MeshEditor_I::TSearchersDeleter Struct Reference
Deleter of theNodeSearcher and theElementSearcher at any compute event occurred. More...
Inheritance diagram for MeshEditor_I::TSearchersDeleter:
typedef map< int, SMESH_subMesh * > TDependsOnMap
 The meshod called by submesh: do my main job. More...
 TSearchersDeleter ()
 Delete theNodeSearcher. More...
void ProcessEvent (const int, const int eventType, SMESH_subMesh *sm, SMESH_subMeshEventListenerData *, const SMESH_Hypothesis *)
 set self on all submeshes and delete theNodeSearcher if other mesh is set More...
void Set (SMESH_Mesh *mesh, const string &meshPartIOR=string())
 delete self from all submeshes More...
void Unset (SMESH_Mesh *mesh)
bool IsDeletable () const
const char * GetName () const
virtual void BeforeDelete (SMESH_subMesh *, SMESH_subMeshEventListenerData *)
static void Delete ()
Data Fields
SMESH_Mesh * myMesh
string myMeshPartIOR
bool myIsDeletable
 if true, it will be deleted by SMESH_subMesh More...
std::set< SMESH_subMesh * > myBusySM
 to avoid infinite recursion via events More...
const char * myName
 identifier More...
◆ TDependsOnMap
◆ TSearchersDeleter()
MeshEditor_I::TSearchersDeleter::TSearchersDeleter ( )
◆ BeforeDelete()
virtual void SMESH_subMeshEventListener::BeforeDelete ( SMESH_subMesh *  ,
◆ Delete()
static void MeshEditor_I::TSearchersDeleter::Delete ( )
◆ GetName()
const char * SMESH_subMeshEventListener::GetName ( ) const
◆ IsDeletable()
bool SMESH_subMeshEventListener::IsDeletable ( ) const
◆ ProcessEvent()
void MeshEditor_I::TSearchersDeleter::ProcessEvent ( const int  ,
SMESH_subMesh *  sm,
SMESH_subMeshEventListenerData *  ,
Reimplemented from SMESH_subMeshEventListener.
References SMESH_subMesh::COMPUTE_EVENT, Delete(), SMESH_subMesh::GetFather(), and Unset().
◆ Set()
◆ Unset()
void MeshEditor_I::TSearchersDeleter::Unset ( SMESH_Mesh *  mesh)
References SMESH_Mesh::GetSubMeshContaining(), and myMesh.
Referenced by ProcessEvent(), and Set().
◆ myBusySM
std::set<SMESH_subMesh*> SMESH_subMeshEventListener::myBusySM
mutableprivateinherited
◆ myIsDeletable
bool SMESH_subMeshEventListener::myIsDeletable
privateinherited
◆ myMesh
SMESH_Mesh* MeshEditor_I::TSearchersDeleter::myMesh
Referenced by Set(), and Unset().
◆ myMeshPartIOR
string MeshEditor_I::TSearchersDeleter::myMeshPartIOR
Referenced by Set().
◆ myName
const char* SMESH_subMeshEventListener::myName
privateinherited
identifier
