VISCOUS_2D::_ProxyMeshHolder Struct Reference
SMESH_subMeshEventListener used to store _ProxyMeshOfFace, computed by _ViscousBuilder2D, in a SMESH_subMesh of the FACE. More...
Inheritance diagram for VISCOUS_2D::_ProxyMeshHolder:
struct  _Data
 _ProxyMeshHolder (const TopoDS_Face &face, SMESH_ProxyMesh::Ptr &mesh)
void ProcessEvent (const int event, const int eventType, SMESH_subMesh *, EventListenerData *data, const SMESH_Hypothesis *)
 Do something on a certain event. More...
bool IsDeletable () const
const char * GetName () const
virtual void BeforeDelete (SMESH_subMesh *, SMESH_subMeshEventListenerData *)
static SMESH_ProxyMesh::Ptr FindProxyMeshOfFace (const TopoDS_Shape &face, SMESH_Mesh &mesh)
static const char * Name ()
bool myIsDeletable
 if true, it will be deleted by SMESH_subMesh More...
std::set< SMESH_subMesh * > myBusySM
 to avoid infinite recursion via events More...
const char * myName
 identifier More...
This is to delete _ProxyMeshOfFace when StdMeshers_ViscousLayers2D hypothesis is modified
◆ _ProxyMeshHolder()
VISCOUS_2D::_ProxyMeshHolder::_ProxyMeshHolder ( const TopoDS_Face &  face,
SMESH_ProxyMesh::Ptr &  mesh
◆ BeforeDelete()
virtual void SMESH_subMeshEventListener::BeforeDelete ( SMESH_subMesh *  ,
◆ FindProxyMeshOfFace()
static SMESH_ProxyMesh::Ptr VISCOUS_2D::_ProxyMeshHolder::FindProxyMeshOfFace ( const TopoDS_Shape &  face,
SMESH_Mesh &  mesh
◆ GetName()
const char * SMESH_subMeshEventListener::GetName ( ) const
◆ IsDeletable()
bool SMESH_subMeshEventListener::IsDeletable ( ) const
◆ Name()
static const char * VISCOUS_2D::_ProxyMeshHolder::Name ( )
staticprivate
Referenced by FindProxyMeshOfFace().
◆ ProcessEvent()
void VISCOUS_2D::_ProxyMeshHolder::ProcessEvent ( const int  event,
SMESH_subMesh *  subMesh,
EventListenerData *  data,
const SMESH_Hypothesis *  hyp
event- algo_event or compute_event itself (of SMESH_subMesh)
eventType- ALGO_EVENT or COMPUTE_EVENT (of SMESH_subMesh)
subMesh- the submesh where the event occurs
data- listener data stored in the subMesh
hyp- hypothesis, if eventType is algo_event
The base implementation (see SMESH_subMesh.cxx) translates CLEAN event to the subMeshes stored in the listener data. Also it sends SUBMESH_COMPUTED event in case of successful COMPUTE event.
eventType- algo_event or compute_event
The base implementation translates CLEAN event to the subMesh stored in listener data. Also it sends SUBMESH_COMPUTED event in case of successful COMPUTE event.
Reimplemented from SMESH_subMeshEventListener.
References SMESH_subMesh::CLEAN, and SMESH_subMesh::COMPUTE_EVENT.
◆ myBusySM
std::set<SMESH_subMesh*> SMESH_subMeshEventListener::myBusySM
mutableprivateinherited
◆ myIsDeletable
bool SMESH_subMeshEventListener::myIsDeletable
privateinherited
◆ myName
const char* SMESH_subMeshEventListener::myName
privateinherited
identifier
