SMESH_OctreeNode Class Reference
#include <SMESH_OctreeNode.hxx>
Inheritance diagram for SMESH_OctreeNode:
struct  Limit
typedef SMESH_Tree< Bnd_B3d, 8 > TBaseTree
typedef Bnd_B3d box_type
 SMESH_OctreeNode (const TIDSortedNodeSet &theNodes, const int maxLevel=8, const int maxNbNodes=5, const double minBoxSize=0.)
 Constructor : Build all the Octree using Compute() More...
virtual ~SMESH_OctreeNode ()
virtual bool isInside (const gp_XYZ &p, const double precision=0.)
 Tells us if Node is inside the current box with the precision "precision". More...
void AllNodesAround (const SMDS_MeshNode *node, std::vector< const SMDS_MeshNode * > *result, const double precision=0.)
 Return in Result a list of Nodes potentials to be near Node. More...
bool NodesAround (const gp_XYZ &point, std::map< double, const SMDS_MeshNode * > &dist2Nodes, double precision)
 Return in dist2Nodes nodes mapped to their square distance from Node Tries to find a closest node. More...
void NodesAround (const gp_XYZ &point, std::vector< const SMDS_MeshNode * > &nodes, double precision)
 Return a list of nodes close to a point. More...
void FindCoincidentNodes (TIDSortedNodeSet *nodes, const double theTolerance, TListOfNodeLists *theGroupsOfNodes)
 Return in theGroupsOfNodes a list of group of nodes close to each other within theTolerance Search for all the nodes in theSetOfNodes. More...
void UpdateByMoveNode (const SMDS_MeshNode *node, const gp_Pnt &toPnt)
 Update data according to node movement. More...
SMESH_OctreeNodeIteratorPtr GetChildrenIterator ()
 Return iterator over children. More...
SMDS_NodeIteratorPtr GetNodeIterator ()
 Return nodes iterator. More...
size_t NbNodes () const
 Return nb nodes in a tree. More...
double maxSize () const
 Compute the bigger dimension of my box. More...
void compute ()
 Compute the Tree. More...
bool isLeaf () const
 Tell if Tree is a leaf or not An inheriting class can influence it via myIsLeaf protected field. More...
int level () const
const box_type * getBox () const
int getHeight (const bool full=true) const
 Return height of the tree, full or from this level to topest leaf. More...
static void FindCoincidentNodes (TIDSortedNodeSet &nodes, TListOfNodeLists *theGroupsOfNodes, const double theTolerance=0.00001, const int maxLevel=-1, const int maxNbNodes=5)
 Return in theGroupsOfNodes a list of group of nodes close to each other within theTolerance Search for all the nodes in theSetOfNodes Static Method : no need to create an SMESH_OctreeNode. More...
static int getChildIndex (double x, double y, double z, const gp_XYZ &boxMiddle)
 Return index of a child the given point is in. More...
static int nbChildren ()
int getMaxNbNodes () const
 Return max number of nodes in a tree leaf. More...
 SMESH_OctreeNode ()
 Constructor used to allocate a child. More...
virtual Bnd_B3d * buildRootBox ()
 Compute the first bounding box. More...
virtual void buildChildrenData ()
 Set the data of the children Shares the father's data with each of his child. More...
virtual SMESH_Octree * newChild () const
 Construct an empty SMESH_OctreeNode used by SMESH_Octree::buildChildren() More...
void findCoincidentNodes (const SMDS_MeshNode *Node, TIDSortedNodeSet *SetOfNodes, std::vector< const SMDS_MeshNode * > *Result, const double precision)
 Return a list of nodes closed to Node and remove it from SetOfNodes. More...
virtual Bnd_B3d * newChildBox (int childIndex) const
 Allocate a bndbox according to childIndex. More...
virtual void enlargeByFactor (Bnd_B3d *box, double factor) const
 Change size of a box by a factor; each dimension changes independently of others. More...
void buildChildren ()
 Build the children boxes and call buildChildrenData() More...
std::vector< const SMDS_MeshNode * > myNodes
SMESH_Tree ** myChildren
SMESH_Tree * myFather
bool myIsLeaf
const SMESH_TreeLimit * myLimit
box_type * myBox
int myLevel
◆ box_type
typedef Bnd_B3d SMESH_Tree< Bnd_B3d , NB_CHILDREN >::box_type
◆ TBaseTree
typedef SMESH_Tree< Bnd_B3d, 8> SMESH_Octree::TBaseTree
◆ SMESH_OctreeNode() [1/2]
SMESH_OctreeNode::SMESH_OctreeNode ( const TIDSortedNodeSet &  theNodes,
const int  maxLevel = 8,
const int  maxNbNodes = 5,
const double  minBoxSize = 0.
theNodes- Set of nodes, the Octree is built from this nodes
maxLevel- Maximum level for the leaves
maxNbNodes- Maximum number of nodes, a leaf can contain
minBoxSize- Minimal size of the Octree Box
References SMESH_Tree< Bnd_B3d, 8 >::compute().
◆ ~SMESH_OctreeNode()
virtual SMESH_OctreeNode::~SMESH_OctreeNode ( )
◆ SMESH_OctreeNode() [2/2]
SMESH_OctreeNode::SMESH_OctreeNode ( )
Referenced by newChild().
◆ AllNodesAround()
void SMESH_OctreeNode::AllNodesAround ( const SMDS_MeshNode *  Node,
std::vector< const SMDS_MeshNode * > *  Result,
const double  precision = 0.
Node- Node
precision- precision used
Result- list of Nodes potentials to be near Node
References AllNodesAround(), isInside(), SMESH_Tree< Bnd_B3d, 8 >::isLeaf(), SMESH_Tree< Bnd_B3d, 8 >::myChildren, myNodes, and Node.
Referenced by AllNodesAround(), and SMESH_NodeSearcherImpl::FindClosestTo().
◆ buildChildren()
void SMESH_Tree< Bnd_B3d , NB_CHILDREN >::buildChildren
◆ buildChildrenData()
void SMESH_OctreeNode::buildChildrenData ( )
◆ buildRootBox()
Bnd_B3d * SMESH_OctreeNode::buildRootBox ( )
We take the max/min coord of the nodes
Implements SMESH_Tree< Bnd_B3d, 8 >.
References getMaxNbNodes(), SMESH_Tree< Bnd_B3d, 8 >::myIsLeaf, and myNodes.
◆ compute()
void SMESH_Tree< Bnd_B3d , NB_CHILDREN >::compute
Compute the Tree.
◆ enlargeByFactor()
void SMESH_Octree::enlargeByFactor ( Bnd_B3d *  box,
double  factor
◆ findCoincidentNodes()
void SMESH_OctreeNode::findCoincidentNodes ( const SMDS_MeshNode *  Node,
TIDSortedNodeSet *  SetOfNodes,
The Octree itself is also modified by this method
Node- We're searching the nodes next to him.
SetOfNodes- set of nodes in which we erase the found nodes
Result- list of nodes closed to Node
precision- Precision used
References findCoincidentNodes(), isInside(), SMESH_Tree< Bnd_B3d, 8 >::isLeaf(), SMESH_Tree< Bnd_B3d, 8 >::myChildren, myNodes, Node, and SMESH_TNodeXYZ::SquareDistance().
Referenced by findCoincidentNodes(), and FindCoincidentNodes().
◆ FindCoincidentNodes() [1/2]
void SMESH_OctreeNode::FindCoincidentNodes ( TIDSortedNodeSet &  theSetOfNodes,
TListOfNodeLists *  theGroupsOfNodes,
const double  theTolerance = 0.00001,
const int  maxLevel = -1,
theSetOfNodes- set of nodes we look at, modified during research
theGroupsOfNodes- list of nodes closed to each other returned
theTolerance- Precision used, default value is 0.00001
maxLevel- Maximum level for SMESH_OctreeNode constructed, default value is -1 (Infinite)
maxNbNodes- maximum Nodes in a Leaf of the SMESH_OctreeNode constructed, default value is 5
References FindCoincidentNodes().
◆ FindCoincidentNodes() [2/2]
void SMESH_OctreeNode::FindCoincidentNodes ( TIDSortedNodeSet *  theSetOfNodes,
References SMESHUtils::elemSetIterator(), findCoincidentNodes(), SMDS_MeshElement::isMarked(), SMESH_MeshAlgos::MarkElems(), and SMDS_MeshElement::setIsMarked().
Referenced by FindCoincidentNodes(), SMESH_MeshEditor::FindCoincidentNodes(), and SMESH::Controls::CoincidentNodes::SetMesh().
◆ getBox()
const box_type * SMESH_Tree< Bnd_B3d , NB_CHILDREN >::getBox ( ) const
◆ getChildIndex()
int SMESH_Octree::getChildIndex ( double  x,
double  y,
double  z,
const gp_XYZ &  boxMiddle
Referenced by buildChildrenData(), NodesAround(), and UpdateByMoveNode().
◆ GetChildrenIterator()
◆ getHeight()
int SMESH_Tree< Bnd_B3d , NB_CHILDREN >::getHeight ( const bool  full = true) const
◆ getMaxNbNodes()
int SMESH_OctreeNode::getMaxNbNodes ( ) const
References SMESH_Tree< Bnd_B3d, 8 >::myLimit.
Referenced by buildChildrenData(), and buildRootBox().
◆ GetNodeIterator()
SMDS_NodeIteratorPtr SMESH_OctreeNode::GetNodeIterator ( )
References myNodes.
Referenced by SMESH_NodeSearcherImpl::FindClosestTo().
◆ isInside()
bool SMESH_OctreeNode::isInside ( const gp_XYZ &  p,
Node- Node
precision- The box is enlarged with this precision
bool- True if Node is in the box within precision
References SMESH_Tree< Bnd_B3d, 8 >::getBox().
Referenced by AllNodesAround(), SMESH_NodeSearcherImpl::FindClosestTo(), findCoincidentNodes(), NodesAround(), and UpdateByMoveNode().
◆ isLeaf()
bool SMESH_Tree< Bnd_B3d , NB_CHILDREN >::isLeaf
◆ level()
int SMESH_Tree< Bnd_B3d , NB_CHILDREN >::level ( ) const
◆ maxSize()
◆ nbChildren()
static int SMESH_Tree< Bnd_B3d , NB_CHILDREN >::nbChildren ( )
◆ NbNodes()
size_t SMESH_OctreeNode::NbNodes ( ) const
Referenced by SMESH_NodeSearcherImpl::FindClosestTo(), and NodesAround().
◆ newChild()
SMESH_Octree * SMESH_OctreeNode::newChild ( ) const
◆ newChildBox()
Bnd_B3d * SMESH_Octree::newChildBox ( int  childIndex) const
childIndex is zero based
◆ NodesAround() [1/2]
bool SMESH_OctreeNode::NodesAround ( const gp_XYZ &  node,
std::map< double, const SMDS_MeshNode * > &  dist2Nodes,
double  precision
node- node to find nodes closest to
dist2Nodes- map of found nodes and their distances
precision- radius of a sphere to check nodes inside
bool- true if an exact overlapping found !!!
References SMESH_Tree< Bnd_B3d, 8 >::getBox(), SMESH_Octree::getChildIndex(), isInside(), SMESH_Tree< Bnd_B3d, 8 >::isLeaf(), SMESH_Octree::maxSize(), SMESH_Tree< Bnd_B3d, 8 >::myChildren, myNodes, NbNodes(), and NodesAround().
Referenced by StdMeshers_Import_1D2D::Compute(), SMESH_NodeSearcherImpl::FindClosestTo(), SMESH_NodeSearcherImpl::FindNearPoint(), and NodesAround().
◆ NodesAround() [2/2]
void SMESH_OctreeNode::NodesAround ( const gp_XYZ &  point,
std::vector< const SMDS_MeshNode * > &  nodes,
double  precision
[in]point- point
[out]nodes- found nodes
[in]precision- allowed distance from point
References isInside(), SMESH_Tree< Bnd_B3d, 8 >::isLeaf(), SMESH_Tree< Bnd_B3d, 8 >::myChildren, myNodes, NbNodes(), and NodesAround().
◆ UpdateByMoveNode()
void SMESH_OctreeNode::UpdateByMoveNode ( const SMDS_MeshNode *  node,
const gp_Pnt &  toPnt
◆ myBox
box_type* SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myBox
◆ myChildren
SMESH_Tree** SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myChildren
◆ myFather
SMESH_Tree* SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myFather
◆ myIsLeaf
bool SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myIsLeaf
◆ myLevel
int SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myLevel
◆ myLimit
const SMESH_TreeLimit* SMESH_Tree< Bnd_B3d , NB_CHILDREN >::myLimit
◆ myNodes
std::vector< const SMDS_MeshNode* > SMESH_OctreeNode::myNodes
