SMDS_LinearEdge.hxx
22// File : SMDS_LinearEdge.hxx
23// Module : SMESH
24//
25#ifndef _SMDS_LinearEdge_HeaderFile
26#define _SMDS_LinearEdge_HeaderFile
27
28#include "SMESH_SMDS.hxx"
30#include "SMDS_CellOfNodes.hxx"
31
33{
34public:
35 SMDS_LinearEdge(const SMDS_MeshNode * node1=nullptr, const SMDS_MeshNode * node2=nullptr);
36 void Init( const SMDS_MeshNode * node1, const SMDS_MeshNode * node2);
37
38 virtual SMDSAbs_ElementType GetType() const { return SMDSAbs_Edge; }
41 virtual bool ChangeNodes(const SMDS_MeshNode* nodes[], const int nbNodes);
42 virtual int NbNodes() const;
43 virtual int NbEdges() const;
44 virtual int NbFaces() const;
45
46 virtual int NbCornerNodes() const { return NbNodes(); }
47 virtual int GetNodeIndex( const SMDS_MeshNode* node ) const;
48
49 virtual bool IsPoly() const { return false; }
50 virtual bool IsQuadratic() const { return false; }
51
52 virtual SMDS_ElemIteratorPtr nodesIterator() const;
53 virtual SMDS_NodeIteratorPtr nodeIterator() const;
54
55 virtual const SMDS_MeshNode* GetNode(const int ind) const;
56
57protected:
58 const SMDS_MeshNode* myNodes[2];
59
60};
61#endif
SMDSAbs_GeometryType
enumeration for element geometry type
Definition: SMDSAbs_ElementType.hxx:47
@ SMDSGeom_EDGE
Definition: SMDSAbs_ElementType.hxx:51
SMDSAbs_ElementType
Type (node, edge, face or volume) of elements.
Definition: SMDSAbs_ElementType.hxx:34
@ SMDSAbs_Edge
Definition: SMDSAbs_ElementType.hxx:37
SMDSAbs_EntityType
Enumeration of entity type used in mesh info array.
Definition: SMDSAbs_ElementType.hxx:79
@ SMDSEntity_Edge
Definition: SMDSAbs_ElementType.hxx:82
boost::shared_ptr< SMDS_Iterator< const SMDS_MeshElement * > > SMDS_ElemIteratorPtr
Definition: SMDS_ElemIterator.hxx:43
boost::shared_ptr< SMDS_Iterator< const SMDS_MeshNode * > > SMDS_NodeIteratorPtr
Definition: SMDS_ElemIterator.hxx:46
#define SMDS_EXPORT
Definition: SMESH_SMDS.hxx:37
Base class for elements not contained in the mesh.
Definition: SMDS_CellOfNodes.hxx:44
Definition: SMDS_LinearEdge.hxx:33
Definition: SMDS_LinearEdge.hxx:49
Definition: SMDS_LinearEdge.hxx:46
Definition: SMDS_LinearEdge.hxx:38
virtual SMDSAbs_GeometryType GetGeomType() const
Definition: SMDS_LinearEdge.hxx:39
virtual SMDSAbs_EntityType GetEntityType() const
Definition: SMDS_LinearEdge.hxx:40
Definition: SMDS_LinearEdge.hxx:50
virtual const SMDS_MeshNode * GetNode(const int ind) const =0
Return node by its index.
virtual int GetNodeIndex(const SMDS_MeshNode *node) const
Check if a node belongs to the element.
Definition: SMDS_MeshElement.cxx:93
virtual int NbFaces() const =0
virtual int NbEdges() const =0
virtual SMDS_ElemIteratorPtr nodesIterator() const =0
virtual int NbNodes() const =0
virtual SMDS_NodeIteratorPtr nodeIterator() const =0
Definition: SMDS_MeshNode.hxx:36
