StdMeshers::Cartesian3D::Hexahedron::_volumeDef Struct Reference
struct  _linkDef
struct  _nodeDef
typedef void * _ptr
 _volumeDef ()
 ~_volumeDef ()
 _volumeDef (_volumeDef &other)
size_t size () const
_volumeDef * at (int index)
void Set (_Node **nodes, int nb)
void SetNext (_volumeDef *vd)
bool IsEmpty () const
bool IsPolyhedron () const
std::vector< std::set< std::pair< int, int > > > getPolygonsEdges () const
 Returns a vector of sets of edges like {{ nodeId1, nodeId2 }, { nodeId2, nodeId3 }} where an index of element in the vector is an index of polygon in the volume. More...
std::vector< std::set< std::pair< int, int > > > findOpenEdges () const
 Finds polygons with at least one edge not connected to any other polygon. More...
int getStartNodeIndex (const int polygon) const
 Returns an index of the first node of the given polygon in the _nodes container. More...
std::map< int, std::vector< int > > findOverlappingPolygons () const
 Finds in the volume a polygon with such a set of edges that is a subset of edges of other polygon. More...
bool divideOverlappingPolygons ()
bool fixOpenEdgesPolygons ()
 Finds polygons with at least one edge not connected to any other polygon, and tries to cap them with new polygons or just remove as invalid. More...
bool capOpenEdgesPolygons (const std::vector< std::set< std::pair< int, int > > > &edgesByPolygon)
 Finds polygons with at least one edge not connected to any other polygon, and tries to cap them with new polygons. More...
bool removeOpenEdgesPolygons (const std::vector< std::set< std::pair< int, int > > > &edgesByPolygon)
 Finds polygons with at least one edge not connected to any other polygon, and removes all of them. More...
Data Fields
std::vector< _nodeDef > _nodes
std::vector< int > _quantities
_volumeDef * _next
StdMeshers::Cartesian3D::TGeomID _solidID
double _size
const SMDS_MeshElement * _volume
std::vector< const SMDS_MeshElement * > _brotherVolume
std::vector< SMESH_Block::TShapeID > _names
◆ _ptr
◆ _volumeDef() [1/2]
StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_volumeDef ( )
◆ ~_volumeDef()
StdMeshers::Cartesian3D::Hexahedron::_volumeDef::~_volumeDef ( )
◆ _volumeDef() [2/2]
StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_volumeDef ( _volumeDef &  other)
References _names, _nodes, _quantities, and _volume.
◆ at()
_volumeDef * StdMeshers::Cartesian3D::Hexahedron::_volumeDef::at ( int  index)
◆ capOpenEdgesPolygons()
bool Hexahedron::_volumeDef::capOpenEdgesPolygons ( const std::vector< std::set< std::pair< int, int > > > &  edgesByPolygon)
Returns true if at least one polygon was created.
References MESSAGE.
◆ divideOverlappingPolygons()
bool Hexahedron::_volumeDef::divideOverlappingPolygons ( )
Then we can remove these edges from a larger polygon and have as a result two connected polygons those are next to each other instead of being overlapped. We can't just delete the smaller polygon, because it could be a part of separated volume that can be revealed later in checkPolyhedronValidity(). Returns true if at least one polygon was changed.
References MESSAGE.
◆ findOpenEdges()
std::vector< std::set< std::pair< int, int > > > Hexahedron::_volumeDef::findOpenEdges ( ) const
Returns a vector of sets of edges like {{ nodeId1, nodeId2 }, { nodeId2, nodeId3 }} where an index of element in the vector is an index of polygon in the volume. Nodes ids in the pairs are sorted, so index of a first node is always less than second.
References MESSAGE.
◆ findOverlappingPolygons()
std::map< int, std::vector< int > > Hexahedron::_volumeDef::findOverlappingPolygons ( ) const
Returns a map where a key is a larger polygon, the value - is a smaller polygon that is a subset of larger, followed by two nodes those we need to connect in a process of cutting of the first polygon. If the second poly is a complete clone of the first one, both nodes will be -1.
◆ fixOpenEdgesPolygons()
bool Hexahedron::_volumeDef::fixOpenEdgesPolygons ( )
Returns true if any of this changes were made.
◆ getPolygonsEdges()
std::vector< std::set< std::pair< int, int > > > Hexahedron::_volumeDef::getPolygonsEdges ( ) const
◆ getStartNodeIndex()
int Hexahedron::_volumeDef::getStartNodeIndex ( const int  polygon) const
◆ IsEmpty()
bool StdMeshers::Cartesian3D::Hexahedron::_volumeDef::IsEmpty ( ) const
References IsEmpty().
Referenced by IsEmpty().
◆ IsPolyhedron()
bool StdMeshers::Cartesian3D::Hexahedron::_volumeDef::IsPolyhedron ( ) const
◆ removeOpenEdgesPolygons()
bool Hexahedron::_volumeDef::removeOpenEdgesPolygons ( const std::vector< std::set< std::pair< int, int > > > &  edgesByPolygon)
Returns true if at least polygon one was removed.
References MESSAGE.
◆ Set()
◆ SetNext()
void StdMeshers::Cartesian3D::Hexahedron::_volumeDef::SetNext ( _volumeDef *  vd)
◆ size()
size_t StdMeshers::Cartesian3D::Hexahedron::_volumeDef::size ( ) const
◆ _brotherVolume
std::vector<const SMDS_MeshElement*> StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_brotherVolume
◆ _names
std::vector< SMESH_Block::TShapeID > StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_names
◆ _next
◆ _nodes
◆ _quantities
◆ _size
◆ _solidID
◆ _volume
const SMDS_MeshElement* StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_volume
