SMESH_MAT2d.hxx
22// File : SMESH_MAT2d.hxx
23// Created : Thu May 28 17:49:53 2015
24// Author : Edward AGAPOV (eap)
26#ifndef __SMESH_MAT2d_HXX__
27#define __SMESH_MAT2d_HXX__
28
29#include "SMESH_Utils.hxx"
30
31#include <TopoDS_Face.hxx>
32#include <TopoDS_Edge.hxx>
33
34#include <vector>
35#include <map>
36
37#include <boost/polygon/polygon.hpp>
38#include <boost/polygon/voronoi.hpp>
39
40class Adaptor3d_Curve;
41
42// Medial Axis Transform 2D
43namespace SMESH_MAT2d
44{
45 class MedialAxis; // MedialAxis is the entry point
46 class Branch;
47 class BranchEnd;
48 class Boundary;
49 struct BoundaryPoint;
50
51 typedef boost::polygon::voronoi_diagram<double> TVD;
52 typedef TVD::cell_type TVDCell;
53 typedef TVD::edge_type TVDEdge;
54 typedef TVD::vertex_type TVDVertex;
55
56 //-------------------------------------------------------------------------------------
57 // type of Branch end point
59 BE_ON_VERTEX, // branch ends at a convex VERTEX
60 BE_BRANCH_POINT, // branch meats 2 or more other branches
61 BE_END // branch end equidistant from several adjacent segments
62 };
63 //-------------------------------------------------------------------------------------
68 {
71 std::vector< const Branch* > _branches;
72
73 BranchEnd(): _vertex(0), _type( BE_UNDEF ) {}
74 };
75 //-------------------------------------------------------------------------------------
80 {
82 std::size_t _iEdge; // MA edge index within the branch
83 double _edgeParam; // normalized param within the MA edge
84
85 BranchPoint( const Branch* b = 0, std::size_t e = 0, double u = -1 ):
86 _branch(b), _iEdge(e), _edgeParam(u) {}
87 };
88 //-------------------------------------------------------------------------------------
95 {
96 public:
97 bool getBoundaryPoints(double param, BoundaryPoint& bp1, BoundaryPoint& bp2 ) const;
98 bool getBoundaryPoints(std::size_t iMAEdge, double maEdgeParam,
99 BoundaryPoint& bp1, BoundaryPoint& bp2 ) const;
100 bool getBoundaryPoints(const BranchPoint& p,
101 BoundaryPoint& bp1, BoundaryPoint& bp2 ) const;
102 bool getParameter(const BranchPoint& p, double & u ) const;
103
104 std::size_t nbEdges() const { return _maEdges.size(); }
105
106 const BranchEnd* getEnd(bool the2nd) const { return & ( the2nd ? _endPoint2 : _endPoint1 ); }
107
108 bool hasEndOfType(BranchEndType type) const;
109
110 void getPoints( std::vector< gp_XY >& points, const double scale[2]) const;
111
112 void getGeomEdges( std::vector< std::size_t >& edgeIDs1,
113 std::vector< std::size_t >& edgeIDs2 ) const;
114
115 void getOppositeGeomEdges( std::vector< std::size_t >& edgeIDs1,
116 std::vector< std::size_t >& edgeIDs2,
117 std::vector< BranchPoint >& divPoints) const;
118
119 bool isRemoved() const { return _proxyPoint._branch; }
120
121 public: // internal: construction
122
123 void init( std::vector<const TVDEdge*>& maEdges,
124 const Boundary* boundary,
125 std::map< const TVDVertex*, BranchEndType >& endType);
126 void setBranchesToEnds( const std::vector< Branch >& branches);
127 BranchPoint getPoint( const TVDVertex* vertex ) const;
128 void setRemoved( const BranchPoint& proxyPoint );
129
130 static void setGeomEdge ( std::size_t geomIndex, const TVDEdge* maEdge );
131 static std::size_t getGeomEdge ( const TVDEdge* maEdge );
132 static void setBndSegment( std::size_t segIndex, const TVDEdge* maEdge );
133 static std::size_t getBndSegment( const TVDEdge* maEdge );
134
135 private:
136
137 bool addDivPntForConcaVertex( std::vector< std::size_t >& edgeIDs1,
138 std::vector< std::size_t >& edgeIDs2,
139 std::vector< BranchPoint >& divPoints,
140 const std::vector<const TVDEdge*>& maEdges,
141 const std::vector<const TVDEdge*>& maEdgesTwin,
142 int & i) const;
143
144 // association of _maEdges with boundary segments is stored in this way:
145 // index of an EDGE: TVDEdge->cell()->color()
146 // index of a segment on EDGE: TVDEdge->color()
147 std::vector<const TVDEdge*> _maEdges; // MA edges ending at points located at _params
148 std::vector<double> _params; // params of points on MA, normalized [0;1] within this branch
149 const Boundary* _boundary; // face boundary
153 };
154
155 //-------------------------------------------------------------------------------------
160 {
161 std::vector< double > _params; // params of discretization points on an EDGE
162 std::vector< std::pair< const Branch*, int > > _maEdges; /* index of TVDEdge in branch;
163 index sign means orientation;
164 index == Branch->nbEdges() means
165 end point of a Branch */
166 };
167 //-------------------------------------------------------------------------------------
173 {
174 public:
175
176 Boundary( std::size_t nbEdges ): _pointsPerEdge( nbEdges ) {}
177 BndPoints& getPoints( std::size_t iEdge ) { return _pointsPerEdge[ iEdge ]; }
178 std::size_t nbEdges() const { return _pointsPerEdge.size(); }
179
180 bool getPoint( std::size_t iEdge, std::size_t iSeg, double u, BoundaryPoint& bp ) const;
181
182 bool getBranchPoint( const std::size_t iEdge, double u, BranchPoint& p ) const;
183
184 bool getBranchPoint( const BoundaryPoint& bp, BranchPoint& p ) const;
185
186 bool isConcaveSegment( std::size_t iEdge, std::size_t iSeg ) const;
187
188 bool moveToClosestEdgeEnd( BoundaryPoint& bp ) const;
189
190 private:
191 std::vector< BndPoints > _pointsPerEdge;
192 };
193
194 //-------------------------------------------------------------------------------------
199 {
200 std::size_t _edgeIndex; // index of an EDGE in a sequence passed to MedialAxis()
201 double _param; // parameter of this EDGE
202 };
203 //-------------------------------------------------------------------------------------
210 {
211 public:
212 MedialAxis(const TopoDS_Face& face,
213 const std::vector< TopoDS_Edge >& edges,
214 const double minSegLen,
215 const bool ignoreCorners = false );
216 std::size_t nbBranches() const { return _nbBranches; }
217 const Branch* getBranch(size_t i) const;
218 const std::vector< const BranchEnd* >& getBranchPoints() const { return _branchPnt; }
219 const Boundary& getBoundary() const { return _boundary; }
220
221 void getPoints( const Branch* branch, std::vector< gp_XY >& points) const;
222 Adaptor3d_Curve* make3DCurve(const Branch& branch) const;
223
224 private:
225
226 private:
227 TopoDS_Face _face;
229 std::vector< Branch > _branch;
230 std::size_t _nbBranches; // removed branches ignored
231 std::vector< const BranchEnd* > _branchPnt;
233 double _scale[2];
234 };
235
236}
237
238#endif
#define SMESHUtils_EXPORT
Definition: SMESH_Utils.hxx:37
Face boundary is discretized so that each its segment to correspond to an edge of MA.
Definition: SMESH_MAT2d.hxx:173
Boundary(std::size_t nbEdges)
Definition: SMESH_MAT2d.hxx:176
Definition: SMESH_MAT2d.hxx:191
Definition: SMESH_MAT2d.hxx:178
BndPoints & getPoints(std::size_t iEdge)
Definition: SMESH_MAT2d.hxx:177
Branch is a set of MA edges enclosed between branch points and/or MA ends.
Definition: SMESH_MAT2d.hxx:95
BranchEnd _endPoint2
Definition: SMESH_MAT2d.hxx:151
const Boundary * _boundary
Definition: SMESH_MAT2d.hxx:149
BranchEnd _endPoint1
Definition: SMESH_MAT2d.hxx:150
Definition: SMESH_MAT2d.hxx:148
Definition: SMESH_MAT2d.hxx:119
BranchPoint _proxyPoint
Definition: SMESH_MAT2d.hxx:152
const BranchEnd * getEnd(bool the2nd) const
Definition: SMESH_MAT2d.hxx:106
std::vector< const TVDEdge * > _maEdges
Definition: SMESH_MAT2d.hxx:147
Definition: SMESH_MAT2d.hxx:104
Medial axis (MA) is defined as the loci of centres of locally maximal balls inside 2D representation ...
Definition: SMESH_MAT2d.hxx:210
const Boundary & getBoundary() const
Definition: SMESH_MAT2d.hxx:219
Definition: SMESH_MAT2d.hxx:216
Boundary _boundary
Definition: SMESH_MAT2d.hxx:232
TopoDS_Face _face
Definition: SMESH_MAT2d.hxx:227
Definition: SMESH_MAT2d.hxx:229
std::vector< const BranchEnd * > _branchPnt
Definition: SMESH_MAT2d.hxx:231
TVD _vd
Definition: SMESH_MAT2d.hxx:228
Definition: SMESH_MAT2d.hxx:230
const std::vector< const BranchEnd * > & getBranchPoints() const
Definition: SMESH_MAT2d.hxx:218
Definition: SMESH_MAT2d.hxx:44
boost::polygon::voronoi_diagram< double > TVD
Definition: SMESH_MAT2d.hxx:51
BranchEndType
Definition: SMESH_MAT2d.hxx:58
@ BE_END
Definition: SMESH_MAT2d.hxx:61
@ BE_UNDEF
@ BE_ON_VERTEX
Definition: SMESH_MAT2d.hxx:59
@ BE_BRANCH_POINT
Definition: SMESH_MAT2d.hxx:60
Definition: SMESH_MAT2d.hxx:54
Definition: SMESH_MAT2d.hxx:53
Definition: SMESH_MAT2d.hxx:52
Data of a discretized EDGE allowing to get a point on MA by a parameter on EDGE.
Definition: SMESH_MAT2d.hxx:160
std::vector< std::pair< const Branch *, int > > _maEdges
Definition: SMESH_MAT2d.hxx:162
Definition: SMESH_MAT2d.hxx:161
Point on FACE boundary.
Definition: SMESH_MAT2d.hxx:199
double _param
Definition: SMESH_MAT2d.hxx:201
Definition: SMESH_MAT2d.hxx:200
End point of MA Branch.
Definition: SMESH_MAT2d.hxx:68
BranchEnd()
Definition: SMESH_MAT2d.hxx:73
const TVDVertex * _vertex
Definition: SMESH_MAT2d.hxx:69
BranchEndType _type
Definition: SMESH_MAT2d.hxx:70
std::vector< const Branch * > _branches
Definition: SMESH_MAT2d.hxx:71
Point on MA Branch.
Definition: SMESH_MAT2d.hxx:80
BranchPoint(const Branch *b=0, std::size_t e=0, double u=-1)
Definition: SMESH_MAT2d.hxx:85
const Branch * _branch
Definition: SMESH_MAT2d.hxx:81
std::size_t _iEdge
Definition: SMESH_MAT2d.hxx:82
double _edgeParam
Definition: SMESH_MAT2d.hxx:83
