SMDS_MeshNode.hxx
23// SMESH SMDS : implementation of Salome mesh data structure
24// File : SMDS_MeshNode.hxx
25// Module : SMESH
26//
27#ifndef _SMDS_MeshNode_HeaderFile
28#define _SMDS_MeshNode_HeaderFile
30#include "SMESH_SMDS.hxx"
31
32#include "SMDS_MeshElement.hxx"
33#include "SMDS_Position.hxx"
34
36{
37 public:
38
39 void setXYZ(double x, double y, double z);
40 double X() const; // ! NOT thread safe methods !
41 double Y() const;
42 double Z() const;
43 void GetXYZ(double xyz[3]) const; // thread safe getting coords
44
45 SMDS_ElemIteratorPtr GetInverseElementIterator(SMDSAbs_ElementType type=SMDSAbs_All) const;
46 int NbInverseElements(SMDSAbs_ElementType type=SMDSAbs_All) const;
47
48 SMDS_PositionPtr GetPosition() const; // WARNING result is std::unique_ptr !
49 void SetPosition(const SMDS_PositionPtr& aPos, int shapeID = 0 );
50
51 virtual SMDSAbs_ElementType GetType() const { return SMDSAbs_Node; }
52 virtual VTKCellType GetVtkType() const { return VTK_VERTEX; }
55 virtual int NbNodes() const { return 1; }
56 virtual int NbEdges() const { return 0; }
57 virtual int NbFaces() const { return 0; }
58
59 virtual SMDS_ElemIteratorPtr nodesIterator() const;
60 virtual SMDS_NodeIteratorPtr nodeIterator() const;
61 virtual const SMDS_MeshNode* GetNode(const int ind) const;
62
63 virtual bool IsPoly() const { return false; }
64 virtual bool IsQuadratic() const { return false; }
65 virtual bool IsMediumNode(const SMDS_MeshNode* /*node*/) const { return false; }
66 virtual int NbCornerNodes() const { return 1; }
67
68 virtual void Print(std::ostream & OS) const override;
69
70 private:
71
72 void init(double x=0, double y=0, double z=0);
73
74 double* getCoord() const;
75 void AddInverseElement (const SMDS_MeshElement * elem);
76 void RemoveInverseElement(const SMDS_MeshElement * elem);
77 void ClearInverseElements();
78
79 friend class SMDS_Mesh;
80
81};
82
83#endif
SMDSAbs_GeometryType
enumeration for element geometry type
Definition: SMDSAbs_ElementType.hxx:47
@ SMDSGeom_NONE
Definition: SMDSAbs_ElementType.hxx:66
SMDSAbs_ElementType
Type (node, edge, face or volume) of elements.
Definition: SMDSAbs_ElementType.hxx:34
@ SMDSAbs_Node
Definition: SMDSAbs_ElementType.hxx:36
@ SMDSAbs_All
Definition: SMDSAbs_ElementType.hxx:35
SMDSAbs_EntityType
Enumeration of entity type used in mesh info array.
Definition: SMDSAbs_ElementType.hxx:79
@ SMDSEntity_Node
Definition: SMDSAbs_ElementType.hxx:80
boost::shared_ptr< SMDS_Iterator< const SMDS_MeshElement * > > SMDS_ElemIteratorPtr
Definition: SMDS_ElemIterator.hxx:43
boost::shared_ptr< SMDS_Iterator< const SMDS_MeshNode * > > SMDS_NodeIteratorPtr
Definition: SMDS_ElemIterator.hxx:46
#define SMDS_EXPORT
Definition: SMESH_SMDS.hxx:37
Base class for elements.
Definition: SMDS_MeshElement.hxx:56
virtual const SMDS_MeshNode * GetNode(const int ind) const =0
Return node by its index.
virtual SMDS_ElemIteratorPtr nodesIterator() const =0
virtual void Print(std::ostream &OS) const
Print self.
Definition: SMDS_MeshElement.cxx:207
virtual SMDS_NodeIteratorPtr nodeIterator() const =0
Definition: SMDS_MeshNode.hxx:36
Definition: SMDS_MeshNode.hxx:56
Definition: SMDS_MeshNode.hxx:52
Definition: SMDS_MeshNode.hxx:55
virtual SMDSAbs_GeometryType GetGeomType() const
Definition: SMDS_MeshNode.hxx:54
Definition: SMDS_MeshNode.hxx:63
Definition: SMDS_MeshNode.hxx:64
virtual bool IsMediumNode(const SMDS_MeshNode *) const
Check if a node is a medium node of a quadratic cell.
Definition: SMDS_MeshNode.hxx:65
Definition: SMDS_MeshNode.hxx:66
Definition: SMDS_MeshNode.hxx:57
Definition: SMDS_MeshNode.hxx:51
virtual SMDSAbs_EntityType GetEntityType() const
Definition: SMDS_MeshNode.hxx:53
Definition: SMDS_Mesh.hxx:53
Replace "typedef SMDS_Position* SMDS_PositionPtr" by a smart pointer allowing implicit casting to der...
Definition: SMDS_Position.hxx:58
