SMDS_Downward Class Referenceabstract
#include <SMDS_Downward.hxx>
Inheritance diagram for SMDS_Downward:
virtual int getNumberOfUpCells (int cellId)=0
virtual const int * getUpCells (int cellId)=0
virtual const unsigned char * getUpTypes (int cellId)=0
virtual void getNodeIds (int cellId, std::set< int > &nodeSet)=0
virtual void getOrderedNodesOfFace (int, std::vector< vtkIdType > &)
int getVtkCellId (int cellId)
int getMaxId ()
 SMDS_Downward (SMDS_UnstructuredGrid *grid, int nbDownCells)
 Generic constructor for all the downward connectivity structures (one per vtk cell type). More...
virtual ~SMDS_Downward ()
int addCell (int vtkId=-1)
virtual void allocate (int nbElems)=0
virtual void compactStorage ()=0
SMDS_UnstructuredGrid * _grid
int _maxId
int _nbDownCells
std::vector< int > _cellIds
Static Protected Attributes
Friends
class SMDS_UnstructuredGrid
class SMDS_Down2D
class SMDS_Down3D
◆ SMDS_Downward()
SMDS_Downward::SMDS_Downward ( SMDS_UnstructuredGrid *  grid,
int  nbDownCells
The static structure for cell dimension is set only once.
gridunstructured grid associated to the mesh.
nbDownCellsnumber of downward entities associated to this vtk type of cell.
References _cellDimension, _cellIds, _cellTypes, _maxId, and getCellDimension().
◆ ~SMDS_Downward()
SMDS_Downward::~SMDS_Downward ( )
◆ addCell()
References _grid, _maxId, _vtkCellIds, allocate(), SMDS_UnstructuredGrid::CellIdToDownId(), initCell(), and SMDS_UnstructuredGrid::setCellIdToDownId().
◆ addDownCell()
void SMDS_Downward::addDownCell ( int  cellId,
int  lowCellId,
unsigned char  aType
Reimplemented in SMDS_DownTriangle, SMDS_DownQuadTriangle, SMDS_DownQuadrangle, SMDS_DownQuadQuadrangle, SMDS_DownTetra, SMDS_DownQuadTetra, SMDS_DownPyramid, SMDS_DownQuadPyramid, SMDS_DownPenta, SMDS_DownQuadPenta, SMDS_DownHexa, and SMDS_DownQuadHexa.
◆ addUpCell()
void SMDS_Downward::addUpCell ( int  cellId,
int  upCellId,
unsigned char  aType
Reimplemented in SMDS_Down1D, and SMDS_Down2D.
◆ allocate()
virtual void SMDS_Downward::allocate ( int  nbElems)
protectedpure virtual
Implemented in SMDS_Down1D, SMDS_Down2D, and SMDS_Down3D.
Referenced by addCell().
◆ compactStorage()
virtual void SMDS_Downward::compactStorage ( )
◆ getCellDimension()
◆ getDownCells()
See also
References _cellIds, and _nbDownCells.
◆ getDownTypes()
See also
SMDS_Downward::getDownCells).
References _cellTypes.
◆ getMaxId()
◆ getNodeIds()
virtual void SMDS_Downward::getNodeIds ( int  cellId,
std::set< int > &  nodeSet
pure virtual
Referenced by SMDS_Down2D::getNodeIds().
◆ getNodes()
int *
◆ getNodeSet()
int SMDS_Downward::getNodeSet ( int  cellId,
int *  nodeSet
◆ getNumberOfDownCells()
cellIdnot used here.
References _nbDownCells.
◆ getNumberOfUpCells()
virtual int SMDS_Downward::getNumberOfUpCells ( int  cellId)
pure virtual
◆ getOrderedNodesOfFace()
virtual void SMDS_Downward::getOrderedNodesOfFace ( int  ,
◆ getUpCells()
virtual const int * SMDS_Downward::getUpCells ( int  cellId)
pure virtual
◆ getUpTypes()
virtual const unsigned char * SMDS_Downward::getUpTypes ( int  cellId)
pure virtual
◆ getVtkCellId()
◆ initCell()
see derived methods
cellId
Reimplemented in SMDS_Down1D.
◆ SMDS_Down2D
friend class SMDS_Down2D
friend
◆ SMDS_Down3D
friend class SMDS_Down3D
friend
◆ SMDS_UnstructuredGrid
friend
◆ _cellDimension
staticprotected
Referenced by getCellDimension(), and SMDS_Downward().
◆ _cellIds
◆ _cellTypes
◆ _grid
◆ _maxId
int SMDS_Downward::_maxId
◆ _nbDownCells
◆ _vtkCellIds
