SMDS_DownQuadEdge Class Reference
#include <SMDS_Downward.hxx>
Inheritance diagram for SMDS_DownQuadEdge:
virtual int getNodes (int cellId, int *nodevec)
virtual void getOrderedNodesOfFace (int, std::vector< vtkIdType > &)
int getVtkCellId (int cellId)
int getMaxId ()
 SMDS_DownQuadEdge (SMDS_UnstructuredGrid *grid)
 ~SMDS_DownQuadEdge ()
 clear vectors used to reference 2D cells containing the edge More...
 Resize the downward connectivity storage vector if needed. More...
void setNodes (int cellId, int vtkId)
void setNodes (int cellId, const int *nodeIds)
int computeVtkCells (int cellId, std::vector< int > &vtkIds)
 Build the list of vtkUnstructuredGrid cells containing the edge. More...
int computeVtkCells (int *pts, std::vector< int > &vtkIds)
int computeFaces (int cellId, int *vtkIds, int nbcells, int *downFaces, unsigned char *downTypes)
 Build the list of downward faces from a list of vtk cells. More...
int computeFaces (int *pts, int *vtkIds, int nbcells, int *downFaces, unsigned char *downTypes)
int addCell (int vtkId=-1)
std::vector< std::vector< int > > _upCellIdsVector
 the number of faces sharing an edge is not known More...
std::vector< std::vector< unsigned char > > _upCellTypesVector
std::vector< int > _upCellIds
 compacted storage after connectivity calculation More...
std::vector< unsigned char > _upCellTypes
std::vector< int > _upCellIndex
SMDS_UnstructuredGrid * _grid
int _maxId
int _nbDownCells
std::vector< int > _cellIds
Static Protected Attributes
Friends
class SMDS_UnstructuredGrid
◆ SMDS_DownQuadEdge()
SMDS_DownQuadEdge::SMDS_DownQuadEdge ( SMDS_UnstructuredGrid *  grid)
◆ ~SMDS_DownQuadEdge()
SMDS_DownQuadEdge::~SMDS_DownQuadEdge ( )
◆ addCell()
◆ addDownCell()
void SMDS_Downward::addDownCell ( int  cellId,
int  lowCellId,
unsigned char  aType
Reimplemented in SMDS_DownTriangle, SMDS_DownQuadTriangle, SMDS_DownQuadrangle, SMDS_DownQuadQuadrangle, SMDS_DownTetra, SMDS_DownQuadTetra, SMDS_DownPyramid, SMDS_DownQuadPyramid, SMDS_DownPenta, SMDS_DownQuadPenta, SMDS_DownHexa, and SMDS_DownQuadHexa.
◆ addUpCell()
void SMDS_Down1D::addUpCell ( int  cellId,
int  upCellId,
unsigned char  aType
References SMDS_Down1D::_upCellIdsVector, and SMDS_Down1D::_upCellTypesVector.
◆ allocate()
void SMDS_Down1D::allocate ( int  nbElems)
nbElemstotal number of elements of the same type required
Implements SMDS_Downward.
References SMDS_Downward::_cellIds, SMDS_Downward::_nbDownCells, SMDS_Down1D::_upCellIdsVector, SMDS_Down1D::_upCellTypesVector, SMDS_Downward::_vtkCellIds, and SMDS_Mesh::chunkSize.
◆ compactStorage()
◆ computeFaces() [1/2]
int SMDS_Down1D::computeFaces ( int *  pts,
int *  vtkIds,
int  nbcells,
int *  downFaces,
unsigned char *  downTypes
ptslist of points id's defining an edge
vtkIdsvector of vtk id's
downFacesvector of face id's in downward structures
downTypesvector of face types
number of downward faces
References SMDS_Downward::_grid, SMDS_Downward::_nbDownCells, SMDS_UnstructuredGrid::CellIdToDownId(), SMDS_Downward::getCellDimension(), SMDS_UnstructuredGrid::getDownArray(), SMDS_Downward::getDownCells(), SMDS_Downward::getDownTypes(), SMDS_Downward::getNumberOfDownCells(), and SMDS_Down2D::isInFace().
◆ computeFaces() [2/2]
int SMDS_Down1D::computeFaces ( int  cellId,
int *  vtkIds,
int  nbcells,
int *  downFaces,
cellIdid of the edge in the downward structure
References SMDS_Downward::_cellIds, SMDS_Downward::_nbDownCells, and SMDS_Down1D::computeFaces().
Referenced by SMDS_UnstructuredGrid::BuildDownwardConnectivity(), and SMDS_Down1D::computeFaces().
◆ computeVtkCells() [1/2]
int SMDS_Down1D::computeVtkCells ( int *  pts,
std::vector< int > &  vtkIds
number of vtk cells (size of vector)
References SMDS_Downward::_grid, SMDS_Downward::_nbDownCells, SMDS_Downward::getCellDimension(), and SMDS_UnstructuredGrid::GetLinks().
◆ computeVtkCells() [2/2]
int SMDS_Down1D::computeVtkCells ( int  cellId,
We keep in the list the cells that contains all the nodes, we keep only volumes and faces.
References SMDS_Downward::_cellIds, SMDS_Downward::_nbDownCells, and SMDS_Down1D::computeVtkCells().
Referenced by SMDS_UnstructuredGrid::BuildDownwardConnectivity(), and SMDS_Down1D::computeVtkCells().
◆ getCellDimension()
◆ getDownCells()
See also
◆ getDownTypes()
See also
SMDS_Downward::getDownCells).
◆ getMaxId()
◆ getNodeIds()
void SMDS_Down1D::getNodeIds ( int  cellId,
std::set< int > &  nodeSet
◆ getNodes()
virtual int SMDS_Down1D::getNodes ( int  cellId,
int *  nodevec
◆ getNodeSet()
int SMDS_Down1D::getNodeSet ( int  cellId,
int *  nodeSet
◆ getNumberOfDownCells()
cellIdnot used here.
◆ getNumberOfUpCells()
int SMDS_Down1D::getNumberOfUpCells ( int  cellId)
References SMDS_Down1D::_upCellIndex.
◆ getOrderedNodesOfFace()
virtual void SMDS_Downward::getOrderedNodesOfFace ( int  ,
◆ getUpCells()
const int * SMDS_Down1D::getUpCells ( int  cellId)
◆ getUpTypes()
const unsigned char * SMDS_Down1D::getUpTypes ( int  cellId)
◆ getVtkCellId()
◆ initCell()
void SMDS_Down1D::initCell ( int  cellId)
cellId
◆ setNodes() [1/2]
void SMDS_Down1D::setNodes ( int  cellId,
const int *  nodeIds
◆ setNodes() [2/2]
int  vtkId
◆ SMDS_UnstructuredGrid
friend
◆ _cellDimension
staticprotectedinherited
◆ _cellIds
◆ _cellTypes
◆ _grid
◆ _maxId
◆ _nbDownCells
◆ _upCellIds
std::vector<int> SMDS_Down1D::_upCellIds
Referenced by SMDS_Down1D::compactStorage(), SMDS_Down1D::getUpCells(), and SMDS_Down1D::SMDS_Down1D().
◆ _upCellIdsVector
std::vector<std::vector<int> > SMDS_Down1D::_upCellIdsVector
◆ _upCellIndex
std::vector<int> SMDS_Down1D::_upCellIndex
◆ _upCellTypes
std::vector<unsigned char> SMDS_Down1D::_upCellTypes
Referenced by SMDS_Down1D::compactStorage(), SMDS_Down1D::getUpTypes(), and SMDS_Down1D::SMDS_Down1D().
◆ _upCellTypesVector
std::vector<std::vector<unsigned char> > SMDS_Down1D::_upCellTypesVector
◆ _vtkCellIds
