SMESH_MAT2d::Branch Class Reference
Branch is a set of MA edges enclosed between branch points and/or MA ends. More...
#include <SMESH_MAT2d.hxx>
bool getBoundaryPoints (double param, BoundaryPoint &bp1, BoundaryPoint &bp2) const
 Returns points on two EDGEs, equidistant from a given point of this Branch. More...
bool getBoundaryPoints (std::size_t iMAEdge, double maEdgeParam, BoundaryPoint &bp1, BoundaryPoint &bp2) const
bool getBoundaryPoints (const BranchPoint &p, BoundaryPoint &bp1, BoundaryPoint &bp2) const
bool getParameter (const BranchPoint &p, double &u) const
 Return a parameter of a BranchPoint normalized within this Branch. More...
std::size_t nbEdges () const
const BranchEnd * getEnd (bool the2nd) const
bool hasEndOfType (BranchEndType type) const
 Check type of both ends. More...
void getPoints (std::vector< gp_XY > &points, const double scale[2]) const
 Returns MA points. More...
void getGeomEdges (std::vector< std::size_t > &edgeIDs1, std::vector< std::size_t > &edgeIDs2) const
 Return indices of EDGEs equidistant from this branch. More...
void getOppositeGeomEdges (std::vector< std::size_t > &edgeIDs1, std::vector< std::size_t > &edgeIDs2, std::vector< BranchPoint > &divPoints) const
 Return indices of opposite parts of EDGEs equidistant from this branch. More...
bool isRemoved () const
void init (std::vector< const TVDEdge * > &maEdges, const Boundary *boundary, std::map< const TVDVertex *, BranchEndType > &endType)
 Copy points of an EDGE. More...
void setBranchesToEnds (const std::vector< Branch > &branches)
 fills BranchEnd::_branches of its ends More...
BranchPoint getPoint (const TVDVertex *vertex) const
 returns a BranchPoint corresponding to a TVDVertex More...
void setRemoved (const BranchPoint &proxyPoint)
 Sets a proxy point for a removed branch. More...
static void setGeomEdge (std::size_t geomIndex, const TVDEdge *maEdge)
 Store data of boundary segments in TVDEdge. More...
static std::size_t getGeomEdge (const TVDEdge *maEdge)
static void setBndSegment (std::size_t segIndex, const TVDEdge *maEdge)
static std::size_t getBndSegment (const TVDEdge *maEdge)
bool addDivPntForConcaVertex (std::vector< std::size_t > &edgeIDs1, std::vector< std::size_t > &edgeIDs2, std::vector< BranchPoint > &divPoints, const std::vector< const TVDEdge * > &maEdges, const std::vector< const TVDEdge * > &maEdgesTwin, int &i) const
 Looks for a BranchPoint position around a concave VERTEX. More...
std::vector< const TVDEdge * > _maEdges
std::vector< double > _params
const Boundary * _boundary
BranchEnd _endPoint1
BranchEnd _endPoint2
BranchPoint _proxyPoint
It's main feature is to return two BoundaryPoint's per a point on it. Points on a Branch are defined by [0,1] parameter
◆ addDivPntForConcaVertex()
bool SMESH_MAT2d::Branch::addDivPntForConcaVertex ( std::vector< std::size_t > &  edgeIDs1,
std::vector< std::size_t > &  edgeIDs2,
std::vector< BranchPoint > &  divPoints,
const std::vector< const TVDEdge * > &  maEdges,
const std::vector< const TVDEdge * > &  maEdgesTwin,
int &  i
◆ getBndSegment()
std::size_t SMESH_MAT2d::Branch::getBndSegment ( const TVDEdge *  maEdge)
◆ getBoundaryPoints() [1/3]
bool SMESH_MAT2d::Branch::getBoundaryPoints ( const BranchPoint &  p,
BoundaryPoint &  bp1,
BoundaryPoint &  bp2
References SMESH_MAT2d::BranchPoint::_branch, SMESH_MAT2d::BranchPoint::_edgeParam, and SMESH_MAT2d::BranchPoint::_iEdge.
◆ getBoundaryPoints() [2/3]
bool SMESH_MAT2d::Branch::getBoundaryPoints ( double  param,
BoundaryPoint &  bp2
[in]param- [0;1] normalized param on the Branch
[out]bp1- BoundaryPoint on EDGE with a lower index
[out]bp2- BoundaryPoint on EDGE with a higher index
bool - true if the BoundaryPoint's found
◆ getBoundaryPoints() [3/3]
bool SMESH_MAT2d::Branch::getBoundaryPoints ( std::size_t  iMAEdge,
double  maEdgeParam,
BoundaryPoint &  bp2
[in]iMAEdge- index of a MA edge within this Branch
[in]maEdgeParam- [0;1] normalized param on the iMAEdge
◆ getEnd()
const BranchEnd * SMESH_MAT2d::Branch::getEnd ( bool  the2nd) const
◆ getGeomEdge()
std::size_t SMESH_MAT2d::Branch::getGeomEdge ( const TVDEdge *  maEdge)
◆ getGeomEdges()
void SMESH_MAT2d::Branch::getGeomEdges ( std::vector< std::size_t > &  edgeIDs1,
◆ getOppositeGeomEdges()
void SMESH_MAT2d::Branch::getOppositeGeomEdges ( std::vector< std::size_t > &  edgeIDs1,
[out]edgeIDs1- EDGE index opposite to the edgeIDs2[i]-th EDGE
[out]edgeIDs2- EDGE index opposite to the edgeIDs1[i]-th EDGE
[out]divPoints- BranchPoint's located between two successive unique pairs of EDGE indices. A divPoints[i] can separate e.g. two following pairs of EDGE indices < 0, 2 > and < 0, 1 >. Number of divPoints is one less than number of edgeIDs
◆ getParameter()
bool SMESH_MAT2d::Branch::getParameter ( const BranchPoint &  p,
double &  u
◆ getPoint()
SMESH_MAT2d::BranchPoint SMESH_MAT2d::Branch::getPoint ( const TVDVertex *  vertex) const
◆ getPoints()
void SMESH_MAT2d::Branch::getPoints ( std::vector< gp_XY > &  points,
Returns MA points.
[out]points- the 2d points
[in]scale- the scale that was used to scale the 2d space of MA
Referenced by SMESH_MAT2d::MedialAxis::getPoints(), and SMESH_MAT2d::MedialAxis::make3DCurve().
◆ hasEndOfType()
bool SMESH_MAT2d::Branch::hasEndOfType ( BranchEndType  type) const
◆ init()
void SMESH_MAT2d::Branch::init ( std::vector< const TVDEdge * > &  maEdges,
const Boundary *  boundary,
std::map< const TVDVertex *, BranchEndType > &  endType
◆ isRemoved()
bool SMESH_MAT2d::Branch::isRemoved ( ) const
◆ nbEdges()
std::size_t SMESH_MAT2d::Branch::nbEdges ( ) const
◆ setBndSegment()
void SMESH_MAT2d::Branch::setBndSegment ( std::size_t  segIndex,
◆ setBranchesToEnds()
void SMESH_MAT2d::Branch::setBranchesToEnds ( const std::vector< Branch > &  branches)
◆ setGeomEdge()
void SMESH_MAT2d::Branch::setGeomEdge ( std::size_t  geomIndex,
◆ setRemoved()
void SMESH_MAT2d::Branch::setRemoved ( const BranchPoint &  proxyPoint)
[in]proxyPoint- a point of another branch to which all points of this branch are mapped
◆ _boundary
const Boundary* SMESH_MAT2d::Branch::_boundary
◆ _endPoint1
BranchEnd SMESH_MAT2d::Branch::_endPoint1
◆ _endPoint2
BranchEnd SMESH_MAT2d::Branch::_endPoint2
◆ _maEdges
std::vector<const TVDEdge*> SMESH_MAT2d::Branch::_maEdges
◆ _params
std::vector<double> SMESH_MAT2d::Branch::_params
◆ _proxyPoint
BranchPoint SMESH_MAT2d::Branch::_proxyPoint
