StdMeshers_Arithmetic1D_i.hxx
24// File : StdMeshers_Arithmetic1D_i.hxx
25// Author : Damien COQUERET, OCC
26// Module : SMESH
27//
28#ifndef _SMESH_ARITHMETIC1D_I_HXX_
29#define _SMESH_ARITHMETIC1D_I_HXX_
30
32
33#include <SALOMEconfig.h>
34#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
35
38
39// ======================================================
40// Arithmetic 1D hypothesis
41// ======================================================
43 public virtual POA_StdMeshers::StdMeshers_Arithmetic1D,
44 public virtual SMESH_Hypothesis_i,
45 public virtual StdMeshers_Reversible1D_i
46{
47public:
48 // Constructor
49 StdMeshers_Arithmetic1D_i( PortableServer::POA_ptr thePOA,
50 ::SMESH_Gen* theGenImpl );
51 // Destructor
53
54 // Set length
55 // * OBSOLETE *. Avoid such a way of interface design
56 void SetLength( CORBA::Double theLength, CORBA::Boolean theIsStart );
57
58 // Sets <start segment length> parameter value
59 void SetStartLength( CORBA::Double length);
60
61 // Sets <end segment length> parameter value
62 void SetEndLength( CORBA::Double length);
63
64 // Get length
65 CORBA::Double GetLength(CORBA::Boolean theIsStart);
66
67 // Get implementation
69
70 // Verify whether hypothesis supports given entity type
71 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
72
73
74 // Methods for copying mesh definition to other geometry
75
76 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
77 virtual bool getObjectsDependOn( std::vector< std::string > & entryArray,
78 std::vector< int > & subIDArray ) const;
79
80 // Set new geometry instead of that returned by getObjectsDependOn()
81 virtual bool setObjectsDependOn( std::vector< std::string > & entryArray,
82 std::vector< int > & subIDArray );
83
84 protected:
85 virtual std::string getMethodOfParameter(const int paramIndex, int nbVars) const;
86};
87
88#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)=0
virtual std::string getMethodOfParameter(const int, int) const
Definition: SMESH_Hypothesis_i.hxx:134
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const =0
Definition: StdMeshers_Arithmetic1D_i.hxx:46
Definition: StdMeshers_Arithmetic1D.hxx:40
Definition: StdMeshers_Reversible1D_i.hxx:43
Dimension
