StdMeshers_Deflection1D_i.hxx
24// File : StdMeshers_Deflection1D_i.hxx
25// Moved here from SMESH_LocalLength_i.hxx
26// Author : Paul RASCLE, EDF
27// Module : SMESH
28//
29#ifndef _SMESH_Deflection1D_I_HXX_
30#define _SMESH_Deflection1D_I_HXX_
31
33
34#include <SALOMEconfig.h>
35#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
36
39
40class SMESH_Gen;
41
42// ======================================================
43// Local Length hypothesis
44// ======================================================
46 public virtual POA_StdMeshers::StdMeshers_Deflection1D,
47 public virtual SMESH_Hypothesis_i
48{
49public:
50 // Constructor
51 StdMeshers_Deflection1D_i( PortableServer::POA_ptr thePOA,
52 ::SMESH_Gen* theGenImpl );
53 // Destructor
55
56 // Set deflection
57 void SetDeflection( CORBA::Double theLength );
58 // Get deflection
59 CORBA::Double GetDeflection();
60
61 // Get implementation
63
64 // Verify whether hypothesis supports given entity type
65 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
66
67 // Methods for copying mesh definition to other geometry
68 virtual bool getObjectsDependOn( std::vector< std::string > & /*entryArray*/,
69 std::vector< int > & /*subIDArray*/ ) const { return false; }
70 virtual bool setObjectsDependOn( std::vector< std::string > & /*entryArray*/,
71 std::vector< int > & /*subIDArray*/ ) { return true; }
72 protected:
73 virtual std::string getMethodOfParameter(const int paramIndex, int nbVars) const;
74};
75
76#endif
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual std::string getMethodOfParameter(const int, int) const
Definition: SMESH_Hypothesis_i.hxx:134
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
Definition: StdMeshers_Deflection1D_i.hxx:48
virtual bool getObjectsDependOn(std::vector< std::string > &, std::vector< int > &) const
Definition: StdMeshers_Deflection1D_i.hxx:68
virtual bool setObjectsDependOn(std::vector< std::string > &, std::vector< int > &)
Definition: StdMeshers_Deflection1D_i.hxx:70
Definition: StdMeshers_Deflection1D.hxx:36
Dimension
