VISCOUS_2D::_SegmentTree Struct Reference
Tree of _Segment's used for a faster search of _Segment's. More...
Inheritance diagram for VISCOUS_2D::_SegmentTree:
struct  _SegBox
typedef boost::shared_ptr< _SegmentTree > Ptr
typedef SMESH_Tree< Bnd_B2d, 4 > TBaseTree
typedef Bnd_B2d box_type
 _SegmentTree (const vector< _Segment > &segments)
 Constructor of SegmentTree. More...
void GetSegmentsNear (const _Segment &seg, vector< const _Segment * > &found)
 Return elements which can include the point. More...
void GetSegmentsNear (const gp_Ax2d &ray, vector< const _Segment * > &found)
 Return segments intersecting a ray. More...
double maxSize () const
 Compute the bigger dimension of my box. More...
void compute ()
 Compute the Tree. More...
bool isLeaf () const
 Tell if Tree is a leaf or not An inheriting class can influence it via myIsLeaf protected field. More...
int level () const
const box_type * getBox () const
int getHeight (const bool full=true) const
 Return height of the tree, full or from this level to topest leaf. More...
static int nbChildren ()
 _SegmentTree ()
_SegmentTree * newChild () const
void buildChildrenData ()
 Redistribute _segments among children. More...
Bnd_B2d * buildRootBox ()
 Return the maximal bnd box. More...
virtual Bnd_B2d * newChildBox (int childIndex) const
 Allocate a bndbox according to childIndex. More...
virtual void enlargeByFactor (Bnd_B2d *box, double factor) const
 Change size of a box by a factor; each dimension changes independently of others. More...
void buildChildren ()
 Build the children boxes and call buildChildrenData() More...
SMESH_Tree ** myChildren
SMESH_Tree * myFather
bool myIsLeaf
const SMESH_TreeLimit * myLimit
box_type * myBox
int myLevel
static int maxNbSegInLeaf ()
vector< _SegBox > _segments
◆ box_type
typedef Bnd_B2d SMESH_Tree< Bnd_B2d , NB_CHILDREN >::box_type
◆ Ptr
typedef boost::shared_ptr< _SegmentTree > VISCOUS_2D::_SegmentTree::Ptr
◆ TBaseTree
typedef SMESH_Tree< Bnd_B2d, 4> SMESH_Quadtree::TBaseTree
◆ _SegmentTree() [1/2]
_SegmentTree::_SegmentTree ( const vector< _Segment > &  segments)
References _segments, and SMESH_Tree< Bnd_B2d, 4 >::compute().
◆ _SegmentTree() [2/2]
VISCOUS_2D::_SegmentTree::_SegmentTree ( )
Referenced by newChild().
◆ buildChildren()
void SMESH_Tree< Bnd_B2d , NB_CHILDREN >::buildChildren
◆ buildChildrenData()
◆ buildRootBox()
_SegmentTree::box_type * _SegmentTree::buildRootBox ( )
Implements SMESH_Tree< Bnd_B2d, 4 >.
References _segments.
◆ compute()
void SMESH_Tree< Bnd_B2d , NB_CHILDREN >::compute
Compute the Tree.
◆ enlargeByFactor()
void SMESH_Quadtree::enlargeByFactor ( Bnd_B2d *  box,
double  factor
◆ getBox()
const box_type * SMESH_Tree< Bnd_B2d , NB_CHILDREN >::getBox ( ) const
◆ getHeight()
int SMESH_Tree< Bnd_B2d , NB_CHILDREN >::getHeight ( const bool  full = true) const
◆ GetSegmentsNear() [1/2]
void _SegmentTree::GetSegmentsNear ( const _Segment &  seg,
vector< const _Segment * > &  found
◆ GetSegmentsNear() [2/2]
void _SegmentTree::GetSegmentsNear ( const gp_Ax2d &  ray,
◆ isLeaf()
bool SMESH_Tree< Bnd_B2d , NB_CHILDREN >::isLeaf
◆ level()
int SMESH_Tree< Bnd_B2d , NB_CHILDREN >::level ( ) const
◆ maxNbSegInLeaf()
static int VISCOUS_2D::_SegmentTree::maxNbSegInLeaf ( )
staticprivate
Referenced by buildChildrenData().
◆ maxSize()
double SMESH_Quadtree::maxSize ( ) const
References SMESH_Tree< Bnd_B2d, 4 >::getBox().
◆ nbChildren()
static int SMESH_Tree< Bnd_B2d , NB_CHILDREN >::nbChildren ( )
◆ newChild()
_SegmentTree * VISCOUS_2D::_SegmentTree::newChild ( ) const
References _SegmentTree().
◆ newChildBox()
Bnd_B2d * SMESH_Quadtree::newChildBox ( int  childIndex) const
childIndex is zero based
◆ _segments
vector< _SegBox > VISCOUS_2D::_SegmentTree::_segments
◆ myBox
box_type* SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myBox
◆ myChildren
SMESH_Tree** SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myChildren
◆ myFather
SMESH_Tree* SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myFather
◆ myIsLeaf
bool SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myIsLeaf
◆ myLevel
int SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myLevel
◆ myLimit
const SMESH_TreeLimit* SMESH_Tree< Bnd_B2d , NB_CHILDREN >::myLimit
