SMDS_DownQuadPyramid Class Reference
#include <SMDS_Downward.hxx>
Inheritance diagram for SMDS_DownQuadPyramid:
virtual void getOrderedNodesOfFace (int cellId, std::vector< vtkIdType > &orderedNodes)
int getVtkCellId (int cellId)
int getMaxId ()
 SMDS_DownQuadPyramid (SMDS_UnstructuredGrid *grid)
 ~SMDS_DownQuadPyramid ()
virtual void computeFacesWithNodes (int cellId, ListElemByNodesType &facesWithNodes)
 Create a list of faces described by a vtk Type and an ordered set of Node Id's The ordering of the thirteen points defining the quadratic pyramid cell is point id's (0-4,5-12) where point id's 0-4 are the five corner vertices of the pyramid; followed by eight mid-edge nodes (5-12). More...
int FindFaceByNodes (int cellId, ElemByNodesType &faceByNodes)
int addCell (int vtkId=-1)
SMDS_UnstructuredGrid * _grid
int _maxId
int _nbDownCells
std::vector< int > _cellIds
Static Protected Attributes
Friends
class SMDS_UnstructuredGrid
◆ SMDS_DownQuadPyramid()
SMDS_DownQuadPyramid::SMDS_DownQuadPyramid ( SMDS_UnstructuredGrid *  grid)
◆ ~SMDS_DownQuadPyramid()
SMDS_DownQuadPyramid::~SMDS_DownQuadPyramid ( )
◆ addCell()
◆ addDownCell()
void SMDS_DownQuadPyramid::addDownCell ( int  cellId,
int  lowCellId,
unsigned char  aType
◆ addUpCell()
void SMDS_Downward::addUpCell ( int  cellId,
int  upCellId,
unsigned char  aType
Reimplemented in SMDS_Down1D, and SMDS_Down2D.
◆ allocate()
void SMDS_Down3D::allocate ( int  nbElems)
◆ compactStorage()
void SMDS_Down3D::compactStorage ( )
Implements SMDS_Downward.
◆ computeFacesWithNodes()
void SMDS_DownQuadPyramid::computeFacesWithNodes ( int  cellId,
ListElemByNodesType &  facesWithNodes
Note that these mid-edge nodes lie on the edges defined by 5(0,1), 6(1,2), 7(2,3), 8(3,0), 9(0,4), 10(1,4), 11(2,4), 12(3,4).
See also
vtkQuadraticPyramid.h in Filtering.
cellIdvolumeId in vtkUnstructuredGrid
facesWithNodesvector of face descriptors to be filled
Implements SMDS_Down3D.
References SMDS_Downward::_grid, ListElemByNodesType::elems, ListElemByNodesType::nbElems, ElemByNodesType::nbNodes, ElemByNodesType::nodeIds, and ElemByNodesType::vtkType.
◆ FindFaceByNodes()
◆ getCellDimension()
◆ getDownCells()
See also
◆ getDownTypes()
See also
SMDS_Downward::getDownCells).
◆ getMaxId()
◆ getNodeIds()
void SMDS_Down3D::getNodeIds ( int  cellId,
std::set< int > &  nodeSet
◆ getNodes()
int *
◆ getNodeSet()
int SMDS_Downward::getNodeSet ( int  cellId,
int *  nodeSet
◆ getNumberOfDownCells()
cellIdnot used here.
◆ getNumberOfUpCells()
int SMDS_Down3D::getNumberOfUpCells ( int  cellId)
◆ getOrderedNodesOfFace()
void SMDS_DownQuadPyramid::getOrderedNodesOfFace ( int  cellId,
std::vector< vtkIdType > &  orderedNodes
◆ getUpCells()
const int * SMDS_Down3D::getUpCells ( int  cellId)
◆ getUpTypes()
const unsigned char * SMDS_Down3D::getUpTypes ( int  cellId)
◆ getVtkCellId()
◆ initCell()
see derived methods
cellId
Reimplemented in SMDS_Down1D.
◆ SMDS_UnstructuredGrid
friend
◆ _cellDimension
staticprotectedinherited
◆ _cellIds
◆ _cellTypes
◆ _grid
◆ _maxId
◆ _nbDownCells
◆ _vtkCellIds
