SMDS_MeshNode *  node2 = nullptr
References myNodes.
◆ begin_nodes()
◆ ChangeNodes()
bool SMDS_LinearEdge::ChangeNodes ( const SMDS_MeshNode *  nodes[],
const int  nbNodes
References myNodes.
◆ end_nodes()
◆ GetEntityType()
virtual SMDSAbs_EntityType SMDS_LinearEdge::GetEntityType ( ) const
Implements SMDS_MeshElement.
References SMDSEntity_Edge.
◆ GetGeomType()
virtual SMDSAbs_GeometryType SMDS_LinearEdge::GetGeomType ( ) const
References SMDSGeom_EDGE.
◆ getGrid()
◆ GetID()
smIdType SMDS_CellOfNodes::GetID ( ) const
Reimplemented from SMDS_MeshElement.
References SMDS_CellOfNodes::myID.
Referenced by SMDS_FaceOfNodes::Print(), SMDS_PolygonalFaceOfNodes::Print(), and SMDS_VolumeOfNodes::Print().
◆ GetMesh()
◆ GetNode()
const SMDS_MeshNode * SMDS_LinearEdge::GetNode ( const int  ind) const
ind- node index
constSMDS_MeshNode* - the node
References myNodes.
◆ GetNodeIndex()
int SMDS_LinearEdge::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
References myNodes.
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ GetShapeID()
int SMDS_CellOfNodes::GetShapeID ( ) const
References SMDS_CellOfNodes::BITS_SHIFT, and SMDS_CellOfNodes::myShapeID.
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetType()
virtual SMDSAbs_ElementType SMDS_LinearEdge::GetType ( ) const
References SMDSAbs_Edge.
◆ GetVtkID()
vtkIdType SMDS_MeshElement::GetVtkID ( ) const
References SMDS_ElementChunk::GetVtkID(), and SMDS_MeshElement::myHolder.
Referenced by SMDS_MeshNode::AddInverseElement(), SMDS_ElementHolder::beforeCompacting(), SMDS_MeshCell::ChangeNodes(), SMDS_MeshVolume::ChangeNodes(), SMDS_MeshNode::ClearInverseElements(), SMDS_ElementFactory::Compact(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_ElementFactory::Free(), SMDS_MeshNode::getCoord(), SMDS_BallElement::GetDiameter(), SMESH_VisualObjDef::GetElemVTKId(), SMESHGUI_PreVisualObj::GetElemVTKId(), SMDS_MeshVolume::GetFaceNode(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshCell::GetNode(), SMDS_MeshVolume::GetNode(), SMDS_MeshCell::GetNodeIndex(), SMDS_MeshVolume::GetNodeIndex(), SMESH_VisualObjDef::GetNodeVTKId(), SMDS_MeshVolume::GetQuantities(), SMESH::Controls::AspectRatio3D::GetValue(), SMDS_MeshCell::GetVtkType(), SMDS_MeshNode::GetXYZ(), SMDS_BallElement::init(), SMDS_MeshNode::init(), SMDS_MeshCell::init(), SMDS_MeshVolume::NbEdges(), SMDS_MeshVolume::NbFaceNodes(), SMDS_MeshVolume::NbFaces(), SMDS_MeshNode::NbInverseElements(), SMDS_MeshCell::NbNodes(), SMDS_MeshVolume::NbNodes(), SMDS_MeshCell::nodeIterator(), SMDS_MeshVolume::nodeIterator(), SMDS_MeshCell::nodesIterator(), SMDS_MeshVolume::nodesIterator(), SMDS_MeshCell::nodesIteratorToUNV(), SMDS_Mesh::RemoveFreeElement(), SMDS_MeshNode::RemoveInverseElement(), SMDS_BallElement::SetDiameter(), and SMDS_MeshNode::setXYZ().
◆ GetVtkType()
virtual VTKCellType SMDS_CellOfNodes::GetVtkType ( ) const
◆ Init()
void SMDS_LinearEdge::Init ( const SMDS_MeshNode *  node1,
References myNodes.
◆ interlacedNodesIterator()
◆ isMarked()
bool SMDS_CellOfNodes::isMarked ( ) const
References SMDS_CellOfNodes::BIT_IS_MARKED, and SMDS_CellOfNodes::myShapeID.
◆ IsMediumNode()
◆ IsNull()
◆ IsPoly()
virtual bool SMDS_LinearEdge::IsPoly ( ) const
◆ IsQuadratic()
virtual bool SMDS_LinearEdge::IsQuadratic ( ) const
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ NbCornerNodes()
virtual int SMDS_LinearEdge::NbCornerNodes ( ) const
◆ NbEdges()
int SMDS_LinearEdge::NbEdges ( ) const
◆ NbFaces()
int SMDS_LinearEdge::NbFaces ( ) const
◆ NbNodes()
int SMDS_LinearEdge::NbNodes ( ) const
Referenced by nodeIterator(), and nodesIterator().
◆ nodeIterator()
SMDS_NodeIteratorPtr SMDS_LinearEdge::nodeIterator ( ) const
References myNodes, and NbNodes().
◆ nodesIterator()
SMDS_ElemIteratorPtr SMDS_LinearEdge::nodesIterator ( ) const
◆ nodesIteratorToUNV()
virtual SMDS_NodeIteratorPtr SMDS_MeshElement::nodesIteratorToUNV ( ) const
Reimplemented in SMDS_MeshCell.
◆ Print()
void SMDS_MeshElement::Print ( std::ostream &  OS) const
Print self.
Reimplemented in SMDS_FaceOfNodes, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by operator<<().
◆ setID()
void SMDS_CellOfNodes::setID ( const smIdType  id)
◆ setIsMarked()
void SMDS_CellOfNodes::setIsMarked ( bool  is) const
Mark this element.
◆ setShapeID() [1/2]
void SMDS_CellOfNodes::setShapeID ( const int  shapeID)
◆ setShapeID() [2/2]
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ myHolder
◆ myID
smIdType SMDS_CellOfNodes::myID
◆ myNodes
const SMDS_MeshNode* SMDS_LinearEdge::myNodes[2]
◆ myShapeID
