SMDS_DownQuadTriangle Class Reference
#include <SMDS_Downward.hxx>
Inheritance diagram for SMDS_DownQuadTriangle:
virtual void getOrderedNodesOfFace (int, std::vector< vtkIdType > &)
int getVtkCellId (int cellId)
int getMaxId ()
 SMDS_DownQuadTriangle (SMDS_UnstructuredGrid *grid)
 ~SMDS_DownQuadTriangle ()
virtual void computeEdgesWithNodes (int cellId, ListElemByNodesType &edgesWithNodes)
 Resize the downward connectivity storage vector if needed. More...
int computeVolumeIds (int cellId, int *ids)
 Find in vtkUnstructuredGrid the volumes containing a face already stored in vtkUnstructuredGrid. More...
int computeVolumeIds (ElemByNodesType &faceByNodes, int *ids)
 Find in vtkUnstructuredGrid the volumes containing a face described by it's nodes Search the volumes containing a face, to store the info in SMDS_Down2D for later uses with SMDS_Down2D::getUpCells and SMDS_Down2D::getUpTypes. More...
int computeVolumeIdsFromNodesFace (int *nodes, int nbNodes, int *ids)
void setTempNodes (int cellId, int vtkId)
void setTempNodes (int cellId, ElemByNodesType &faceByNodes)
bool isInFace (int cellId, int *pts, int npts)
 Find if all the nodes belongs to the face. More...
int FindEdgeByNodes (int cellId, ElemByNodesType &edgeByNodes)
int FindEdgeByNodesSet (int cellId, int *nodeSetToFind, int vtkEdgeType)
int addCell (int vtkId=-1)
std::vector< int > _upCellIds
 2 volumes max. More...
std::vector< unsigned char > _upCellTypes
 2 volume types per face More...
std::vector< int > _tempNodes
 temporary storage of nodes, until downward connectivity completion More...
int _nbNodes
 number of nodes in a face More...
SMDS_UnstructuredGrid * _grid
int _maxId
int _nbDownCells
std::vector< int > _cellIds
Static Protected Attributes
Friends
class SMDS_UnstructuredGrid
◆ SMDS_DownQuadTriangle()
SMDS_DownQuadTriangle::SMDS_DownQuadTriangle ( SMDS_UnstructuredGrid *  grid)
◆ ~SMDS_DownQuadTriangle()
SMDS_DownQuadTriangle::~SMDS_DownQuadTriangle ( )
◆ addCell()
◆ addDownCell()
void SMDS_DownQuadTriangle::addDownCell ( int  cellId,
int  lowCellId,
unsigned char  aType
◆ addUpCell()
void SMDS_Down2D::addUpCell ( int  cellId,
int  upCellId,
unsigned char  aType
References SMDS_Down2D::_upCellIds, and SMDS_Down2D::_upCellTypes.
◆ allocate()
void SMDS_Down2D::allocate ( int  nbElems)
nbElemstotal number of elements of the same type required
Implements SMDS_Downward.
References SMDS_Downward::_cellIds, SMDS_Downward::_nbDownCells, SMDS_Down2D::_nbNodes, SMDS_Down2D::_tempNodes, SMDS_Down2D::_upCellIds, SMDS_Down2D::_upCellTypes, SMDS_Downward::_vtkCellIds, and SMDS_Mesh::chunkSize.
◆ compactStorage()
◆ computeEdgesWithNodes()
void SMDS_DownQuadTriangle::computeEdgesWithNodes ( int  cellId,
ListElemByNodesType &  edgesWithNodes
◆ computeVolumeIds() [1/2]
int SMDS_Down2D::computeVolumeIds ( ElemByNodesType &  faceByNodes,
int *  ids
A face belongs to 0, 1 or 2 volumes, identified by their id in vtkUnstructuredGrid.
faceByNodes
idsa couple of vtkId, initialized at -1 (no parent volume)
number of volumes (0, 1 or 2)
References SMDS_Down2D::computeVolumeIdsFromNodesFace(), ElemByNodesType::nbNodes, and ElemByNodesType::nodeIds.
◆ computeVolumeIds() [2/2]
int SMDS_Down2D::computeVolumeIds ( int  cellId,
int *  ids
Search the volumes containing a face, to store the info in SMDS_Down2D for later uses with SMDS_Down2D::getUpCells and SMDS_Down2D::getUpTypes. A face belongs to 0, 1 or 2 volumes, identified by their id in vtkUnstructuredGrid.
cellIdthe face cell id in vkUnstructuredGrid
References SMDS_Downward::_grid, and SMDS_Down2D::computeVolumeIdsFromNodesFace().
◆ computeVolumeIdsFromNodesFace()
int SMDS_Down2D::computeVolumeIdsFromNodesFace ( int *  pts,
int  npts,
int *  ids
ptsarray of vtk node id's
nptsnumber of nodes
ids
References SMDS_Downward::_grid, SMDS_Downward::getCellDimension(), and SMDS_UnstructuredGrid::GetLinks().
Referenced by SMDS_UnstructuredGrid::BuildDownwardConnectivity(), and SMDS_Down2D::computeVolumeIds().
◆ FindEdgeByNodes()
int SMDS_Down2D::FindEdgeByNodes ( int  cellId,
ElemByNodesType &  edgeByNodes
◆ FindEdgeByNodesSet()
int SMDS_Down2D::FindEdgeByNodesSet ( int  cellId,
int *  nodeSetToFind,
int  vtkEdgeType
◆ getCellDimension()
◆ getDownCells()
See also
◆ getDownTypes()
See also
SMDS_Downward::getDownCells).
◆ getMaxId()
◆ getNodeIds()
void SMDS_Down2D::getNodeIds ( int  cellId,
std::set< int > &  nodeSet
◆ getNodes()
int *
◆ getNodeSet()
int SMDS_Down2D::getNodeSet ( int  cellId,
int *  nodeSet
References SMDS_Down2D::_nbNodes, and SMDS_Down2D::_tempNodes.
◆ getNumberOfDownCells()
cellIdnot used here.
◆ getNumberOfUpCells()
int SMDS_Down2D::getNumberOfUpCells ( int  cellId)
References SMDS_Down2D::_upCellIds.
◆ getOrderedNodesOfFace()
virtual void SMDS_Downward::getOrderedNodesOfFace ( int  ,
◆ getUpCells()
const int * SMDS_Down2D::getUpCells ( int  cellId)
◆ getUpTypes()
const unsigned char * SMDS_Down2D::getUpTypes ( int  cellId)
References SMDS_Down2D::_upCellTypes.
◆ getVtkCellId()
◆ initCell()
see derived methods
cellId
Reimplemented in SMDS_Down1D.
◆ isInFace()
bool SMDS_Down2D::isInFace ( int  cellId,
int *  pts,
int  npts
cellIdthe face cell Id
nodeSetset of node id's to be found in the face list of nodes
Referenced by SMDS_Down1D::computeFaces().
◆ setTempNodes() [1/2]
void SMDS_Down2D::setTempNodes ( int  cellId,
◆ setTempNodes() [2/2]
int  vtkId
◆ SMDS_UnstructuredGrid
friend
◆ _cellDimension
staticprotectedinherited
◆ _cellIds
◆ _cellTypes
◆ _grid
◆ _maxId
◆ _nbDownCells
◆ _nbNodes
◆ _tempNodes
◆ _upCellIds
std::vector<int> SMDS_Down2D::_upCellIds
◆ _upCellTypes
std::vector<unsigned char> SMDS_Down2D::_upCellTypes
◆ _vtkCellIds
