SMESHGUI_Angle Class Reference
Angle measurement widget. More...
#include <SMESHGUI_Measurements.h>
Inheritance diagram for SMESHGUI_Angle:
 SMESHGUI_Angle (QWidget *=0)
 ~SMESHGUI_Angle ()
void deactivate ()
void updateSelection ()
 Setup selection mode. More...
Private Slots
void selectionChanged ()
 Called when selection is changed. More...
void nodesEdited ()
void compute ()
void clear ()
bool addPointByActor (int id)
bool addPointByIDSource (int id)
gp_Vec getNormal (const gp_Vec &vec10)
 Return normal to a plane of drawing in the case of 180 degrees angle. More...
QLineEdit * myNodes
QLineEdit * myResult
SMESH::SMESH_IDSource_var myIDSrc
SMESH_Actor * myActor
std::vector< SMESH::PointStruct > myPoints
SMESHGUI_MeshEditPreview * myPreview
Widget to calculate angle between 3 nodes.
◆ SMESHGUI_Angle()
SMESHGUI_Angle::SMESHGUI_Angle ( QWidget *  parent = 0)
parentparent widget
References compute(), SMESHGUI_MeshEditPreview::GetActor(), SMESH::GetViewWindow(), MARGIN, myActor, myNodes, myPreview, myResult, and SPACING.
◆ ~SMESHGUI_Angle()
SMESHGUI_Angle::~SMESHGUI_Angle ( )
References myPreview.
◆ addPointByActor()
bool SMESHGUI_Angle::addPointByActor ( int  id)
◆ addPointByIDSource()
bool SMESHGUI_Angle::addPointByIDSource ( int  id)
References myIDSrc, and myPoints.
Referenced by nodesEdited(), and selectionChanged().
◆ clear
void SMESHGUI_Angle::clear ( )
privateslot
◆ compute
◆ deactivate()
void SMESHGUI_Angle::deactivate ( )
◆ getNormal()
gp_Vec SMESHGUI_Angle::getNormal ( const gp_Vec &  vec10)
References SMESH_MeshAlgos::FaceNormal(), SMDS_Mesh::FindNode(), SMESH_Actor::GetObject(), myActor, myNodes, and SMDSAbs_Face.
Referenced by compute().
◆ nodesEdited
void SMESHGUI_Angle::nodesEdited ( )
privateslot
◆ selectionChanged
void SMESHGUI_Angle::selectionChanged ( )
privateslot
◆ updateSelection()
void SMESHGUI_Angle::updateSelection ( )
◆ myActor
SMESH_Actor* SMESHGUI_Angle::myActor
◆ myIDSrc
SMESH::SMESH_IDSource_var SMESHGUI_Angle::myIDSrc
◆ myNodes
QLineEdit* SMESHGUI_Angle::myNodes
◆ myPoints
std::vector< SMESH::PointStruct > SMESHGUI_Angle::myPoints
◆ myPreview
SMESHGUI_MeshEditPreview* SMESHGUI_Angle::myPreview
◆ myResult
QLineEdit* SMESHGUI_Angle::myResult
Referenced by clear(), compute(), and SMESHGUI_Angle().
