SMESH_subMeshEventListener Class Reference
A base for objects reacting on submesh events. More...
#include <SMESH_subMeshEventListener.hxx>
Inheritance diagram for SMESH_subMeshEventListener:
 SMESH_subMeshEventListener (bool isDeletable, const char *name)
virtual ~SMESH_subMeshEventListener ()
bool IsDeletable () const
const char * GetName () const
virtual void BeforeDelete (SMESH_subMesh *, SMESH_subMeshEventListenerData *)
virtual void ProcessEvent (const int event, const int eventType, SMESH_subMesh *subMesh, SMESH_subMeshEventListenerData *data, const SMESH_Hypothesis *hyp=0)
 Do something on a certain event. More...
bool myIsDeletable
 if true, it will be deleted by SMESH_subMesh More...
std::set< SMESH_subMesh * > myBusySM
 to avoid infinite recursion via events More...
const char * myName
 identifier More...
Friends
class SMESH_subMesh
◆ SMESH_subMeshEventListener()
SMESH_subMeshEventListener::SMESH_subMeshEventListener ( bool  isDeletable,
const char *  name
◆ ~SMESH_subMeshEventListener()
virtual SMESH_subMeshEventListener::~SMESH_subMeshEventListener ( )
◆ BeforeDelete()
virtual void SMESH_subMeshEventListener::BeforeDelete ( SMESH_subMesh *  ,
◆ GetName()
const char * SMESH_subMeshEventListener::GetName ( ) const
◆ IsDeletable()
bool SMESH_subMeshEventListener::IsDeletable ( ) const
◆ ProcessEvent()
void SMESH_subMeshEventListener::ProcessEvent ( const int  event,
SMESH_subMesh *  subMesh,
SMESH_subMeshEventListenerData *  data,
const SMESH_Hypothesis *  hyp = 0
event- algo_event or compute_event itself (of SMESH_subMesh)
eventType- ALGO_EVENT or COMPUTE_EVENT (of SMESH_subMesh)
subMesh- the submesh where the event occurs
data- listener data stored in the subMesh
hyp- hypothesis, if eventType is algo_event
The base implementation (see SMESH_subMesh.cxx) translates CLEAN event to the subMeshes stored in the listener data. Also it sends SUBMESH_COMPUTED event in case of successful COMPUTE event.
eventType- algo_event or compute_event
The base implementation translates CLEAN event to the subMesh stored in listener data. Also it sends SUBMESH_COMPUTED event in case of successful COMPUTE event.
Reimplemented in VISCOUS_2D::_ProxyMeshHolder, VISCOUS_3D::_ShrinkShapeListener, VISCOUS_3D::_ViscousListener, and MeshEditor_I::TSearchersDeleter.
References SMESH_subMesh::CLEAN, SMESH_subMesh::COMPUTE, SMESH_subMesh::COMPUTE_EVENT, SMESH_subMesh::COMPUTE_OK, SMESH_subMesh::COMPUTE_SUBMESH, SMESH_subMesh::GetComputeState(), SMESH_subMeshEventListenerData::mySubMeshes, and SMESH_subMesh::SUBMESH_COMPUTED.
Referenced by VISCOUS_3D::_ShrinkShapeListener::ProcessEvent().
◆ SMESH_subMesh
friend class SMESH_subMesh
friend
◆ myBusySM
std::set<SMESH_subMesh*> SMESH_subMeshEventListener::myBusySM
mutableprivate
◆ myIsDeletable
bool SMESH_subMeshEventListener::myIsDeletable
◆ myName
const char* SMESH_subMeshEventListener::myName
identifier
