VISCOUS_2D::_ProxyMeshOfFace Struct Reference
Proxy Mesh of FACE with viscous layers. More...
Inheritance diagram for VISCOUS_2D::_ProxyMeshOfFace:
struct  _EdgeSubMesh
typedef boost::shared_ptr< SMESH_ProxyMesh > Ptr
typedef std::map< const SMDS_MeshNode *, const SMDS_MeshNode *, TIDCompare > TN2NMap
 _ProxyMeshOfFace (const SMESH_Mesh &mesh)
_EdgeSubMesh * GetEdgeSubMesh (int ID)
virtual SubMesh * newSubmesh (int index=0) const
 Create a SubMesh. More...
const SMESHDS_SubMesh * GetSubMesh (const TopoDS_Shape &shape) const
 Returns the submesh of a shape; it can be a proxy sub-mesh. More...
const SMESHDS_SubMesh * GetSubMesh (const int shapeID) const
 Return a sub-mesh by a shape ID; it can be a proxy sub-mesh. More...
const SubMesh * GetProxySubMesh (const TopoDS_Shape &shape) const
 Returns the proxy sub-mesh of a shape; it can be NULL. More...
const SMDS_MeshNode * GetProxyNode (const SMDS_MeshNode *node) const
 Returns the proxy node of a node; the input node is returned if no proxy exists. More...
int NbProxySubMeshes () const
 Returns number of proxy sub-meshes. More...
SMDS_ElemIteratorPtr GetFaces () const
 Returns iterator on all faces of the mesh taking into account substitutions To be used in case of mesh without shape. More...
SMDS_ElemIteratorPtr GetFaces (const TopoDS_Shape &face) const
 Returns iterator on all faces on the shape taking into account substitutions. More...
smIdType NbFaces () const
 Return total nb of faces taking into account substitutions. More...
bool IsTemporary (const SMDS_MeshElement *elem) const
 Return true if the element is a temporary one. More...
SMDS_ElemIteratorPtr GetInverseElementIterator (const SMDS_MeshNode *node, SMDSAbs_ElementType type) const
 Return iterator on inverse elements of a node that may be a proxy one. More...
SMESH_Mesh * GetMesh () const
SMESHDS_Mesh * GetMeshDS () const
 Returns mesh DS. More...
static bool HasPrismsOnTwoSides (SMESHDS_SubMesh *faceSM)
 Check if a FACE has prisms on its both sides. More...
void setMesh (const SMESH_Mesh &mesh)
 Set mesh. More...
int shapeIndex (const TopoDS_Shape &shape) const
 Returns index of a shape. More...
SubMesh * findProxySubMesh (int shapeIndex=0) const
 Returns a proxy sub-mesh. More...
SubMesh * getProxySubMesh (int shapeIndex)
 Returns a proxy sub-mesh; it is created if not yet exists. More...
SubMesh * getProxySubMesh (const TopoDS_Shape &shape=TopoDS_Shape())
bool takeProxySubMesh (const TopoDS_Shape &shape, SMESH_ProxyMesh *proxyMesh)
 Move proxy sub-mesh from other proxy mesh to this, returns true if sub-mesh found. More...
void takeTmpElemsInMesh (SMESH_ProxyMesh *proxyMesh)
 Move tmp elements residing the _mesh from other proxy mesh to this. More...
void removeTmpElement (const SMDS_MeshElement *elem)
 Removes tmp elements from the _mesh. More...
void storeTmpElement (const SMDS_MeshElement *elem)
 Stores tmp element residing the _mesh. More...
void setNode2Node (const SMDS_MeshNode *srcNode, const SMDS_MeshNode *proxyNode, const SubMesh *subMesh)
 Set node-node correspondence. More...
std::vector< SMDSAbs_EntityType > _allowedTypes
Private Types
typedef NCollection_DataMap< const SMDS_MeshNode *, std::vector< const SMDS_MeshElement * >, SMESH_Hasher > TNodeElemVecMap
const SMESH_Mesh * _mesh
std::vector< SubMesh * > _subMeshes
std::set< const SMDS_MeshElement * > _elemsInMesh
TNodeElemVecMap _inverseElements
SubMesh * _subContainer
It's needed only to redefine newSubmesh().
◆ Ptr
typedef boost::shared_ptr<SMESH_ProxyMesh> SMESH_ProxyMesh::Ptr
◆ TN2NMap
typedef std::map<const SMDS_MeshNode*, const SMDS_MeshNode*, TIDCompare > SMESH_ProxyMesh::TN2NMap
◆ TNodeElemVecMap
typedef NCollection_DataMap< const SMDS_MeshNode*, std::vector< const SMDS_MeshElement* >, SMESH_Hasher > SMESH_ProxyMesh::TNodeElemVecMap
privateinherited
◆ _ProxyMeshOfFace()
VISCOUS_2D::_ProxyMeshOfFace::_ProxyMeshOfFace ( const SMESH_Mesh &  mesh)
◆ findProxySubMesh()
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::findProxySubMesh ( int  shapeIndex = 0) const
◆ GetEdgeSubMesh()
◆ GetFaces() [1/2]
◆ GetFaces() [2/2]
SMDS_ElemIteratorPtr SMESH_ProxyMesh::GetFaces ( const TopoDS_Shape &  face) const
◆ GetInverseElementIterator()
SMDS_ElemIteratorPtr SMESH_ProxyMesh::GetInverseElementIterator ( const SMDS_MeshNode *  node,
◆ GetMesh()
◆ GetMeshDS()
◆ GetProxyNode()
◆ GetProxySubMesh()
const SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::GetProxySubMesh ( const TopoDS_Shape &  shape) const
References SMESH_ProxyMesh::_subMeshes, and SMESH_ProxyMesh::shapeIndex().
Referenced by VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), and VISCOUS_3D::_ViscousBuilder::MakeN2NMap().
◆ getProxySubMesh() [1/2]
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::getProxySubMesh ( const TopoDS_Shape &  shape = TopoDS_Shape())
References SMESH_ProxyMesh::getProxySubMesh(), and SMESH_ProxyMesh::shapeIndex().
◆ getProxySubMesh() [2/2]
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::getProxySubMesh ( int  shapeIndex)
◆ GetSubMesh() [1/2]
const SMESHDS_SubMesh * SMESH_ProxyMesh::GetSubMesh ( const int  shapeID) const
References SMESH_ProxyMesh::_subMeshes, SMESH_ProxyMesh::GetMeshDS(), and SMESHDS_Mesh::MeshElements().
◆ GetSubMesh() [2/2]
◆ HasPrismsOnTwoSides()
bool SMESH_ProxyMesh::HasPrismsOnTwoSides ( SMESHDS_SubMesh *  smFace)
[in]smFace- sub-mesh of the FACE. NOT a proxy sub-mesh!
bool - true if there are prisms on the two sides
References SMDS_MeshElement::begin_nodes(), SMDS_MeshElement::end_nodes(), SMESHDS_SubMesh::GetElements(), SMDS_Mesh::GetElementsByNodes(), SMDS_MeshElement::NbCornerNodes(), SMESHDS_SubMesh::NbElements(), and SMDSAbs_Volume.
Referenced by StdMeshers_QuadToTriaAdaptor::Compute().
◆ IsTemporary()
bool SMESH_ProxyMesh::IsTemporary ( const SMDS_MeshElement *  elem) const
References SMESH_ProxyMesh::_elemsInMesh, and SMDS_MeshElement::GetID().
Referenced by _QuadFaceGrid::LoadGrid(), and SMESH_MesherHelper::LoadNodeColumns().
◆ NbFaces()
◆ NbProxySubMeshes()
int SMESH_ProxyMesh::NbProxySubMeshes ( ) const
References SMESH_ProxyMesh::_subMeshes.
Referenced by SMESH_ProxyMesh::GetInverseElementIterator().
◆ newSubmesh()
virtual SubMesh * VISCOUS_2D::_ProxyMeshOfFace::newSubmesh ( int  index = 0) const
Create a SubMesh.
[ino]index - shape index
SubMesh* - new SubMesh
Reimplemented from SMESH_ProxyMesh.
References SMESH_ProxyMesh::GetMeshDS().
◆ removeTmpElement()
◆ setMesh()
◆ setNode2Node()
void SMESH_ProxyMesh::setNode2Node ( const SMDS_MeshNode *  srcNode,
const SMDS_MeshNode *  proxyNode,
const SubMesh *  subMesh
References SMESH_ProxyMesh::SubMesh::_n2n.
Referenced by VISCOUS_3D::_MeshOfSolid::setNode2Node().
◆ shapeIndex()
◆ storeTmpElement()
void SMESH_ProxyMesh::storeTmpElement ( const SMDS_MeshElement *  elem)
References SMESH_ProxyMesh::_elemsInMesh.
◆ takeProxySubMesh()
bool SMESH_ProxyMesh::takeProxySubMesh ( const TopoDS_Shape &  shape,
SMESH_ProxyMesh *  proxyMesh
References SMESH_ProxyMesh::_mesh, SMESH_ProxyMesh::_subMeshes, SMESH_ProxyMesh::findProxySubMesh(), and SMESH_ProxyMesh::shapeIndex().
◆ takeTmpElemsInMesh()
void SMESH_ProxyMesh::takeTmpElemsInMesh ( SMESH_ProxyMesh *  proxyMesh)
Referenced by StdMeshers_QuadToTriaAdaptor::Compute(), and SMESH_ProxyMesh::SMESH_ProxyMesh().
◆ _allowedTypes
◆ _elemsInMesh
◆ _inverseElements
TNodeElemVecMap SMESH_ProxyMesh::_inverseElements
privateinherited
◆ _mesh
◆ _subContainer
SubMesh* SMESH_ProxyMesh::_subContainer
mutableprivateinherited
◆ _subMeshes
