StdMeshers_BlockRenumber_i.hxx
23// File : StdMeshers_BlockRenumber_i.hxx
24// Author : Edward AGAPOV
25// Module : SMESH
26//
27#ifndef _SMESH_BlockRenumber_I_HXX_
28#define _SMESH_BlockRenumber_I_HXX_
31
32#include <SALOMEconfig.h>
33#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
34
37
38class SMESH_Gen;
39
40// =========================================================
45// =========================================================
46
48 public virtual POA_StdMeshers::StdMeshers_BlockRenumber,
49 public virtual SMESH_Hypothesis_i
50{
51public:
52
53 StdMeshers_BlockRenumber_i( PortableServer::POA_ptr thePOA,
54 ::SMESH_Gen* theGenImpl );
55
56 // Set orientation of blocks
57 void SetBlocksOrientation( const StdMeshers::blockcs_array& blockCS ) override;
58
59 // Return orientation of blocks
60 StdMeshers::blockcs_array* GetBlocksOrientation() override;
61
62
63 // Get implementation
65
66 // Verify whether hypothesis supports given entity type
67 CORBA::Boolean IsDimSupported( SMESH::Dimension type ) override;
68
69 // Methods for copying mesh definition to other geometry
70 bool getObjectsDependOn( std::vector< std::string > & entryArray,
71 std::vector< int > & subIDArray ) const override;
72 bool setObjectsDependOn( std::vector< std::string > & entryArray,
73 std::vector< int > & subIDArray ) override;
74};
75
76#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray)=0
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual bool getObjectsDependOn(std::vector< std::string > &entryArray, std::vector< int > &subIDArray) const =0
Definition: StdMeshers_BlockRenumber_i.hxx:50
Definition: StdMeshers_BlockRenumber.hxx:72
Dimension
sequence< BlockCS > blockcs_array
Definition: SMESH_BasicHypothesis.idl:1125
