SMDS_DownTetra Class Reference
#include <SMDS_Downward.hxx>
Inheritance diagram for SMDS_DownTetra:
virtual void getOrderedNodesOfFace (int cellId, std::vector< vtkIdType > &orderedNodes)
int getVtkCellId (int cellId)
int getMaxId ()
 SMDS_DownTetra (SMDS_UnstructuredGrid *grid)
 ~SMDS_DownTetra ()
virtual void computeFacesWithNodes (int cellId, ListElemByNodesType &facesWithNodes)
 Create a list of faces described by a vtk Type and an ordered set of Node Id's The linear tetrahedron is defined by four points. More...
int FindFaceByNodes (int cellId, ElemByNodesType &faceByNodes)
int addCell (int vtkId=-1)
SMDS_UnstructuredGrid * _grid
int _maxId
int _nbDownCells
std::vector< int > _cellIds
Static Protected Attributes
Friends
class SMDS_UnstructuredGrid
◆ SMDS_DownTetra()
SMDS_DownTetra::SMDS_DownTetra ( SMDS_UnstructuredGrid *  grid)
◆ ~SMDS_DownTetra()
SMDS_DownTetra::~SMDS_DownTetra ( )
◆ addCell()
◆ addDownCell()
void SMDS_DownTetra::addDownCell ( int  cellId,
int  lowCellId,
unsigned char  aType
◆ addUpCell()
void SMDS_Downward::addUpCell ( int  cellId,
int  upCellId,
unsigned char  aType
Reimplemented in SMDS_Down1D, and SMDS_Down2D.
◆ allocate()
void SMDS_Down3D::allocate ( int  nbElems)
◆ compactStorage()
void SMDS_Down3D::compactStorage ( )
Implements SMDS_Downward.
◆ computeFacesWithNodes()
void SMDS_DownTetra::computeFacesWithNodes ( int  cellId,
ListElemByNodesType &  facesWithNodes
See also
vtkTetra.h in Filtering.
cellIdvolumeId in vtkUnstructuredGrid
facesWithNodesvector of face descriptors to be filled
Implements SMDS_Down3D.
References SMDS_Downward::_grid, ListElemByNodesType::elems, ListElemByNodesType::nbElems, ElemByNodesType::nbNodes, ElemByNodesType::nodeIds, and ElemByNodesType::vtkType.
◆ FindFaceByNodes()
◆ getCellDimension()
◆ getDownCells()
See also
◆ getDownTypes()
See also
SMDS_Downward::getDownCells).
◆ getMaxId()
◆ getNodeIds()
void SMDS_Down3D::getNodeIds ( int  cellId,
std::set< int > &  nodeSet
◆ getNodes()
int *
◆ getNodeSet()
int SMDS_Downward::getNodeSet ( int  cellId,
int *  nodeSet
◆ getNumberOfDownCells()
cellIdnot used here.
◆ getNumberOfUpCells()
int SMDS_Down3D::getNumberOfUpCells ( int  cellId)
◆ getOrderedNodesOfFace()
void SMDS_DownTetra::getOrderedNodesOfFace ( int  cellId,
std::vector< vtkIdType > &  orderedNodes
◆ getUpCells()
const int * SMDS_Down3D::getUpCells ( int  cellId)
◆ getUpTypes()
const unsigned char * SMDS_Down3D::getUpTypes ( int  cellId)
◆ getVtkCellId()
◆ initCell()
see derived methods
cellId
Reimplemented in SMDS_Down1D.
◆ SMDS_UnstructuredGrid
friend
◆ _cellDimension
staticprotectedinherited
◆ _cellIds
◆ _cellTypes
◆ _grid
◆ _maxId
◆ _nbDownCells
◆ _vtkCellIds
