StdMeshers_ImportSource1D_i.hxx
24// File : StdMeshers_ImportSource1D_i.hxx
25// Module : SMESH
26//
27#ifndef _SMESH_ImportSource1D_I_HXX_
28#define _SMESH_ImportSource1D_I_HXX_
31
32#include <SALOMEconfig.h>
33#include CORBA_SERVER_HEADER(SMESH_BasicHypothesis)
34
37
38class SMESH_Gen;
39
41 public virtual POA_StdMeshers::StdMeshers_ImportSource1D,
42 public virtual SMESH_Hypothesis_i
43{
44 public:
45 // Constructor
46 StdMeshers_ImportSource1D_i( PortableServer::POA_ptr thePOA,
47 ::SMESH_Gen* theGenImpl );
48 // Destructor
50
51 void SetSourceEdges(const ::SMESH::ListOfGroups& groups);
52 SMESH::string_array* GetSourceEdges();
53 void SetCopySourceMesh(::CORBA::Boolean toCopyMesh, ::CORBA::Boolean toCopyGroups);
54 void GetCopySourceMesh(::CORBA::Boolean& toCopyMesh, ::CORBA::Boolean& toCopyGroups);
55
56 // Get implementation
58
59 // Verify whether hypothesis supports given entity type
60 CORBA::Boolean IsDimSupported( SMESH::Dimension type );
61
62 // Redefined Persistence
63 virtual char* SaveTo();
64 virtual void LoadFrom( const char* theStream );
65 virtual void UpdateAsMeshesRestored();
66
67
68
69 // Methods for copying mesh definition to other geometry
70
71 // Return geometry this hypothesis depends on. Return false if there is no geometry parameter
72 virtual bool getObjectsDependOn( std::vector< std::string > & /*entryArray*/,
73 std::vector< int > & /*subIDArray*/ ) const { return 0; }
74
75 // Set new geometry instead of that returned by getObjectsDependOn()
76 virtual bool setObjectsDependOn( std::vector< std::string > & /*entryArray*/,
77 std::vector< int > & /*subIDArray*/ ) { return true; }
78 private:
79 SMESH::string_array_var _groupEntries;
80 std::vector< std::string > _groupIDs;
81};
82
83#endif
84
#define STDMESHERS_I_EXPORT
Definition: SMESH_StdMeshers_I.hxx:38
Definition: SMESH_Gen.hxx:68
virtual void LoadFrom(const char *theStream)
SMESH_Hypothesis_i::LoadFrom.
Definition: SMESH_Hypothesis_i.cxx:288
Definition: SMESH_Hypothesis_i.cxx:327
::SMESH_Hypothesis * GetImpl()
SMESH_Hypothesis_i::GetImpl.
Definition: SMESH_Hypothesis_i.cxx:236
virtual char * SaveTo()
SMESH_Hypothesis_i::SaveTo.
Definition: SMESH_Hypothesis_i.cxx:262
Definition: StdMeshers_ImportSource1D_i.hxx:43
Definition: StdMeshers_ImportSource1D_i.hxx:79
virtual bool setObjectsDependOn(std::vector< std::string > &, std::vector< int > &)
Definition: StdMeshers_ImportSource1D_i.hxx:76
Definition: StdMeshers_ImportSource1D_i.hxx:80
virtual bool getObjectsDependOn(std::vector< std::string > &, std::vector< int > &) const
Definition: StdMeshers_ImportSource1D_i.hxx:72
Stores groups to import elements from.
Definition: StdMeshers_ImportSource.hxx:49
Dimension
sequence< string > string_array
Definition: SMESH_Mesh.idl:46
sequence< SMESH_GroupBase > ListOfGroups
Definition: SMESH_Mesh.idl:39
